240 Watt USB-C Charger
Hello framework community
I have recently picked up a 240 watt USB-C PD 3.1 charger from Mouser Electronics made by delta the ADP-240KB BA. I tested my Framework 16 + GPU with an endurance stress test to verify that the battery drain under heavy load issue was solved with higher available power; it managed to charge during the 3D Mark endurance stress test that would drain it otherwise.
If anyone is interested the brick is larger with an integrated USB-C cable so not ideal but seems to be good quality, Delta is a well known manufacturer.
Spec Sheet Page: Products_202402271704188990-3412395.pdf
CA Product Page: ADP-240KB BA Delta Electronics | Mouser Canada
US Product Page: ADP-240KB BA Delta Electronics | Mouser
A post was merged into an existing topic: A call on 240w adapter
