After my Gen 11 mainboard died I bought a Mainboard (AMD Ryzen™ AI 300 Series) - Ryzen™ AI 7 350. Most things are working fine. I’m running Debian Testing with
$ uname -a
Linux birke 7.1.4+deb14-amd64 #1 SMP PREEMPT_DYNAMIC Debian 7.1.4-1 (2026-07-19) x86_64 GNU/Linux
I’m typically using hybernate to save battery fully. When using suspend I have problems. When opening the lid for a short moment the system does not take any input. I’m using xfce4 and when xfce4-screensaver was installed the screen just remained black when opening the lid. No keys or mouse click possible. After purging xfce4-screensaver I simply see the screen as it was before closing the lid. No key or touchpad brings back the system. I had to power off. When this happened the first time I tried to ssh into the system and this failed as well.
$ cat /sys/power/mem_sleep
[s2idle]
journalctl -b -1 -k | tail -100
Jul 24 18:52:41 birke kernel: wlp192s0: send auth to dc:39:6f:fd:e4:2d (try 1/3)
Jul 24 18:52:41 birke kernel: wlp192s0: authenticated
Jul 24 18:52:41 birke kernel: wlp192s0: associate with dc:39:6f:fd:e4:2d (try 1/3)
Jul 24 18:52:41 birke kernel: wlp192s0: RX AssocResp from dc:39:6f:fd:e4:2d (capab=0x1431 status=0 aid=2)
Jul 24 18:52:41 birke kernel: wlp192s0: associated
Jul 24 18:52:41 birke kernel: wlp192s0: Limiting TX power to 20 (20 - 0) dBm as advertised by dc:39:6f:fd:e4:2d
Jul 24 20:06:05 birke kernel: ucsi_acpi USBC000:00: unknown error 256
Jul 24 20:06:06 birke kernel: ucsi_acpi USBC000:00: unknown error 0
Jul 24 20:06:06 birke kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-5)
Jul 24 20:41:02 birke kernel: perf: interrupt took too long (3589 > 3505), lowering kernel.perf_event_max_sample_rate to 55500
Jul 24 20:54:26 birke kernel: wlp192s0: disconnect from AP dc:39:6f:fd:e4:2d for new auth to b0:f2:08:6f:50:01
Jul 24 20:54:26 birke kernel: wlp192s0: authenticate with b0:f2:08:6f:50:01 (local address=f4:7b:09:49:66:55)
Jul 24 20:54:26 birke kernel: wlp192s0: send auth to b0:f2:08:6f:50:01 (try 1/3)
Jul 24 20:54:26 birke kernel: wlp192s0: authenticated
Jul 24 20:54:26 birke kernel: wlp192s0: associate with b0:f2:08:6f:50:01 (try 1/3)
Jul 24 20:54:26 birke kernel: wlp192s0: RX ReassocResp from b0:f2:08:6f:50:01 (capab=0x1431 status=0 aid=130)
Jul 24 20:54:26 birke kernel: wlp192s0: associated
Jul 24 20:54:26 birke kernel: wlp192s0: Limiting TX power to 20 (20 - 0) dBm as advertised by b0:f2:08:6f:50:01
Jul 24 20:54:36 birke kernel: wlp192s0: deauthenticating from b0:f2:08:6f:50:01 by local choice (Reason: 3=DEAUTH_LEAVING)
Jul 24 20:54:39 birke kernel: wlp192s0: authenticate with dc:39:6f:fd:e4:2d (local address=f4:7b:09:49:66:55)
Jul 24 20:54:39 birke kernel: wlp192s0: send auth to dc:39:6f:fd:e4:2d (try 1/3)
Jul 24 20:54:39 birke kernel: wlp192s0: send auth to dc:39:6f:fd:e4:2d (try 2/3)
Jul 24 20:54:39 birke kernel: wlp192s0: authenticated
Jul 24 20:54:39 birke kernel: wlp192s0: associate with dc:39:6f:fd:e4:2d (try 1/3)
Jul 24 20:54:39 birke kernel: wlp192s0: RX AssocResp from dc:39:6f:fd:e4:2d (capab=0x1431 status=0 aid=1)
Jul 24 20:54:39 birke kernel: wlp192s0: associated
Jul 24 20:54:39 birke kernel: wlp192s0: Limiting TX power to 20 (20 - 0) dBm as advertised by dc:39:6f:fd:e4:2d
Jul 24 21:30:08 birke kernel: ucsi_acpi USBC000:00: unknown error 256
Jul 24 21:30:08 birke kernel: ucsi_acpi USBC000:00: unknown error 0
Jul 24 21:30:08 birke kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-5)
Jul 24 21:31:17 birke kernel: ucsi_acpi USBC000:00: unknown error 256
Jul 24 21:31:27 birke kernel: ucsi_acpi USBC000:00: unknown error 256
Jul 24 21:31:28 birke kernel: ucsi_acpi USBC000:00: unknown error 0
Jul 24 21:31:28 birke kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-5)
Jul 24 21:31:31 birke kernel: ucsi_acpi USBC000:00: unknown error 256
Jul 24 21:31:31 birke kernel: ucsi_acpi USBC000:00: unknown error 0
Jul 24 21:31:31 birke kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-5)
Jul 24 21:31:50 birke kernel: ucsi_acpi USBC000:00: unknown error 256
Jul 24 21:31:53 birke kernel: ucsi_acpi USBC000:00: unknown error 0
Jul 24 21:31:53 birke kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-5)
Jul 24 21:39:36 birke kernel: ucsi_acpi USBC000:00: unknown error 256
Jul 24 21:39:38 birke kernel: ucsi_acpi USBC000:00: unknown error 0
Jul 24 21:39:38 birke kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-5)
Jul 24 21:59:08 birke kernel: ucsi_acpi USBC000:00: unknown error 256
Jul 24 21:59:08 birke kernel: ucsi_acpi USBC000:00: unknown error 0
Jul 24 21:59:08 birke kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-5)
Jul 24 21:59:38 birke kernel: usb 4-2: new SuperSpeed USB device number 2 using xhci_hcd
Jul 24 21:59:38 birke kernel: usb 4-2: New USB device found, idVendor=32ac, idProduct=0009, bcdDevice= 0.02
Jul 24 21:59:38 birke kernel: usb 4-2: New USB device strings: Mfr=3, Product=4, SerialNumber=2
Jul 24 21:59:38 birke kernel: usb 4-2: Product: SD Expansion Card
Jul 24 21:59:38 birke kernel: usb 4-2: Manufacturer: Framework
Jul 24 21:59:38 birke kernel: usb 4-2: SerialNumber: 000000000002
Jul 24 21:59:38 birke kernel: usb-storage 4-2:1.0: USB Mass Storage device detected
Jul 24 21:59:38 birke kernel: scsi host0: usb-storage 4-2:1.0
Jul 24 21:59:38 birke kernel: usbcore: registered new interface driver usb-storage
Jul 24 21:59:38 birke kernel: usbcore: registered new interface driver uas
Jul 24 21:59:38 birke kernel: ucsi_acpi USBC000:00: unknown error 256
Jul 24 21:59:39 birke kernel: scsi 0:0:0:0: Direct-Access Generic MassStorageClass 0002 PQ: 0 ANSI: 6
Jul 24 21:59:39 birke kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jul 24 21:59:39 birke kernel: ucsi_acpi USBC000:00: unknown error 256
Jul 24 21:59:39 birke kernel: sd 0:0:0:0: [sda] 120649728 512-byte logical blocks: (61.8 GB/57.5 GiB)
Jul 24 21:59:39 birke kernel: sd 0:0:0:0: [sda] Write Protect is off
Jul 24 21:59:39 birke kernel: sd 0:0:0:0: [sda] Mode Sense: 21 00 00 00
Jul 24 21:59:39 birke kernel: sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
Jul 24 21:59:39 birke kernel: sda: sda1
Jul 24 21:59:39 birke kernel: sd 0:0:0:0: [sda] Attached SCSI removable disk
Jul 24 21:59:41 birke kernel: ucsi_acpi USBC000:00: unknown error 256
Jul 24 21:59:47 birke kernel: ucsi_acpi USBC000:00: unknown error 256
Jul 24 21:59:48 birke kernel: ucsi_acpi USBC000:00: unknown error 0
Jul 24 21:59:48 birke kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-5)
Jul 24 22:10:47 birke kernel: usb 4-2: USB disconnect, device number 2
Jul 24 22:10:49 birke kernel: ucsi_acpi USBC000:00: unknown error 256
Jul 24 22:10:49 birke kernel: usb 4-2: new SuperSpeed USB device number 3 using xhci_hcd
Jul 24 22:10:49 birke kernel: usb 4-2: New USB device found, idVendor=32ac, idProduct=0009, bcdDevice= 0.02
Jul 24 22:10:49 birke kernel: usb 4-2: New USB device strings: Mfr=3, Product=4, SerialNumber=2
Jul 24 22:10:49 birke kernel: usb 4-2: Product: SD Expansion Card
Jul 24 22:10:49 birke kernel: usb 4-2: Manufacturer: Framework
Jul 24 22:10:49 birke kernel: usb 4-2: SerialNumber: 000000000002
Jul 24 22:10:49 birke kernel: usb-storage 4-2:1.0: USB Mass Storage device detected
Jul 24 22:10:49 birke kernel: scsi host0: usb-storage 4-2:1.0
Jul 24 22:10:50 birke kernel: scsi 0:0:0:0: Direct-Access Generic MassStorageClass 0002 PQ: 0 ANSI: 6
Jul 24 22:10:50 birke kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jul 24 22:10:50 birke kernel: sd 0:0:0:0: [sda] 120649728 512-byte logical blocks: (61.8 GB/57.5 GiB)
Jul 24 22:10:50 birke kernel: sd 0:0:0:0: [sda] Write Protect is off
Jul 24 22:10:50 birke kernel: sd 0:0:0:0: [sda] Mode Sense: 21 00 00 00
Jul 24 22:10:50 birke kernel: sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
Jul 24 22:10:50 birke kernel: sda: sda1
Jul 24 22:10:50 birke kernel: sd 0:0:0:0: [sda] Attached SCSI removable disk
Jul 24 22:10:56 birke kernel: usb 4-2: USB disconnect, device number 3
Jul 24 23:39:33 birke kernel: wlp192s0: disconnect from AP dc:39:6f:fd:e4:2d for new auth to dc:39:6f:fd:e1:1d
Jul 24 23:39:33 birke kernel: wlp192s0: authenticate with dc:39:6f:fd:e1:1d (local address=f4:7b:09:49:66:55)
Jul 24 23:39:33 birke kernel: wlp192s0: send auth to dc:39:6f:fd:e1:1d (try 1/3)
Jul 24 23:39:33 birke kernel: wlp192s0: authenticated
Jul 24 23:39:33 birke kernel: wlp192s0: associate with dc:39:6f:fd:e1:1d (try 1/3)
Jul 24 23:39:33 birke kernel: wlp192s0: RX ReassocResp from dc:39:6f:fd:e1:1d (capab=0x1431 status=0 aid=1)
Jul 24 23:39:33 birke kernel: wlp192s0: associated
Jul 24 23:39:34 birke kernel: wlp192s0: Limiting TX power to 20 (20 - 0) dBm as advertised by dc:39:6f:fd:e1:1d
Jul 24 23:59:37 birke kernel: ucsi_acpi USBC000:00: unknown error 256
Jul 25 00:02:07 birke kernel: wlp192s0: deauthenticating from dc:39:6f:fd:e1:1d by local choice (Reason: 3=DEAUTH_LEAVING)
Jul 25 00:02:08 birke kernel: PM: suspend entry (s2idle)
Any idea what I can do?
