Hi all,
Basics:
- FW13 chassis
- 7640U (3.18 BIOS), AI 340 (3.05 BIOS) boards
- Cooler Master standalone case
- Windows 11
- RTC Battery installed
- 65W GaN charge/ 140W battery
I’ve been working through troubleshooting steps with Framework support, but this seems to be a tricky one, so I’m hoping someone else has bumped into this before. The situation is this, I bought a FW13 with a 7640U board and used it for about a year until deciding that I wanted to move that board into the Cooler Master standalone case to replace my ageing HTPC. I ended up ordering a AI 300 board as a replacement for the laptop and installing the 7640U board in the CM case.
Both boards absoluely refuse to boot in the CM case, no matter what I try. They’re both set to standalone mode and have an RTC battery installed.
Most of the troubleshooting has been done on the 7640U so I’ll focus on that. Initially I didn’t set it to standalone mode, so it did the red/blue flashing LEDs. After sticking it back in the laptop chassis and setting it to standalone mode, the red/blue LEDs don’t flash, just the white/green power indicator LEDs on the side of the board with the power input.
The board behaves in two different ways and seems to switch between them at random.
Mode 1: Most of the time, pushing the power button causes the power indicator LEDs on the board to turn off momentarily, the fan to spin for 2-5 seconds, and the ethernet adapter activity lights to flash on once. It seems to need a couple of seconds between power button presses, but it will repeat that pattern as long as you have patience to keep pressing the button.
Mode 2: Infrequent, not easily reproduced. Every now and again after some new troubleshooting steps the board will light the power indicator LEDs when power is connected but pushing the power button doesn’t cause those LEDs to flicker off. The fan usually doesn’t spin, but the CPU and SSD controller get hot (almost painful to the touch) for about 10 seconds and then cool back off. When it’s behaving in this way pushing the power button usually does nothing, but once it’s been through its heating/cooling cycle, the power button will eventually cause the heating cycle to repeat. Sometimes the ethernet adapter activity lights flash twice, sometimes not at all.
At no point has either board given any display output when in the standalone case. Both boards boot and work flawlessly in the FW13 chassis.
I’ve tested the following:
- I/O modules in most (all?) permutations of the 4 slots (all installed and minimal installed)
- 3 GaN chargers 45W and 60W
- 140W battery bank (Ugreen) to rule out under power condition
- 6+ USB C cables (mostly Anker) in different lenghts
- Only HDMI out (available monitor/module)
- Both the 7640U and AI 340 boards (AI 340 only seems to do Mode 1 described above, but I haven’t tested it as much)
- Turned off secure boot
- Both boards have Samsung SSDs and RAM on the compatable list
- Reseting the 7640U using the case open switch 10x press
There’s probably more, but that’s all that comes to mind at the moment. Framework support has run me through troubleshooting and pointed me toward the community post below but I can’t replicate what they describe in step 2. Setting the board to standalone mode should get me to step 5, but it still doesn’t change the behaviour.
If anyone has any thoughts I’m open to suggestions before I break down and just buy a new chassis, since that seems to make it boot reliably. I’ve been building my own PCs for ever and don’t mind troubleshooting, but I’m entirely out of ideas at this point.
Thanks in advance.
