Are Frameworks affected by SinkClose flaw?
I have a Framework 16. Is it (or the AMD Framework 13) affected by the security flaw known as SinkClose?
https://www.bleepingcomputer.com/news/security/new-amd-sinkclose-flaw-helps-install-nearly-undetectable-malware/
Hugh
The CPUs are impacted by the issue.
AMD says the issue is fixed in Platform Initialization (PI) version 1.1.0.3, however the release notes for the latest release firmware for the Framework Laptop 16 (and the Framework Laptop 13) state that it includes PI version 1.1.0.2a and the release notes for the beta firmware do not specify the PI version (which I assume means that it wasn’t changed).
So it is affected, however given that AMD has released the fix I expect Framework’s next update should include the fix.
Affected product list:
https://www.amd.com/en/resources/product-security/bulletin/amd-sb-7014.html
