I was curious… I know they say no support, but I also know some have successfully used 96GB kits in spite of the stated 64GB limit.
At any rate, I am glad you finally have a working unit! Have you been enjoying it so far?
Thanks, I’m happy with it so far. After upgrading to BIOS 3.03 there are some minor nitpicks still left (idle power use, wifi stability, some irritating but seemingly cosmetic usb error log messages) which I suspect will improve over time, but it is mostly working fine for me.
Batch 9 reporting in, ordered a single stick of 16GB DDR5-5600 RAM. The laptop will not successfully boot, display stays dark. Post code 0x05. I have opened a support ticket, but I am also posting here in case it helps identify a broader issue.
Edit: In my case, channel 0 is not operational. Only channel 1 works.
