Do any of the main boards for the framework 13 pro (i.e. the most current generation) support 128GB LPDDR5X and the lack of the possible selection is a supply issue? or is there a technical limitation?
I think the issue is that currently, the largest single LPCAMM2 modules available are 64GB. I believe the system can theoretically support more RAM, but it will require the market to release higher density modules with larger capacities.
Based on this article Intel says their chips support 96GB and Samsung is making modules
https://www.techspot.com/news/111331-samsung-readies-lpcamm2-lpddr5x-modules-up-96gb-9600.html
