just run iw phy on your intel
and diff it to the mtk:
Wiphy phy0
wiphy index: 0
max # scan SSIDs: 4
max scan IEs length: 482 bytes
max # sched scan SSIDs: 10
max # match sets: 16
Retry short limit: 7
Retry long limit: 4
Coverage class: 0 (up to 0m)
Device supports AP-side u-APSD.
Device supports T-DLS.
Supported Ciphers:
* WEP40 (00-0f-ac:1)
* WEP104 (00-0f-ac:5)
* TKIP (00-0f-ac:2)
* CCMP-128 (00-0f-ac:4)
* CCMP-256 (00-0f-ac:10)
* GCMP-128 (00-0f-ac:8)
* GCMP-256 (00-0f-ac:9)
* CMAC (00-0f-ac:6)
* CMAC-256 (00-0f-ac:13)
* GMAC-128 (00-0f-ac:11)
* GMAC-256 (00-0f-ac:12)
Available Antennas: TX 0x3 RX 0x3
Configured Antennas: TX 0x3 RX 0x3
Supported interface modes:
* managed
* AP
* AP/VLAN
* monitor
* P2P-client
* P2P-GO
Band 1:
Capabilities: 0x9ff
RX LDPC
HT20/HT40
SM Power Save disabled
RX Greenfield
RX HT20 SGI
RX HT40 SGI
TX STBC
RX STBC 1-stream
Max AMSDU length: 7935 bytes
No DSSS/CCK HT40
Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
Minimum RX AMPDU time spacing: No restriction (0x00)
HT TX/RX MCS rate indexes supported: 0-15
HE Iftypes: managed
HE MAC Capabilities (0x08011a000040):
+HTC HE Supported
Trigger Frame MAC Padding Duration: 2
OM Control
Maximum A-MPDU Length Exponent: 3
A-MSDU in A-MPDU
HE PHY Capabilities: (0x2a70ce120dc0b3064e3f00):
HE40/2.4GHz
HE160/5GHz
242 tone RUs/2.4GHz
Device Class: 1
LDPC Coding in Payload
HE SU PPDU with 1x HE-LTF and 0.8us GI
NDP with 4x HE-LTF and 3.2us GI
STBC Tx <= 80MHz
STBC Rx <= 80MHz
Full Bandwidth UL MU-MIMO
Partial Bandwidth UL MU-MIMO
DCM Max Constellation: 2
DCM Max Constellation Rx: 2
SU Beamformee
Beamformee STS <= 80Mhz: 3
Ng = 16 SU Feedback
Ng = 16 MU Feedback
Codebook Size SU Feedback
Codebook Size MU Feedback
Triggered CQI Feedback
Partial Bandwidth Extended Range
PPE Threshold Present
Power Boost Factor ar
HE SU PPDU & HE PPDU 4x HE-LTF 0.8us GI
20MHz in 40MHz HE PPDU 2.4GHz
20MHz in 160/80+80MHz HE PPDU
80MHz in 160/80+80MHz HE PPDU
DCM Max BW: 1
Longer Than 16HE SIG-B OFDM Symbols
Non-Triggered CQI Feedback
TX 1024-QAM
RX 1024-QAM
RX Full BW SU Using HE MU PPDU with Compression SIGB
RX Full BW SU Using HE MU PPDU with Non-Compression SIGB
HE RX MCS and NSS set <= 80 MHz
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: not supported
4 streams: not supported
5 streams: not supported
6 streams: not supported
7 streams: not supported
8 streams: not supported
HE TX MCS and NSS set <= 80 MHz
1 streams: MCS 0-11
2 streams: MCS 0-11
HE RX MCS and NSS set 160 MHz
1 streams: MCS 0-11
2 streams: MCS 0-11
HE TX MCS and NSS set 160 MHz
1 streams: MCS 0-11
2 streams: MCS 0-11
PPE Threshold 0x39 0x1c 0xc7 0x71 0x1c 0x07
EHT Iftypes: managed
EHT MAC Capabilities (0x0000):
EHT PHY Capabilities: (0x0000000000000000):
EHT MCS/NSS: (0x):
EHT bw=160 MHz, max NSS for MCS 8-9: Rx=0, Tx=0
EHT bw=160 MHz, max NSS for MCS 10-11: Rx=0, Tx=0
EHT bw=160 MHz, max NSS for MCS 12-13: Rx=0, Tx=0
HE Iftypes: AP
HE MAC Capabilities (0x00011a081044):
+HTC HE Supported
BSR
OM Control
BQR
A-MSDU in A-MPDU
OM Control UL MU Data Disable RX
HE PHY Capabilities: (0x0220ce120000a000000c00):
HE40/2.4GHz
STBC Tx <= 80MHz
STBC Rx <= 80MHz
TX 1024-QAM
RX 1024-QAM
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
EHT Iftypes: AP
EHT MCS/NSS: (0x):
EHT bw=20 MHz, max NSS for MCS 0-7: Rx=0, Tx=0
EHT bw=20 MHz, max NSS for MCS 8-9: Rx=0, Tx=0
EHT bw=20 MHz, max NSS for MCS 10-11: Rx=0, Tx=0
EHT bw=20 MHz, max NSS for MCS 12-13: Rx=0, Tx=0
Bitrates (non-HT):
* 1.0 Mbps (short preamble supported)
* 2.0 Mbps (short preamble supported)
* 5.5 Mbps (short preamble supported)
* 11.0 Mbps (short preamble supported)
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
* 2412 MHz [1] (30.0 dBm)
* 2417 MHz [2] (30.0 dBm)
* 2422 MHz [3] (30.0 dBm)
* 2427 MHz [4] (30.0 dBm)
* 2432 MHz [5] (30.0 dBm)
* 2437 MHz [6] (30.0 dBm)
* 2442 MHz [7] (30.0 dBm)
* 2447 MHz [8] (30.0 dBm)
* 2452 MHz [9] (30.0 dBm)
* 2457 MHz [10] (30.0 dBm)
* 2462 MHz [11] (30.0 dBm)
* 2467 MHz [12] (disabled)
* 2472 MHz [13] (disabled)
* 2484 MHz [14] (disabled)
Band 2:
Capabilities: 0x9ff
RX LDPC
HT20/HT40
RX Greenfield
RX HT20 SGI
RX HT40 SGI
TX STBC
RX STBC 1-stream
No DSSS/CCK HT40
VHT Capabilities (0x339071f6):
Max MPDU length: 11454
Supported Channel Width: 160 MHz
RX LDPC
short GI (80 MHz)
short GI (160/80+80 MHz)
TX STBC
SU Beamformee
MU Beamformee
RX antenna pattern consistency
TX antenna pattern consistency
VHT RX MCS set:
1 streams: MCS 0-9
2 streams: MCS 0-9
VHT RX highest supported: 0 Mbps
VHT TX MCS set:
1 streams: MCS 0-9
2 streams: MCS 0-9
VHT TX highest supported: 0 Mbps
VHT extended NSS: supported
HE Iftypes: managed
+HTC HE Supported
OM Control
A-MSDU in A-MPDU
HE PHY Capabilities: (0x4c70ce120dc0b3064e3f00):
HE40/HE80/5GHz
HE160/5GHz
242 tone RUs/5GHz
Device Class: 1
STBC Tx <= 80MHz
STBC Rx <= 80MHz
SU Beamformee
Ng = 16 SU Feedback
Ng = 16 MU Feedback
DCM Max BW: 1
TX 1024-QAM
RX 1024-QAM
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
EHT MCS/NSS: (0x):
EHT bw <= 80 MHz, max NSS for MCS 8-9: Rx=0, Tx=0
EHT bw <= 80 MHz, max NSS for MCS 10-11: Rx=0, Tx=0
EHT bw <= 80 MHz, max NSS for MCS 12-13: Rx=0, Tx=0
HE Iftypes: AP
+HTC HE Supported
BSR
OM Control
BQR
A-MSDU in A-MPDU
HE PHY Capabilities: (0x0420ce120000a000000c00):
HE40/HE80/5GHz
STBC Tx <= 80MHz
STBC Rx <= 80MHz
TX 1024-QAM
RX 1024-QAM
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
EHT Iftypes: AP
EHT MCS/NSS: (0x):
Bitrates (non-HT):
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
* 5180 MHz [36] (23.0 dBm)
* 5200 MHz [40] (23.0 dBm)
* 5220 MHz [44] (23.0 dBm)
* 5240 MHz [48] (23.0 dBm)
* 5260 MHz [52] (24.0 dBm) (radar detection)
* 5280 MHz [56] (24.0 dBm) (radar detection)
* 5300 MHz [60] (24.0 dBm) (radar detection)
* 5320 MHz [64] (24.0 dBm) (radar detection)
* 5500 MHz [100] (24.0 dBm) (radar detection)
* 5520 MHz [104] (24.0 dBm) (radar detection)
* 5540 MHz [108] (24.0 dBm) (radar detection)
* 5560 MHz [112] (24.0 dBm) (radar detection)
* 5580 MHz [116] (24.0 dBm) (radar detection)
* 5600 MHz [120] (24.0 dBm) (radar detection)
* 5620 MHz [124] (24.0 dBm) (radar detection)
* 5640 MHz [128] (24.0 dBm) (radar detection)
* 5660 MHz [132] (24.0 dBm) (radar detection)
* 5680 MHz [136] (24.0 dBm) (radar detection)
* 5700 MHz [140] (24.0 dBm) (radar detection)
* 5720 MHz [144] (24.0 dBm) (radar detection)
* 5745 MHz [149] (30.0 dBm)
* 5765 MHz [153] (30.0 dBm)
* 5785 MHz [157] (30.0 dBm)
* 5805 MHz [161] (30.0 dBm)
* 5825 MHz [165] (30.0 dBm)
* 5845 MHz [169] (27.0 dBm) (no IR)
* 5865 MHz [173] (disabled)
* 5885 MHz [177] (disabled)
Band 4:
HE Iftypes: managed
+HTC HE Supported
OM Control
A-MSDU in A-MPDU
HE40/HE80/5GHz
HE160/5GHz
242 tone RUs/5GHz
Device Class: 1
STBC Tx <= 80MHz
STBC Rx <= 80MHz
SU Beamformee
Ng = 16 SU Feedback
Ng = 16 MU Feedback
DCM Max BW: 1
TX 1024-QAM
RX 1024-QAM
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
EHT MCS/NSS: (0x):
HE Iftypes: AP
+HTC HE Supported
BSR
OM Control
BQR
A-MSDU in A-MPDU
HE40/HE80/5GHz
STBC Tx <= 80MHz
STBC Rx <= 80MHz
TX 1024-QAM
RX 1024-QAM
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
EHT Iftypes: AP
EHT MCS/NSS: (0x):
Bitrates (non-HT):
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
* 5955 MHz [1] (disabled)
* 5975 MHz [5] (disabled)
* 5995 MHz [9] (disabled)
* 6015 MHz [13] (disabled)
* 6035 MHz [17] (disabled)
* 6055 MHz [21] (disabled)
* 6075 MHz [25] (disabled)
* 6095 MHz [29] (disabled)
* 6115 MHz [33] (disabled)
* 6135 MHz [37] (disabled)
* 6155 MHz [41] (disabled)
* 6175 MHz [45] (disabled)
* 6195 MHz [49] (disabled)
* 6215 MHz [53] (disabled)
* 6235 MHz [57] (disabled)
* 6255 MHz [61] (disabled)
* 6275 MHz [65] (disabled)
* 6295 MHz [69] (disabled)
* 6315 MHz [73] (disabled)
* 6335 MHz [77] (disabled)
* 6355 MHz [81] (disabled)
* 6375 MHz [85] (disabled)
* 6395 MHz [89] (disabled)
* 6415 MHz [93] (disabled)
* 6435 MHz [97] (disabled)
* 6455 MHz [101] (disabled)
* 6475 MHz [105] (disabled)
* 6495 MHz [109] (disabled)
* 6515 MHz [113] (disabled)
* 6535 MHz [117] (disabled)
* 6555 MHz [121] (disabled)
* 6575 MHz [125] (disabled)
* 6595 MHz [129] (disabled)
* 6615 MHz [133] (disabled)
* 6635 MHz [137] (disabled)
* 6655 MHz [141] (disabled)
* 6675 MHz [145] (disabled)
* 6695 MHz [149] (disabled)
* 6715 MHz [153] (disabled)
* 6735 MHz [157] (disabled)
* 6755 MHz [161] (disabled)
* 6775 MHz [165] (disabled)
* 6795 MHz [169] (disabled)
* 6815 MHz [173] (disabled)
* 6835 MHz [177] (disabled)
* 6855 MHz [181] (disabled)
* 6875 MHz [185] (disabled)
* 6895 MHz [189] (disabled)
* 6915 MHz [193] (disabled)
* 6935 MHz [197] (disabled)
* 6955 MHz [201] (disabled)
* 6975 MHz [205] (disabled)
* 6995 MHz [209] (disabled)
* 7015 MHz [213] (disabled)
* 7035 MHz [217] (disabled)
* 7055 MHz [221] (disabled)
* 7075 MHz [225] (disabled)
* 7095 MHz [229] (disabled)
* 7115 MHz [233] (disabled)
Supported commands:
* new_interface
* set_interface
* new_key
* start_ap
* new_station
* new_mpath
* set_mesh_config
* set_bss
* authenticate
* associate
* deauthenticate
* disassociate
* join_ibss
* join_mesh
* remain_on_channel
* set_tx_bitrate_mask
* frame
* frame_wait_cancel
* set_wiphy_netns
* set_channel
* tdls_mgmt
* tdls_oper
* start_sched_scan
* probe_client
* set_noack_map
* register_beacons
* start_p2p_device
* set_mcast_rate
* connect
* disconnect
* channel_switch
* set_qos_map
* set_multicast_to_unicast
* set_sar_specs
WoWLAN support:
* wake up on disconnect
* wake up on magic packet
* wake up on pattern match, up to 1 patterns of 1-128 bytes,
maximum packet offset 0 bytes
* can do GTK rekeying
* wake up on network detection, up to 10 match sets
software interface modes (can always be added):
* AP/VLAN
* monitor
valid interface combinations:
* #{ managed, P2P-client } <= 2, #{ AP, P2P-GO } <= 1,
total <= 2, #channels <= 2
HT Capability overrides:
* MCS: ff ff ff ff ff ff ff ff ff ff
* maximum A-MSDU length
* supported channel width
* short GI for 40 MHz
* max A-MPDU length exponent
* min MPDU start spacing
Device supports TX status socket option.
Device supports HT-IBSS.
Device supports SAE with AUTHENTICATE command
Device supports scan flush.
Device supports per-vif TX power setting
Driver supports full state transitions for AP/GO clients
Driver supports a userspace MPM
Device supports active monitor (which will ACK incoming frames)
Driver/device bandwidth changes during BSS lifetime (AP/GO mode)
Device supports configuring vdev MAC-addr on create.
Device supports randomizing MAC-addr in scans.
Device supports randomizing MAC-addr in sched scans.
max # scan plans: 1
max scan plan interval: 65535
max scan plan iterations: 0
Supported TX frame types:
* IBSS: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* mesh point: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-device: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
Supported RX frame types:
* IBSS: 0x40 0xb0 0xc0 0xd0
* managed: 0x40 0xb0 0xd0
* AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* mesh point: 0xb0 0xc0 0xd0
* P2P-client: 0x40 0xd0
* P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* P2P-device: 0x40 0xd0
Supported extended features:
* [ RRM ]: RRM
* [ SET_SCAN_DWELL ]: scan dwell setting
* [ BEACON_RATE_LEGACY ]: legacy beacon rate setting
* [ BEACON_RATE_HT ]: HT beacon rate setting
* [ BEACON_RATE_VHT ]: VHT beacon rate setting
* [ FILS_STA ]: STA FILS (Fast Initial Link Setup)
* [ CQM_RSSI_LIST ]: multiple CQM_RSSI_THOLD records
* [ CONTROL_PORT_OVER_NL80211 ]: control port over nl80211
* [ ACK_SIGNAL_SUPPORT ]: ack signal level support
* [ TXQS ]: FQ-CoDel-enabled intermediate TXQs
* [ CAN_REPLACE_PTK0 ]: can safely replace PTK 0 when rekeying
* [ AIRTIME_FAIRNESS ]: airtime fairness scheduling
* [ AQL ]: Airtime Queue Limits (AQL)
* [ CONTROL_PORT_NO_PREAUTH ]: disable pre-auth over nl80211 control port support
* [ SCAN_FREQ_KHZ ]: scan on kHz frequency support
* [ CONTROL_PORT_OVER_NL80211_TX_STATUS ]: tx status for nl80211 control port support
* [ BEACON_RATE_HE ]: HE beacon rate support (AP/mesh)
All Current Intel Wifi cards do not support AP/STA modes - just P2P modes - which is what recent versions of nmcli will default to setting up when an intel card is detected.
