nixos-unstable
Which release version?
Updated yesterday, reverted flake.lock to pre-update, still borked.
Which kernel are you using?
7.0.8
0.0.3.6, I ran an update from 3.5 to 3.6 after noticing this problem but before reverting my flake.lock.
Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series)
Ryzen 300
I’ve been following this guide from the knowledge-base: Ubuntu Bluetooth Troubleshooting Guide
Running sudo hciconfig hci0 up results in the following error:
Can’t init device hci0: Invalid argument (22)
From what I can tell this might be a kernel issue of some sort? Any information or assistance here would be greatly appreciated.
James3
May 17, 2026, 11:03am
2
Try an older kernel, say 7.0.6 or before to see if that helps.
If it helps, at least one then knows it it a kernel bug.
It is a kernel bug try using 6.6 or stable branch with 7.0.3 or 7.0.6 it works i tried it out.
You can make this change in your config while waiting for the patch to come out:
let
linux_7_0_6 = pkgs.linux_7_0.override {
argsOverride = rec {
version = "7.0.6";
modDirVersion = version;
src = pkgs.fetchurl {
url = "mirror://kernel/linux/kernel/v7.x/linux-${version}.tar.xz";
hash = "sha256-y6REQKpXr/18ISQdxbwjSw31PEmfj/w+vCkN0zkKdSM=";
in
{boot.kernelPackages = pkgs.linuxPackagesFor linux_7_0_6;
# rest of the conf
# also don't forget to comment your current kernel
and when the patch comes out just comment this out and try the new kernel to see if it works
A lot of security bug fixes went into 7.0.7 related to bluetooth. So my guess it is accidentally broke something.
A patch is here:
It works for me. It is not great bug fix, as it just opens the security hole again.
Essentially, the mediatek bluetooth firmware is buggy.
diff --git a/drivers/bluetooth/btmtk.c b/drivers/bluetooth/btmtk.c
index 31ff133b6159..6a9020b2b249 100644
--- a/drivers/bluetooth/btmtk.c
+++ b/drivers/bluetooth/btmtk.c
@@ -678,8 +678,10 @@ static int btmtk_usb_hci_wmt_sync(struct hci_dev *hdev,
case BTMTK_WMT_FUNC_CTRL:
if (!skb_pull_data(data->evt_skb,
sizeof(wmt_evt_funcc->status))) {
- err = -EINVAL;
- goto err_free_skb;
+ //err = -EINVAL;
+ //goto err_free_skb;
+ status = BTMTK_WMT_ON_UNDONE;
+ break;
wmt_evt_funcc = (struct btmtk_hci_wmt_evt_funcc *)wmt_evt;
Thanks for the derivation, works like a charm!
The patch (seems to be originally from this linux-bluetooth thread ) seems to be maintaining the security aspect of original security-but-buggy-device-firmware-breaking fix .
Am I interpreting this right - keeping the delegation of reading the data to skb_pull_data, instead of the old naive pointer cast, keeps the OOB read from happening despite the new return logic?
The bluetooth fix is in Linux kernel 7.0.10.
