Hi @David_Mischel, would wifi tethering work for you? I use it with my phone providing the hotspot all the time. The computer connects to the wifi hotspot that the phone is providing, and uses the phone’s cellular data connection.
What type of phone (android/iPhone) are you using and what OS on the laptop?
Update - I just tested and was able to tether via bluetooth. I had to enable it on my phone (android), then use the gsconnect (or kdeconnect, depending) extension on my linux (manjaro) laptop to tether to the phone. Posting this through that connection.
I don’t know about wifi tethering but it sounds like that is a preferred wireless solution. My phone OS is Android. My laptop is dual boot: windows11 and Kubuntu.
Due to timing of my day (traveling in UK and i have an appointment before 6; it’s 1715 now) i can’t try this until tomorrow. I will test then.
