ALS Not Working after upgrading to Fedora 41
Sorry if this has been mentioned elsewhere, I just wanted to share that after upgrading to Fedora 41 I no longer have access to ALS correcting screen brightness automatically. It has been removed from settings/power and I am unable to currently find a method to enable it.
Which kernel are you using? Linux 6.11.8-300.fc41.x86_64
Which Framework Laptop 13 model are you using? (AMD Ryzen™ 7040 Series)
This is a Fedora bug: 2324181 – selinux is denying iio-sensor-proxy write access to sysfs which it needs for certain iio sensors
Thanks for that Jules, reading that is mostly incoherent for me.
So when the bugs are created they just get fixed eventually? or how does that work?
On Linux usually more often and faster than on Windows, but how long exactly it takes in each case may vary significantly depending on priorities set by a given distro and/or community involvement.
Fix is in testing, you can install the update manually or wait for it to reach stable: FEDORA-2025-62c612355c — bugfix update for selinux-policy — Fedora Updates System
I don’t mind waiting, do you know roughly how long it takes to go live? Also, thank you for keeping up with this. It is very nice of you!
It has reached live and working perfectly to the best of my knowledge. I hope it is working for others!
