Howdy Folks! Been looking to create a NAS using my 1135g7 board and Im wondering if anyone has found any use for the battery connector. Im looking for an adapter to use the battery connector as a USB-C PD port, this would be used to power the machine without using the main USB-C ports on the mainboard. As well as my use case, im sure many people would appreciate freeing up a Expansion card slot on their Mini-Pc. Could anybody help me with Prototyping one of these. Id love for it to input and output power using the 10 pin power connector.
Based on the GitHub The connector is an ACES 50459-010H0M0-001
After reading through WAY too many ACES connectors to triple check, it mates with an 50459-xxxHxMx-002 housing. in order to make this adapter, all I have to do is terminate the correct wires for a female USB-C PD port. If there’s anything wrong with this let me know.
Alternatively, i believe it could be possible to terminate it to a 4 pin pcie/CPU connector such as these for small form factor cases using a desktop power supply.
