On my 13 inch laptops, the audio port is built into the chassis. I just placed my preorder for the 16 inch version and I noticed that there is an audio plug-in module. Does this mean there is no audio connector in the chassis? If so it would also mean that this new computer only has one additional module port instead of two
Does the modular audio plug offer anything that the built-in audio plug on the 13 does not offer ?
Correct.
It gives better audio.
Framework | Audio Expansion Card
This Expansion Card provides increased dynamic range and improved signal to noise ratio in comparison to the Framework Laptop 13 built-in audio jack.
Thanks … I was happy with the built in audio jack. Too bad that I now have to use one of the side slots for the new audio module.
I initially felt the same way, but i think modularity is really better in the long run.
Realistically most people have some sort of bluetooth headset anyways. 6 (or 5 minus the audio port) still gives you plenty of options, even more than many other laptops out there. And if you really really need more, USB-C always allows for easy “expansion” via dongles and docks, just like on every other device.
So all in all Framework’s approach is always at least equal to 90% of the other manufacturers and often even better, so in my book that’s a win
You make some great points - I am a bit behind times and had forgotten all about bluetooth headsets and yes, a USB-C add-on box is a viable alternative.
Thanks!
