[solved] Ryzen 7 wakes up after suspending Debian 13, Ryzen AI 300 does not
Debian
Which release version?
13
Which kernel are you using?
6.12.63+deb13-amd64
03.05
AMD Ryzen™ AI 300 Series
We have two Framework laptops in my home. A 16” laptop with a Ryzen 7 7840HS CPU, and a brand new 13” machine with the new AI chip in it.
Both machines run Debian 13. The Ryzen 7 wakes up after suspending it. The AI chip doesn’t.
There are several threads on this forum about Framework laptops not waking up after closing the lid. I have gone through all of them and tried lots of suggestions. Nothing works. It is driving me mad.
Here’s a full overview of the Framework 13 if it helps:
System:
Kernel: 6.12.63+deb13-amd64 arch: x86_64 bits: 64 compiler: gcc v: 14.2.0
Desktop: GNOME v: 48.7 Distro: Debian GNU/Linux 13 (trixie)
Machine:
Type: Laptop System: Framework product: Laptop 13 (AMD Ryzen AI 300 Series)
v: A5 serial:
Mobo: Framework model: FRANMGCP05 v: A5 serial:
UEFI: INSYDE v: 03.05 date: 10/30/2025
Battery:
ID-1: BAT1 charge: 56.0 Wh (89.6%) condition: 62.5/60.7 Wh (103.0%)
volts: 17.2 min: 15.5 model: NVT FRANGWA status: discharging
CPU:
Info: 6-core model: AMD Ryzen AI 5 340 w/ Radeon 840M bits: 64 type: MT MCP
arch: N/A rev: 0 cache: L1: 480 KiB L2: 6 MiB L3: 16 MiB
Speed (MHz): avg: 625 min/max: 599/4148 boost: enabled cores: 1: 625
2: 625 3: 625 4: 625 5: 625 6: 625 7: 625 8: 625 9: 625 10: 625 11: 625
12: 625 bogomips: 47909
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Graphics:
Device-1: Advanced Micro Devices [AMD/ATI] Krackan [Radeon 840M / 860M
Graphics] vendor: Framework driver: amdgpu v: kernel bus-ID: c1:00.0
temp: 30.0 C
Device-2: Framework Laptop Webcam Module (2nd Gen) driver: uvcvideo
type: USB bus-ID: 3-3:2
Display: wayland server: X.Org v: 24.1.6 with: Xwayland v: 24.1.6
compositor: gnome-shell driver: dri: radeonsi gpu: amdgpu
resolution: 3006x2004~60Hz
API: EGL v: 1.5 drivers: kms_swrast,radeonsi,swrast platforms:
active: gbm,wayland,x11,surfaceless,device inactive: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.7-2 glx-v: 1.4
direct-render: yes renderer: AMD Radeon Graphics (radeonsi gfx1152 LLVM
19.1.7 DRM 3.61 6.12.63+deb13-amd64)
Info: Tools: api: eglinfo,glxinfo x11: xdriinfo, xdpyinfo, xprop, xrandr
Audio:
Device-1: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
[Rembrandt/Strix] vendor: Framework driver: snd_hda_intel v: kernel
bus-ID: c1:00.1
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Framework
driver: snd_acp_pci v: kernel bus-ID: c1:00.5
Device-3: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
vendor: Framework driver: snd_hda_intel v: kernel bus-ID: c1:00.6
API: ALSA v: k6.12.63+deb13-amd64 status: kernel-api
Server-1: PipeWire v: 1.4.2 status: active
Network:
Device-1: MEDIATEK MT7925 Wi-Fi 7 160MHz driver: mt7925e v: kernel
bus-ID: c0:00.0
IF: wlp192s0 state: up mac:
Bluetooth:
Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB
bus-ID: 3-5:3
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: bt-v: 5.4
lmp-v: 13
Drives:
Local Storage: total: 931.51 GiB used: 160.7 GiB (17.3%)
ID-1: /dev/nvme0n1 vendor: Crucial model: CT1000P310SSD8 size: 931.51 GiB
temp: 29.9 C
Partition:
ID-1: / size: 899.83 GiB used: 160.69 GiB (17.9%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 974.1 MiB used: 8.8 MiB (0.9%) fs: vfat
dev: /dev/nvme0n1p1
Swap:
ID-1: swap-1 type: partition size: 15.29 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p3
Sensors:
System Temperatures: cpu: 30.8 C mobo: N/A gpu: amdgpu temp: 31.0 C
Fan Speeds (rpm): cpu: 0
Info:
Memory: total: 16 GiB note: est. available: 14.92 GiB used: 1.45 GiB (9.7%)
Processes: 386 Uptime: 1m Init: systemd
Packages: 2350 Compilers: gcc: 14.2.0 Shell: Bash v: 5.2.37 inxi: 3.3.38
Like right away? After some time? When you connect/disconnect the power?
Can you clarify?
The 16 will wake up from ac power connect/disconnect after using certain chargers. It’s been a bug in firmware for a while that framework hasn’t been that interested in fixing.
I’m not complaining about the Ryzen 7. It is behaving fine. It’s the Ryzen AI 300 that is giving me trouble. It just won’t ever wake up from sleep mode, no matter which button I click. I always have to do a hard reboot.
Ha. The latest firmware update fixed the issue!
