By the way, are the hibernate and shutdown battery drain issues also part of the fixes? I somewhat remember that it was part of the reason why people switched to 3.08!
Yeah, nrp said itâs fixed:
On my dual boot Win 11 and Ubuntu 22.04 I had no issues with battery drain in either state, but I donât use the USB A and HDMI ports that apparently keep a live state, and yes I think there is mention of a fix for when those cards are used.
See Battery slowly drains when completely shut down - #106 by Anand_Gadiyar
The above post and those following
and
More than sad, but Iâd be more concerned about the RTC|CMOS battery holding out
So all these BIOS update issues and workarounds for folks on Linux?
If you are on Ubuntu or Fedora there are no issues.
More than sad
This journey has taught me: Every early adopter is a willing suckerâŚno matter how good the PR & marketing materials were. Willing to settle for less, willing to suck it up, willing to wait it out.
For me the EFI Shell method worked without any major issues (from 3.07 to 3.09 beta). PopOS with LUKS encrypted nvme.
I however have two minor findings:
- The maximum battery percentage setting was lost and I had to set it again
- I have set a BIOS supervisor password and I kind of expected that I had to fill it in before the upgrade. But that wasnât needed in the end.
In the OP:
Updating the BIOS firmware will erase NVRAM boot variables
Guess itâs not just boot variables.
Not sure this is accurate, at least with my current board (could be defective) Iâm losing 1% per hour with 2 USB-A ports.
I have upgraded on Windows and so far so good!
Still have some issues with Modern Standby but that is likely more of a Windows driver issue than a BIOS one.
Not sure if itâs been mentioned in this thread but I noticed that after going from 3.07 to 3.09 I would constantly have disconnecting/reconnecting USB sounds coming from windows. I looked up the event viewer logs and saw that it had to do with USB Selective Suspend. I didnât have anything with USB in the power settings so I wound up disabling shutting down USB power in device manager. Is there a better fix for this or do I keep this setting on until another BIOS version is released?
Maybe related to the battery useage.
Best Power Efficiency
Balanced
Best performance
The later will stop idle things being powered down etc. So that would mean the USB A may be powered continuously.
Updated with LVFS from Fedora 36. No issues so far. Took maybe 5 minutes.
Everything worked, used fwupdmgr update
, took 5:49min. Now full battery, going to let the laptop in sleep mode for 12h to see how much battery loss there is.
First impressions are good. Fingerprint scanner feels snappier and more accurate, on the older bios it took 2 or 3 turns before my fingerprint was recognized. Now it works the first time.
Also my external monitor gets recognized immediately after boot and hibernation, before I had to unplug and replug (usbc to dipslaylink cable).
Using Archlinux, I3WM with LUKS encryption.
One strange thing I found was that post bios update my laptop cannot seem to enter a sleep state. The screen turns off and the power button flashes, but the battery keeps draining at a enormous rate and the laptop gets HOT (almost burned myself when I took it out of my backpack. I never experienced this problem on 3.07/3.08.
This proabably isnât BIOS though as I just recently updated from Windows 11 Insider Beta preview to developer preview. Sleep Study also doesnât update any more.
Yes I noticed the drain and heat in 3.07 and 3.08 though too.
I wouldnât put it to sleep in a bag, only on the desk when I frequently visit, else itâs hibernate.
My observations of sleep in Linux have been rock solid. Windows was problematic, with Windows sometimes acting like it was sleeping but thinking it was cool to still be awake to work on updates or other nonsense. I got around worrying about this on Windows with hibernation.
I operate essentially the same under Linux, but standby time is greatly improved. I see about 1-3% drain per hour, with 1% being the the average. I have had the computer sleeping for 8 hours to come back to only 9% drained. That, to me, is great standby battery life.
Sadly most of the issues I had with my Framework seemed to be Windows oriented in nature. Life under Ubuntu and running Windows in a VM has been pretty excellent.
Not seeing differences in standby drain on Windows (only one datapoint though). This is with 1 USB-C, 2 USB-A, 1 HDMI cards.
3.07:
Update for BIOS 3.09 â no apparent differences in standby drain (as expected). [image]
Adding to the list of successes - updated from 3.06 - 3.09 via fwupdmgr on Fedora 35. Also went ahead and updated to Fedora 36 as well. So far so good.
Me neither. Still same old, same old; rather high drain (1w+) when I plug in USB-A or the HDMI expansion card.
Fedora 36. Ran the fwupdmgr command. No errors displayed, but still on BiOS 3.07. Tried from bootable USB drive - got an error and it dropped to a shell. SecureBoot is disabled in BIOS. DisableCapsuleUpdateOnDisk=true is configured in uefi_capsule.conf.
What else can I try?
I have the same problem (Fedora 36)
after the reboot im still on 3.07
