Audio combo port mode settings
On Windows I used the realtek app to set whether the combo audio port had a headset, headphones or a microphone plugged into it. Where is this on Linux?
Some of the configurations I want:
Microphone in the combo input and the internal speakers output.
Builtin microphone input and headphone output.
Headset in and out (already works).
Builtin microphone input and internal speakers output (already works).
Which Linux distro are you using? Bazzite
Which release version? 43.20251114.0
Which kernel are you using? 6.17.7-ba10.fc43.x86_64
Which BIOS version are you using? 3.24
Which Framework Laptop 13 model are you using? 11th Gen Intel® Core™
