Which model and version of BIOS is installed in the PC ?
Is the BIOS upgradable ?
Is wake on lan available if ethernet expansion is inserted ?
If there is a BIOS password, it is possible to reset it (or reset the BIOS) ?
Thanks
Thanks
I’m also curious as to what BIOS software is installed.
If you do a search there are a few topics covering some aspects of BIOS:
Here’s an example:
http://community.frame.work/t/free-the-ec-and-coreboot-only
