1440x960 resolution on the 2.8k display
The 2.8k display on my FW13 7640u for some reason doesn’t present 1440x960 as a supported resolution, the closest is 1440x900. I know I can add custom resolutions and it works (xrandr on Linux in my case), but it would be nice if the monitor actually reported pretty much the only non-native resolution that makes sense.
I’ve asked it a while ago on the Discord, but since that got shut down I don’t know if it was ever picked up or if there’s a reason why the monitor doesn’t report this resolution. I assume it would need to have the EDID reprogrammed.
Using this modeline: Modeline "1440x960_120.00" 245.25 1440 1560 1712 1984 960 963 973 1032 -hsync +vsync
I am not really sure what the point of having 1440x960 in the list of resolutions would be given that, in year 2026, you would actually achieve it by selecting 2880x1920 with 200% scaling anyway.
I think this list of resolutions in EDID is mostly a legacy backwards-compatibility thing anyway. So it makes sense to me that they would populate it with a bunch of legacy “standard” resolutions that are not achievable from the native one by scaling with a reasonable coefficient.
This is a legal claim to me. First, not all desktop environments bring the ability to set scaling. And second, no all programs handle the scaling correctly. So setting the overall resolution can handle those problems, and maybe others too.
It improves performance in some games, sometimes quite significantly. In World of Warships easily around 20% for example. Some games just don’t handle resolution settings well. The nice thing about the 2.8k screen is that 1140x960 is still a very usable resolution on a screen this size without looking like it’s coated in vaseline.
It should be a fairly trivial addition, the panel supports it just fine (at least on 120hz). It just isn’t reporting it.
That’s… pretty dumb if 1440x960 isn’t supported. Is this a linux only thing maybe?
Nope, Windows 10 at least doesn’t support 1440x960, not even 1440x900 which Linux does support.
Oddly enough Windows 10 seemed to offer fewer resolution options than Linux for some unknown reason.
Unless they started putting scalers into integrated displays now you aren’t really gaining anything from outputting less resolution as the gpu is still scaling it and sending it to the display at full resolution. If you just want to give games weird resolutions probably easier to just use gamescope for that.
Is there a difference betwwen setting the game to 1440x960 or adjusting the system setting to 1440x960 so the game can only recognize 1440x960 (and below)?
It mostly changes where the scaling is done (assuming you mean windowed/borderless where setting the game resolution doesn’t change the display resolution) if you set it in the game it’s the compositor that has to do the scaling, if you set the system it’s the gpu or the display (if that does have a scaler, integrated displays usually don’t afaik.)
Running through gamescope gamescope however let’s you do some neat stuff, it lets you use integer scaling for those crisp pixels or fsr (usually better than normal gpu/display scaling). It also let’s you scam some games into thinking your screen has different resolutions for those that don’t handle some resolutions well.
