Framework Laptop 13 (AMD Ryzen AI 300 Series) not charging with some chargers
My new Framework Laptop 13 (AMD Ryzen AI 300 Series) appears to have some issues with some chargers. Specifically, it will not charge with my Anker 747 chargers. I have a few of these chargers and I’ve tested with all of the chargers (in each of the sockets in the chargers and each of the expansion card slots on the laptop) and each time I test, the same thing happens – the charging light beside the expansion card slot on the laptop flashes for a split second, and then turns off and remains off and no charging occurs (the computer does not report charging and will discharge over time).
This sounds similar to AMD Framework USB-C charger compatibility issues; however I think this is not the same issue for a few reasons:
  1. That ticket appears to be for the 7040 series, not the AI 300 series, based on when the ticket was created
  2. I’m assuming that ticket is resolved given no one has said anything in the thread since January
  3. Someone explicitly mentioned the Anker 747 working in that thread
I don’t really have any good ideas for how I can debug this issue. For what it’s worth, I am running linux (NixOS specifically) but I don’t think that’s relevant given the computer won’t charge from those chargers when it’s turned off either.
Any ideas?
Im having the same issue. Im using a slightly older 737 charger that ive had for a while with a pair of anker 100w cables. never had any issues before charging even past 60w on other devices. This laptop is a little over a day old, and i noticed the charging issue an hour into using Fedora for the first time. I dont know what to do, it would seem there arent any bios updates past 3.03 for this mobo.
some people have said it should charge even when fully off, but for me it still charges when it decides it wants to (usually some time after 30 or so minutes)
I can just barely live with this.
so many people with this issue specifically say anker, so I wanted to try other chargers but people say it happens even with the official FW charger too.
I am also having the same issue and I use an Anker Gan charger and am running windows 11. I submitted a ticket and I will respond when and if the problem is resolved and if you guys find anything out please let me know as well. Best of luck.
Thank you for reminding me i replied in this thread. I have an update. i had been browsing a few days ago On the main thread for charging issues
I could not find the message, but I saw EPR and PD 3.1 mentioned as “preffered” by the chipset somewhere. My 737 is neither of those, although it does put out enough power.
I confirmed that the issues went away when testing a few chargers that are rated as EPR, and now i have ordered one which makes 3 chargers tested and confirmed problem free.
If you have a usb c macbook charger, some of those might work.
I am using an Anker 747 Gan charger that I do not belive is PD 3.1 or EPR so I will attempt to use a MacBook charger thank you.
Update: Well apparently my 747 charger should be PD 3.1 as what Anker advertises as PowerIQ4 should be essentially PD 3.1. As for EPR I have no idea. But this is confusing as my issue has started recently although I’ve been using the same charging bricks for weeks now with no issue.
ah, that is strange. Check to see if you have EPR on that charger, I found that most PD 3.1 chargers had EPR included when i was shopping for one recently.
My charging issues happened only a few hours after setup. I dont remember if my 737 was fully operational during that time. That is interesting that you were using the same bricks for weeks without any issues.
I get the same behavior from the 737 and 747 chargers, but can charge fine with an older 65W 515 charger and a PowerCore+ 26800 battery bank. The newer Prime 27650 battery bank also works. I’m hoping this will get resolved as I have a handful of these chargers and this will become show stopper in terms of keeping this laptop.
Can confirm the issue with Anker 737 and Laptop 13 AI 300 series.
Same charger no issue with Lenovo and HP machines.
Another not “fully baked” Framework feature?
Hello, I have the Ryzen Ai 9 HX370 and I’m running into similar charging issues. It started with a 60w PowerAdd charging brick I got in 2021. Back on the 11th Gen intel board I used to have some issues with the charger where it wouldn’t charge the first time I plugged it in. Replugging it in would fix it. With the new mainboard, I had a different behavior where it would switch between charging and not charging non-stop. I didn’t think much of it and thought the laptop was just more sensitive when it came to cheap chargers.
More recently, I tried using my Jackery Explorer 100 Plus, which is a somewhat big LifePO4 battery bank with a screen that indicates charging speeds. I plugged it in, and the same thing happened. This time, I could see it was switching between 8-9watts to 97watts. Reconnecting the cable doesn’t fix it. I restarted the PC and noticed that it was steadily charging at around ~50watts during boot. It went up to 90watts and once Windows loaded, the issue came back. If I shut down the computer and let it charge for a little, then power it on, it will charge properly even when Windows is loaded. If I unplug it and plug it back in, the issue comes back. It’s very odd. I also tested with an Anker PowerCore III battery bank (60w, also from 2021) and it works fine.
I think this could be a firmware or software issue that could be resolved since it charges fine when powered off. Any suggestions to fix it is welcome, otherwise, I can’t do much beside wait for a fix or contact support.
I’m using an Anker PowerPort III. It worked fine at first, but now my laptop refuses to charge at all.
FYI, my issue was resolved with the 3.04 BIOS update.
