Bios Battery charging limit ignored
Hey,
my battery always charges up to 100% and my bios setting with 80% charging limit is ignored. Someone else have this issues?
Regards
Can’t help, but you should provide the BIOS version you’re running :slight_smile:
Update to the latest version: Framework Laptop 13 Ryzen 7040 BIOS 3.09 Release
Disable the battery extender in the bios.
Power off laptop (not suspend).
Wait 2 mins. And power on.
This resets the EC.
If you wish to use the battery limit of 80%, you don’t need the battery extender function as that is for protecting a 100% charged battery.
Its the new Ryzen 9 HX 370
Sorry there is only the release bios for the Ryzen AI yet
Sorry maybe thats got lost, I don’t talk about battery extender, I talk about charging limit
Currently that’s my configuration
I had it setup exactly like that for my old 7040 Mainboard and thwt configuration never charged more then 80%
And battery extender can mess with the charge limit (or at least id did on the 7x40u).
Ok, that is good that you have “Battery Extender” disabled.
The EC code has some bugs in it, that under some situations, it escapes its 80% limit.
When that happens, you can discharge it back to below 80% and it probably will not hit the edge case again for a while.
In any case, going through the EC reset I described should help.
I have written my own bug fixes to the EC code, but it only works on FW13 AMD 7840U, 7640U and FW16 AMD 7840HS. So, they won’t work on your AI 370.
It’s a known issue as described here : F13 AMD AI 300 - Battery charge limit ignored on subsequent boots · Issue #67 · FrameworkComputer/SoftwareFirmwareIssueTracker · GitHub
framework released a laptop with a buggy bios. We have to wait for them to merge the fix from 7040.
The only bios available for AI 300 now is the 0.3.3 which is can not be suitable for production systems.
Okay I did the following, restart into bios, set charging limit to 100, powered down for 10 minutes, now I booted the machine, set charging limit to 80, now I booted up the os and will wait for the battery to drain under 80
My pre-built 370 exhibits consistent behavior: Battery limit set to 80%. When shutdown and charger cable is plugged in, it will exceed 80%. When running W11 and the charger cable is plugged in, it will maintain 80% charge, running or sleeping (lid shut).I haven’t tried hibernate.
Looks like a bug in the firmware with my 7840u Board I never had this issues…
Thanks for catching the LVFS record, a touch concerned by it…
I’m facing the exact same issue on my HX 370.
Setting charge limit using @DHowett’s ectool at system boot is my current workaround:
sudo ectool chargecontrol normal 80 80
I am also on the new Framework Laptop 13 (AMD Ryzen AI 300 Series)/FRANMGCP09, BIOS 03.04 06/10/2025 and Omarchy Arch Linux version 6.16.3-arch1-1.
So, it used to work very well and the battery limit was respected (even with Extender enabled). Yet, since some time, I realized it does not work anymore and it charges to 100%.
I followed the steps to reset EC and after waiting 2 mins it seems to pick it up initially, i.e. after 2 mins before tuning the laptop on I plug in the adapter and I see the LED changing color from orange to white - which used to be the case when the battery reached the limit set in BIOS. But then, when I turn the laptop on, soon after typing the password to decrypt the SSD, the LED changes to orange again and then it stays like this, until I reset the EC again by powering off, disconnecting the adapter and waiting 2mins. But then the process repeats. So I am wondering if this is still problem of BIOS or there is something with my (Omarchy) Arch Linux…
Omarchy uses power-profiles-daemon, and i do not see anything strange there… At least I did not see any conflicts before…
dmsg only gives me this when searching for battery:
``bash
❯ sudo dmesg -T | grep ‘battery’
[Thu Aug 28 04:11:54 2025] ACPI: battery: Slot [BAT1] (battery present)
[Thu Aug 28 04:12:18 2025] ACPI: battery: new hook: cros-charge-control.6.auto
Thanks for any feedback…
I found the problem.
With recent kernel cros_charge_control seem to be functioning (which means btw that it should be possible to use tlp to control the battery). But even if you do not, the BIOS settings on new FW13 with AI 9 HX 370 to limit charge level will not be respected because they will be conflicting with cros_charge_control. I found it by tracking down the boot logs. At some point I saw this:
journalctl -b -13 | grep battery
Aug 23 02:41:09 f13-ep-0 kernel: ACPI: battery: Slot [BAT1] (battery present)
Aug 23 02:41:09 f13-ep-0 kernel: ACPI: battery: new hook: cros-charge-control.6.auto
And then the threshold files finally appear:
lsmod | grep cros
leds_cros_ec           12288  0
gpio_cros_ec           12288  0
led_class_multicolor    16384  1 leds_cros_ec
cros_kbd_led_backlight    12288  0
cros_ec_sysfs          16384  0
cros_charge_control    16384  0
cros_ec_debugfs        20480  0
cros_ec_chardev        16384  0
cros_ec_hwmon          12288  0
cros_ec_dev            20480  0
cros_ec_lpcs           28672  0
cros_ec                20480  1 cros_ec_lpcs
cros_ec_proto          61440  11 leds_cros_ec,cros_ec_lpcs,cros_kbd_led_backlight,cros_ec,gpio_cros_ec,cros_ec_dev,cros_ec_debugfs,cros_ec_hwmon,cros_ec_sysfs,cros_ec_chardev,cros_charge_control
❯ cat /sys/class/power_supply/BAT1/uevent | grep CHARGE
POWER_SUPPLY_CHARGE_FULL_DESIGN=3915000
POWER_SUPPLY_CHARGE_FULL=4014000
POWER_SUPPLY_CHARGE_NOW=2778000
POWER_SUPPLY_CHARGE_CONTROL_START_THRESHOLD=0
POWER_SUPPLY_CHARGE_CONTROL_END_THRESHOLD=100
POWER_SUPPLY_CHARGE_BEHAVIOUR=auto
To get the BIOS working correctly you need to blacklist:
$ cat /etc/modprobe.d/blacklist-cros.conf
blacklist cros_charge_control
$ sudo mkinitcpio -P
This will remove the conflict and let the BIOS control the charging.
