Amdgpu kernel panics / display crashes
I don’t know if I am the only one, but I am having a lot of trouble with the GPU in the desktop when running Fedora with the current kernel (6.16.5).
Under wayland, when any video was playing I frequently hit this what appears to be an issue with Chrome, Wayland, and amdgpu:
which I think is probably the same as these:
https://gitlab.freedesktop.org/drm/amd/-/issues/4499 / Making sure you're not a bot!
At least all the errors look very similar. Workarounds seem to be don’t use hardware acceleration in Chrome or switch to X11. Without hardware acceleration video seemed a little laggy, so with kde I installed kwin-x11 and plasma-workspace-x11 and am using x11 for now. I haven’t seen anymore of these crashes.
Another one I am seeing looks a lot like what is described in this lkml thread. I don’t think other than the proposed increase in timeout there is any workaround or fix. I am seeing this both with wayland and x11. For now I’ve rebuilt the kernel with the timeout increase and I guess I’ll see what happens.
Anyway, I thought I’d share in case others are seeing anything like these and need a workaround or have some better ideas.
I suggest you update your GPU firmware to latest upstream GPU firmware. Fedora current snapshot is right before some Strix Halo fixes went in.
If that doesn’t help I think we need a bug report with specific logs to triage.
Thanks for the suggestion. I have updated the firmware and will open bug reports if problems persist.
I would also be getting AMD timeouts and game crashes on Windows if I was to install AMD Adrenalin directly from AMD. Was able to resolve it by using AMD cleanup tool and using the framework desktop driver bundle. Both have the same version 25.9.1, but with the AMD tool included the installer manager and caused many of my games to crash or stutter very drastically and also pop-up the ‘amd driver timeout’ window right in front of my game that’s still playing.
Errors like these.
Fault bucket LKD_0x141_Tdr:6_IMAGE_amdkmdag.sys-HWS:1-GRE=c860, type 0
Event Name: LiveKernelEvent
Response: Not available
Cab Id: 2df21e5e-c72e-4c13-8041-71fddea1a691
Fault bucket LKD_0xA2000002_amdfendr!unknown_function, type 0
Cab Id: 8e9d34ca-2da3-4c68-9a04-a89677d4f495
Fault bucket 2228745037158999057, type 5
Event Name: BEX64
Cab Id: 0
Faulting application name: SteelSeriesCaptureSvc.exe, version: 1.0.0.1, time stamp: 0x686fd4f1
Faulting module name: SteelSeriesCaptureSvc.exe, version: 1.0.0.1, time stamp: 0x686fd4f1
Exception code: 0xc0000409
Fault offset: 0x000000000003b101
Faulting process id: 0x1DFC
Faulting application start time: 0x1DC2ACE1AE30B0E
Faulting application path: C:\Program Files\SteelSeries\GG\apps\moments\SteelSeriesCaptureSvc.exe
Faulting module path: C:\Program Files\SteelSeries\GG\apps\moments\SteelSeriesCaptureSvc.exe
Faulting application name: logioptionsplus_agent.exe, version: 1.95.1519.0, time stamp: 0x68bb7a36
Faulting module name: AMDXN64.DLL, version: 32.0.21025.10016, time stamp: 0x68a80934
Fault offset: 0x0000000000d49031
Faulting process id: 0x1C60
Faulting application start time: 0x1DC2AC54E33B853
Faulting application path: C:\Program Files\LogiOptionsPlus\logioptionsplus_agent.exe
Faulting module path: C:\WINDOWS\System32\DriverStore\FileRepository\u0418637.inf_amd64_4462a7afa694670e\B418564\AMDXN64.DLL
Event Name: BEX64
Cab Id: 0
Fault bucket 1979808285661430185, type 5
Event Name: RADAR_PRE_LEAK_64
Cab Id: 0
Fault bucket , type 0
Cab Id: 0
Problem signature:
P1: a1000005
P2: 0
P3: 0
Fault bucket LKD_0xA1000005_amdfendr!unknown_function, type 0
Cab Id: 0da62f76-bc38-430d-aedb-dccf30f1a848
Problem signature:
P1: a1000005
P2: 0
I didn’t have these issues at first right out of the box since I just decided to directly install windows fresh, windows updates, and then the framework desktop driver bundle. I must have randomly decided to download the AMD exe to update the drivers and see if there’s any newer updates available. Then to suddenly start stuttering in games and having driver timeouts. Resorted to just using AMD cleanup, and re-do the framework driver bundle and hadn’t had these errors since and had smooth game play again.
Just providing this info for any Windows users and to probably populate some google search results, was struggling and thinking something went wrong hardware wise. Linux however, seems to be stuck making sure you just get the latest distro and kernel updates.
