AMDGPU crashes with 6.18.13-100.fc42.x86_64
Anyone else with AMD 7040 FW13 and running Fedora 42 and KDE plasma seeing AMD GPU crashes with kernel 6.18.13-100.fc42.x86_64 that weren’t present before? I’ve gotten 2 over the last 3 days whereas before I was mostly stable.
Mar 01 11:36:06 fedora kwin_wayland[2876]: With the output of ‘sudo dmesg’ and ‘journalctl --user-unit plasma-kwin_wayland --boot 0’
Mar 01 11:36:06 fedora kwin_wayland[2876]: Please report this at
Mar 01 11:36:06 fedora kwin_wayland[2876]: The main thread was hanging temporarily!
Mar 01 11:36:06 fedora kwin_wayland[2876]: Pageflip timed out! This is a bug in the amdgpu kernel driver
Mar 01 11:36:06 fedora kernel: amdgpu 0000:c1:00.0: amdgpu: [drm] ERROR [CRTC:80:crtc-0] hw_done or flip_done timed out
Mar 01 11:36:06 fedora kernel: amdgpu 0000:c1:00.0: [drm] ERROR [CRTC:80:crtc-0] flip_done timed out
Mar 01 11:35:56 fedora kernel: amdgpu 0000:c1:00.0: [drm] ERROR dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Mar 01 11:35:55 fedora kernel: amdgpu 0000:c1:00.0: [drm] ERROR dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
I’m adding amdgpu.dcdebugmask=0x10 since searching suggests tons of problems with PSR and AMD GPU, just weird I never needed it before.
I saw this just once, with Arch Linux kernel 6.18.9 a few days ago. Haven’t seen it before or since (now on kernel 6.18.13).
I’m running Cinnamon desktop on Xorg. It seemed like everything froze, and then after a minute things were just unbearably laggy and unresponsive, but I was able to painfully collect logs and reboot.
Kernel logs were just being “spammed” with:
[287894.374215] amdgpu 0000:c1:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
[287894.634890] amdgpu 0000:c1:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
[287895.902596] amdgpu 0000:c1:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
[287896.139358] amdgpu 0000:c1:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
[287896.375798] amdgpu 0000:c1:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
[287896.634629] amdgpu 0000:c1:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
[287897.906065] amdgpu 0000:c1:00.0: [drm] *ERROR* Error queueing DMUB command: status=2
[287897.906069] amdgpu 0000:c1:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
[287898.142376] amdgpu 0000:c1:00.0: [drm] *ERROR* Error queueing DMUB command: status=2
[287898.142378] amdgpu 0000:c1:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
[287898.378850] amdgpu 0000:c1:00.0: [drm] *ERROR* Error queueing DMUB command: status=2
[287898.378851] amdgpu 0000:c1:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
It seems to be rare enough for me that I’m not going to try to prevent it with amdgpu.dcdebugmask
Also noticed it on Fedora Silverblue 43 6.18.13-200.fc43.x86_64 on a FW13 AMD7040, I get similar logs:
Feb 23 19:05:31 ... kernel: amdgpu 0000:c1:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Feb 23 19:05:41 ... kernel: amdgpu 0000:c1:00.0: [drm] *ERROR* [CRTC:80:crtc-0] flip_done timed out
It started happening recently (not having seen this issue before), and even had it happen twice in one evening. There was another thread on the forum with this same error, naming GNOME Night Light feature as known potential cause for the issue. After turning off Night Light, I haven’t seen the crash anymore (anecdotal, but might help others).
I do use kde night color temp change, so that definitely could be a factor.
I haven’t yet seen it happen again since I killed PSR, just kind of weird it crops up now.
Yeah I just had this happened to me, sucks. I’m on kernel 6.18.10-200.fc43.x86_64 running Bluefin (based on Fedora Silverblue).
It happened a two minutes after the night shift ran at 19:12.
Logs:
Mar 20 19:13:14  kernel: amdgpu 0000:c1:00.0: [drm] *ERROR* [CRTC:80:crtc-0] flip_done timed out
Mar 20 19:13:04  kernel: amdgpu 0000:c1:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Mar 20 19:13:03  kernel: amdgpu 0000:c1:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Mar 20 19:13:01  wpa_supplicant[1935]: wlp1s0: Reject scan trigger since one is already pending
Mar 20 19:12:36  systemd[3762]: Started app-flatpak-dev.diegovsky.Riff-3244710604.scope.
Mar 20 19:12:36  dev.diegovsky.Riff.desktop[60602]: [2026-03-21T02:12:36Z ERROR librespot_playback::player] Player::play called from invalid state: Playing { track_id: S>
Mar 20 19:12:36  bluetoothd[1632]: profiles/audio/media.c:parse_int64_metadata() expected DBUS_TYPE_INT64 got DBUS_TYPE_UINT64
Mar 20 19:12:26  org.mozilla.firefox.desktop[64794]: [2] Sandbox: CanCreateUserNamespace() clone() failure: EPERM
Mar 20 19:12:26  systemd[3762]: Started app-flatpak-org.mozilla.firefox-3571081138.scope.
Getting same problem. Running Kubuntu (Ubuntu w/ KDE Plasma) 25.10 on Framework Desktop. System intermittently locks up and requires power down to reboot. Reinstalled Kubuntu on another drive to test. New install seemed stable but has now also locked up once.
System was stable (and great) before this week. I do have a Clonzilla complete image from a couple weeks ago. Have saved all my current development work to an external drive and will try restoring the Clonzilla image if it can’t get this fixed. Reluctant to do this because it will probably take a whole day. Will wait a little while before trying this because there may be a real fix.
Will be really grateful If someone can figure this out. It’s crashing 3 or 4 time a day and it’s interfering with development.
More Info:
When running:
journalctl -b -1 -e
Results include:
Problem with kubuntu crashing :Apr 15 12:28:07 Kubuntu kwin_wayland_wrapper[2518]: kwin_wayland_drm: Pageflip timed out! This is a bug in the amdgpu kernel driver
Apr 15 12:28:07 Kubuntu kwin_wayland_wrapper[2518]: kwin_wayland_drm: Please report this at …
Apr 15 12:28:07 Kubuntu kwin_wayland_wrapper[2518]: kwin_wayland_drm: With the output of ‘sudo dmesg’ and ‘journalctl --user-unit plasma-kwin_wayland --boot 0’
Do we need an update to the amdgpu kernal driver?
Is the problem restricted to KDE Plasma?
My second install of Kubuntu is not using the night light feature but has experienced the same bug.
Been running Chrome but will experiment with just using Firefox.
Tried amdgpu.dcdebugmask=0x10 but problem still there.
Intermittent problems are hard to diagnose (and fix). Wish everyone good luck.
Have really liked Kubuntu on Framework Desktop but does anyone have any recommendations for alternatives? Using JetBrains Rider to do C# development in Genetic Programming and generative art. :cowboy_hat_face: :victory_hand:
I believe the problem is caused by an interaction between KDE, AMDGPU drivers and chromium based web browsers. I have switch to using Firefox and have had no problems. Still running KDE (Fedora 43 KDE) and stil running on Framework Desktop.
