Anker 727 charging issue
Hi all,
I know there’s been some finicky interactions between the FW13 and some Anker charging stations, and oddly enough it seems to have finally bit me too. For about a year I reliably charged my 13 using my Anker 727 device with no issues, but over the past few days it’s stopped working. When I plug in the USB-C to USB-C connector the side LED will flash amber for a second then cut off. I know it’s not just one side because the same happens on the other (I have a USB-C card in the upper left and upper right slots). Charging with my Monoprice wall wart and USB-C works, as does charging my cell phone on the Anker using the same port and cable that used to work on my FW.
Has anyone else had this issue?
For context I’m currently running off of BIOS 3.09 and Linux Mint 22.1 OS. Mainboard is an AMD Ryzen 7840U with 61wh battery.
Okay, looks like the issue might be with a bad outlet, not the computer or charger. Closing this one!
