Timeline of Generational Changes
Since there’s been some confusion, this post is a timeline outlining the major changes between generations of Framework Laptop 13. It has been marked as a wiki post so anyone can edit it. Feel free to correct any errors you see.
Changes persist between generations unless otherwise indicated.
Intel Core 11th Gen (Batch 1 Shipped August 2021)
  • Around October 2021, Framework switched the audio codec from Realtek ALC295 to the Tempo 92HD95B due to chip shortages
Intel Core 12th Gen (Batch 1 Shipped July 2022)
  • New CNC Top Cover
  • RTC Battery no longer required for operation (still populated by default)
Intel Core 13th Gen (Batch 1 Shipped May/June 2023)
Announced at the same time as AMD 7040 Series. Only the changes listed under both models apply to both models.
  • Matte Display
  • 3.5 Kg Hinges
  • 61 Wh Battery (Core i7 configs only)
  • RTC Battery not populated by default
  • WiFi Card Bracket which holds antenna connectors while handling the card
  • 80 dB Speakers
AMD Ryzen 7040 Series (Batch 1 Shipped October 2023)
Announced at the same time as 13th Gen Intel Core. Only the changes listed under both models apply to both models.
  • Matte Display
  • 3.5 Kg Hinges
  • 61 Wh Battery (Ryzen 7 configs only)
  • RealTek ALC295 Audio CODEC (return of the original CODEC from Intel Core 11th Gen)
  • 2-pin RTC Battery connector replaces old battery socket
Does the 2pin RTC connector allows non rechargeable batteries like in any other laptop/desktop?
Edited to separate Intel Core 13th Gen and AMD Ryzen 7040 Series
I doubt it, but they haven’t said. It’s really not good to put non-rechargeable RTC batteries in any device that is designed for rechargables. It can damage the board and/or the battery, and would need to be replaced often.
For a short moment, I thought we are going to see the product road map. ^^;
Nope! Not a framework employee, so I don’t have that info (as much as I would love to as well).
It wouldn’t be wise for them to publish unreleased products too. But I admit I was tempted to click into this post in hopes of seeing something about Meteor Lake.
Added some dates. Timeline needs dates, IMO.
Minor hyperlink and formatting changes. Thanks for the times @Second_Coming.
Added batch 1 shipping date for AMD 7040 series.
If I have the Framework Laptop 13 DIY Edition (AMD Ryzen™ 7040 Series) shipped January 2024, is that considered 1st Gen Batch 1, then?
No. Batch 1 of AMD 7040 Series shipped in October 2023. You placed an in-stock order.
This has not been updated in a while and I just found this Framework Laptop 13 | Framewiki.
Should we still keep this post here?
Perhaps just a note that this is no longer being updated and that one should use the framewiki instead.
