I’m still on the 11th gen board, with BIOS 3.22, USB-C cards only, 2 x 32GB. With Fedora 42 and Ubuntu 24.04 LTS, I’m still unable to get s2idle to sip sub-0.5w during suspend. What am I missing here? It’s been 4 years, and I was hoping that Framework and / or the Linux community could have this addressed.
The only other ‘workarounds’ I’ve seen seem to be going with either:
S3 / deep, but with longer wake up time. (like 20 seconds+); or,
Leverage suspend AND (then) hibernate, never suspend alone. Which still means the suspended state still sips more than it should.
I have NixOS installed on my 11th gen intel machine. It has 2*16GB ram. Recently updated to 3.22. Using s2idle and overnight less than %1 per hour battery is consumed which sub 0.5w. It has samsung 970 evo 1tb if that is a factor.
I wonder if that’s a factor. I just gave NixOS a go, but I didn’t reach the same outcome. Was there any additional / specific configuration done on your system?
I just went out and got an SN7100 1TB. Going to see if there’s any energy benefit coming from the SN850 1TB, and the SN850X 1TB. Will report back.
Currently testing out Idle Powered On (NixOS, 6.16 kernel, Plasma, 20% brightness, wifi on / wpa3, added nixos-hardware, sleep disabled). Then I’ll test suspend energy consumption.
So, on the Windows 11 Pro side, normal installation, plus the driver bundle, changed standbybudgetpercent to 40%. It slept for 8 hours and 14 minutes. During that period, it was averaging at 716mW.
Nice, NixOS won this nicely, both with fresh installation and minimal configuration changes.
