Boot and performance issues - possibly related to kernel Linux 6.10.9-200.fc40.x86_64
As of this morning (15/09/24) I am seeing an unusual screen when I start up my Framework 13 (12th gen, Fedora 40). After the startup Framework logo appears the screen shows a grey screen with three square dots in the top left corner. This screen displays for a few seconds, then the startup process resumes. However this problem has coincided with the operating system working very slowly once it has got to the desktop and from that point on.
I have checked System Monitor and I can’t see any unexpected processes running. Core temperatures are all fine. It all looks normal, but everything is very slow to happen.
Any ideas what is going on? Fedora is up to date, there is no pending software to install.
Update: I have found a post that shows the same boot screen I am seeing on my Framework 13 here: Plymouth boot screen with three dots - Fedora Discussion
Obviously it’s nothing to do with a graphics card because my laptop doesn’t have one, but this suggests the problem is related to the kernel. My laptop is running Linux 6.10.9-200.fc40.x86_64.
Is there a (simple) way to test this hypothesis?
You might need to describe what you mean by slowly. Do you see anything in the system logs? Have you tried the previous kernel? If you start a f40 live cd does it have the same issue?
Propably relates to this:
Although this is related to AMD but the symptoms seem to be similar
It’s a strange slowness. For instance when I activate the Activities Overview there is a 1-2 second wait before anything happens. Previously it has been instantaneous. Dragging windows around the desktop causes significant stutters, which has never happened before. It seems like a graphics issue to me. But it also appears to be causing web pages to load very slowly too, which I don’t think is a graphics thing.
I don’t know how to try the previous kernel. It seems like a good idea, if that is possible.
The log looks like this:
16:52:17 reporter-system: Process 6513 (bijiben-shell-search-provider) crashed in g_type_check_instance_is_fundamentally_a()
16:52:12 systemd-coredum: Process 12551 (bijiben-shell-s) of user 1000 dumped core.
Module libcamelimapx.so from rpm evolution-data-server-3.52.4-1.fc40.x86_64
Module libcamelpop3.so from rpm evolution-data-server-3.52.4-1.fc40.x86_64
Module libcamelsmtp.so from rpm evolution-data-server-3.52.4-1.fc40.x86_64
Module libcamellocal.so from rpm evolution-data-server-3.52.4-1.fc40.x86_64
Module libcamelnntp.so from rpm evolution-data-server-3.52.4-1.fc40.x86_64
Module libcamelsendmail.so from rpm evolution-data-server-3.52.4-1.fc40.x86_64
Module libstemmer.so.0 from rpm snowball-2.2.0-10.fc40.x86_64
Module libtracker-parser-libicu.so from rpm tracker-3.7.3-1.fc40.x86_64
Module libgvfscommon.so from rpm gvfs-1.54.2-1.fc40.x86_64
Module libgvfsdbus.so from rpm gvfs-1.54.2-1.fc40.x86_64
Module libdconfsettings.so from rpm dconf-0.40.0-12.fc40.x86_64
Module libvmaf.so.1 from rpm vmaf-2.3.0-7.fc40.x86_64
Module libudev.so.1 from rpm systemd-255.12-1.fc40.x86_64
Module libGLdispatch.so.0 from rpm libglvnd-1.7.0-4.fc40.x86_64
Module libelf.so.1 from rpm elfutils-0.191-4.fc40.x86_64
Module libcrypt.so.2 from rpm libxcrypt-4.4.36-5.fc40.x86_64
Module libgmp.so.10 from rpm gmp-6.2.1-8.fc40.x86_64
Module libhogweed.so.6 from rpm nettle-3.9.1-6.fc40.x86_64
Module libnettle.so.8 from rpm nettle-3.9.1-6.fc40.x86_64
Module libp11-kit.so.0 from rpm p11-kit-0.25.5-1.fc40.x86_64
Module libplds4.so from rpm nss-3.103.0-1.fc40.x86_64
Module libplc4.so from rpm nss-3.103.0-1.fc40.x86_64
Module libxcb-randr.so.0 from rpm libxcb-1.17.0-1.fc40.x86_64
Module libexpat.so.1 from rpm expat-2.6.3-1.fc40.x86_64
Module libevdev.so.2 from rpm libevdev-1.13.3-1.fc40.x86_64
Module libaom.so.3 from rpm aom-3.9.0-1.fc40.x86_64
Module libSvtAv1Enc.so.2 from rpm svt-av1-2.1.0-1.fc40.x86_64
Module librav1e.so.0 from rpm rust-rav1e-0.7.1-2.fc40.x86_64
Module libdav1d.so.7 from rpm dav1d-1.4.3-1.fc40.x86_64
Module libbrotlienc.so.1 from rpm brotli-1.1.0-3.fc40.x86_64
Module libsharpyuv.so.0 from rpm libwebp-1.3.2-5.fc40.x86_64
Module libgudev-1.0.so.0 from rpm libgudev-238-5.fc40.x86_64
Module libX11-xcb.so.1 from rpm libX11-1.8.10-2.fc40.x86_64
Module libGLX.so.0 from rpm libglvnd-1.7.0-4.fc40.x86_64
Module libEGL.so.1 from rpm libglvnd-1.7.0-4.fc40.x86_64
Module liborc-0.4.so.0 from rpm orc-0.4.39-1.fc40.x86_64
Module libdw.so.1 from rpm elfutils-0.191-4.fc40.x86_64
Module libunwind.so.8 from rpm libunwind-1.8.0-3.fc40.x86_64
Module libgpg-error.so.0 from rpm libgpg-error-1.49-1.fc40.x86_64
Module libwoff2common.so.1.0.2 from rpm woff2-1.0.2-19.fc40.x86_64
Module libzstd.so.1 from rpm zstd-1.5.6-1.fc40.x86_64
Module liblz4.so.1 from rpm lz4-1.9.4-6.fc40.x86_64
Module libcap.so.2 from rpm libcap-2.69-8.fc40.x86_64
Module libbrotlicommon.so.1 from rpm brotli-1.1.0-3.fc40.x86_64
Module libsasl2.so.3 from rpm cyrus-sasl-2.1.28-19.fc40.x86_64
Module libevent-2.1.so.7 from rpm libevent-2.1.12-12.fc40.x86_64
Module libkeyutils.so.1 from rpm keyutils-1.6.3-3.fc40.x86_64
Module libkrb5support.so.0 from rpm krb5-1.21.3-1.fc40.x86_64
Module libcom_err.so.2 from rpm e2fsprogs-1.47.0-5.fc40.x86_64
Module libk5crypto.so.3 from rpm krb5-1.21.3-1.fc40.x86_64
Module libkrb5.so.3 from rpm krb5-1.21.3-1.fc40.x86_64
Module libunistring.so.5 from rpm libunistring-1.1-7.fc40.x86_64
Module libicudata.so.74 from rpm icu-74.2-1.fc40.x86_64
Module libgnutls.so.30 from rpm gnutls-3.8.6-1.fc40.x86_64
Module libnspr4.so from rpm nss-3.103.0-1.fc40.x86_64
Module libXau.so.6 from rpm libXau-1.0.11-6.fc40.x86_64
Module libbz2.so.1 from rpm bzip2-1.0.8-18.fc40.x86_64
Module libdatrie.so.1 from rpm libdatrie-0.2.13-9.fc40.x86_64
Module libdbus-1.so.3 from rpm dbus-1.14.10-3.fc40.x86_64
Module libatspi.so.0 from rpm at-spi2-core-2.52.0-1.fc40.x86_64
Module libgraphite2.so.3 from rpm graphite2-1.3.14-15.fc40.x86_64
Module libblkid.so.1 from rpm util-linux-2.40.1-1.fc40.x86_64
Module libdrm.so.2 from rpm libdrm-2.4.123-1.fc40.x86_64
Module libgbm.so.1 from rpm mesa-24.1.7-1.fc40.x86_64
Module libseccomp.so.2 from rpm libseccomp-2.5.5-1.fc40.x86_64
Module libmanette-0.2.so.0 from rpm libmanette-0.2.7-1.fc40.x86_64
Module libwayland-server.so.0 from rpm wayland-1.23.0-2.fc40.x86_64
Module libtasn1.so.6 from rpm libtasn1-4.19.0-6.fc40.x86_64
Module libenchant-2.so.2 from rpm enchant2-2.6.9-1.fc40.x86_64
Module libavif.so.16 from rpm libavif-1.0.4-3.fc40.x86_64
Module libjxl.so.0.8 from rpm jpegxl-0.8.3-1.fc40.x86_64
Module libwebp.so.7 from rpm libwebp-1.3.2-5.fc40.x86_64
Module libwebpdemux.so.2 from rpm libwebp-1.3.2-5.fc40.x86_64
Module libjpeg.so.62 from rpm libjpeg-turbo-3.0.2-1.fc40.x86_64
Module libgstfft-1.0.so.0 from rpm gstreamer1-plugins-base-1.24.7-1.fc40.x86_64
Module libgstgl-1.0.so.0 from rpm gstreamer1-plugins-base-1.24.7-1.fc40.x86_64
Module libgstvideo-1.0.so.0 from rpm gstreamer1-plugins-base-1.24.7-1.fc40.x86_64
Module libgsttag-1.0.so.0 from rpm gstreamer1-plugins-base-1.24.7-1.fc40.x86_64
Module libgsttranscoder-1.0.so.0 from rpm gstreamer1-plugins-bad-free-1.24.7-1.fc40.x86_64
Module libgstaudio-1.0.so.0 from rpm gstreamer1-plugins-base-1.24.7-1.fc40.x86_64
Module libgstpbutils-1.0.so.0 from rpm gstreamer1-plugins-base-1.24.7-1.fc40.x86_64
Module libgstreamer-1.0.so.0 from rpm gstreamer1-1.24.7-1.fc40.x86_64
Module libgstbase-1.0.so.0 from rpm gstreamer1-1.24.7-1.fc40.x86_64
Module libgstapp-1.0.so.0 from rpm gstreamer1-plugins-base-1.24.7-1.fc40.x86_64
Module libgstallocators-1.0.so.0 from rpm gstreamer1-plugins-base-1.24.7-1.fc40.x86_64
Module libharfbuzz-icu.so.0 from rpm harfbuzz-8.5.0-1.fc40.x86_64
Module libwoff2dec.so.1.0.2 from rpm woff2-1.0.2-19.fc40.x86_64
Module liblcms2.so.2 from rpm lcms2-2.16-3.fc40.x86_64
Module libxslt.so.1 from rpm libxslt-1.1.42-1.fc40.x86_64
Module libsystemd.so.0 from rpm systemd-255.12-1.fc40.x86_64
Module libbrotlidec.so.1 from rpm brotli-1.1.0-3.fc40.x86_64
Module libgssapi_krb5.so.2 from rpm krb5-1.21.3-1.fc40.x86_64
Module libcrypto.so.3 from rpm openssl-3.2.2-3.fc40.x86_64
Module libssl.so.3 from rpm openssl-3.2.2-3.fc40.x86_64
Module libpsl.so.5 from rpm libpsl-0.21.5-3.fc40.x86_64
Module libssh.so.4 from rpm libssh-0.10.6-5.fc40.x86_64
Module libidn2.so.0 from rpm libidn2-2.3.7-1.fc40.x86_64
Module libnghttp2.so.14 from rpm nghttp2-1.59.0-3.fc40.x86_64
Module liblzma.so.5 from rpm xz-5.4.6-3.fc40.x86_64
Module libicuuc.so.74 from rpm icu-74.2-1.fc40.x86_64
Module libicui18n.so.74 from rpm icu-74.2-1.fc40.x86_64
Module libsoup-3.0.so.0 from rpm libsoup3-3.4.4-3.fc40.x86_64
Module libsecret-1.so.0 from rpm libsecret-0.21.4-2.fc40.x86_64
Module libedbus-private.so from rpm evolution-data-server-3.52.4-1.fc40.x86_64
Module libcamel-1.2.so.64 from rpm evolution-data-server-3.52.4-1.fc40.x86_64
Module libical.so.3 from rpm libical-3.0.18-1.fc40.x86_64
Module libpixman-1.so.0 from rpm pixman-0.43.4-1.fc40.x86_64
Module libxcb-shm.so.0 from rpm libxcb-1.17.0-1.fc40.x86_64
Module libxcb-render.so.0 from rpm libxcb-1.17.0-1.fc40.x86_64
Module libxcb.so.1 from rpm libxcb-1.17.0-1.fc40.x86_64
Module libXrender.so.1 from rpm libXrender-0.9.11-6.fc40.x86_64
Module libfreetype.so.6 from rpm freetype-2.13.2-5.fc40.x86_64
Module libpng16.so.16 from rpm libpng-1.6.40-3.fc40.x86_64
Module libthai.so.0 from rpm libthai-0.1.29-8.fc40.x86_64
Module libXinerama.so.1 from rpm libXinerama-1.1.5-6.fc40.x86_64
Module libXrandr.so.2 from rpm libXrandr-1.5.4-3.fc40.x86_64
Module libXcomposite.so.1 from rpm libXcomposite-0.4.6-3.fc40.x86_64
Module libXdamage.so.1 from rpm libXdamage-1.1.6-3.fc40.x86_64
Module libXcursor.so.1 from rpm libXcursor-1.2.1-7.fc40.x86_64
Module libXext.so.6 from rpm libXext-1.3.6-1.fc40.x86_64
Module libwayland-egl.so.1 from rpm wayland-1.23.0-2.fc40.x86_64
Module libwayland-cursor.so.0 from rpm wayland-1.23.0-2.fc40.x86_64
Module libxkbcommon.so.0 from rpm libxkbcommon-1.6.0-2.fc40.x86_64
Module libXfixes.so.3 from rpm libXfixes-6.0.1-3.fc40.x86_64
Module libwayland-client.so.0 from rpm wayland-1.23.0-2.fc40.x86_64
Module libcloudproviders.so.0 from rpm libcloudproviders-0.3.5-3.fc40.x86_64
Module libatk-bridge-2.0.so.0 from rpm at-spi2-core-2.52.0-1.fc40.x86_64
Module libX11.so.6 from rpm libX11-1.8.10-2.fc40.x86_64
Module libXi.so.6 from rpm libXi-1.8.2-1.fc40.x86_64
Module libepoxy.so.0 from rpm libepoxy-1.5.10-6.fc40.x86_64
Module libatk-1.0.so.0 from rpm at-spi2-core-2.52.0-1.fc40.x86_64
Module libgdk_pixbuf-2.0.so.0 from rpm gdk-pixbuf2-2.42.10-8.fc40.x86_64
Module libcairo-gobject.so.2 from rpm cairo-1.18.0-3.fc40.x86_64
Module libfribidi.so.0 from rpm fribidi-1.0.14-2.fc40.x86_64
Module libfontconfig.so.1 from rpm fontconfig-2.15.0-6.fc40.x86_64
Module libpangoft2-1.0.so.0 from rpm pango-1.54.0-1.fc40.x86_64
Module libharfbuzz.so.0 from rpm harfbuzz-8.5.0-1.fc40.x86_64
Module libpcre2-8.so.0 from rpm pcre2-10.44-1.fc40.x86_64
Module libffi.so.8 from rpm libffi-3.4.4-7.fc40.x86_64
Module libselinux.so.1 from rpm libselinux-3.6-4.fc40.x86_64
Module libmount.so.1 from rpm util-linux-2.40.1-1.fc40.x86_64
Module libz.so.1 from rpm zlib-ng-2.1.7-1.fc40.x86_64
Module libgmodule-2.0.so.0 from rpm glib2-2.80.3-1.fc40.x86_64
Module libjavascriptcoregtk-4.1.so.0 from rpm webkitgtk-2.44.3-2.fc40.x86_64
Module libwebkit2gtk-4.1.so.0 from rpm webkitgtk-2.44.3-2.fc40.x86_64
Module libcurl.so.4 from rpm curl-8.6.0-10.fc40.x86_64
Module libxml2.so.2 from rpm libxml2-2.12.8-1.fc40.x86_64
Module libedataserver-1.2.so.27 from rpm evolution-data-server-3.52.4-1.fc40.x86_64
Module libical-glib.so.3 from rpm libical-3.0.18-1.fc40.x86_64
Module libecal-2.0.so.3 from rpm evolution-data-server-3.52.4-1.fc40.x86_64
Module libjson-glib-1.0.so.0 from rpm json-glib-1.8.0-3.fc40.x86_64
Module libcairo.so.2 from rpm cairo-1.18.0-3.fc40.x86_64
Module libpango-1.0.so.0 from rpm pango-1.54.0-1.fc40.x86_64
Module libpangocairo-1.0.so.0 from rpm pango-1.54.0-1.fc40.x86_64
Module libgdk-3.so.0 from rpm gtk3-3.24.43-1.fc40.x86_64
Module libgtk-3.so.0 from rpm gtk3-3.24.43-1.fc40.x86_64
Module libgoa-1.0.so.0 from rpm gnome-online-accounts-3.50.2-1.fc40.x86_64
Module libglib-2.0.so.0 from rpm glib2-2.80.3-1.fc40.x86_64
Module libgobject-2.0.so.0 from rpm glib2-2.80.3-1.fc40.x86_64
Module libgio-2.0.so.0 from rpm glib2-2.80.3-1.fc40.x86_64
Module libtracker-sparql-3.0.so.0 from rpm tracker-3.7.3-1.fc40.x86_64
Module bijiben-shell-search-provider from rpm bijiben-40.1-10.fc40.x86_64
Stack trace of thread 12551:
#0 0x00007f52eeff79b1 g_type_check_instance_is_fundamentally_a (libgobject-2.0.so.0 + 0x399b1)
#1 0x00007f52eefde88f g_object_unref (libgobject-2.0.so.0 + 0x2088f)
#2 0x00007f52eeec40c5 g_source_callback_unref (libglib-2.0.so.0 + 0x540c5)
#3 0x00007f52eeecb3ac g_source_destroy_internal (libglib-2.0.so.0 + 0x5b3ac)
#4 0x00007f52eeeccfa9 g_main_context_dispatch_unlocked.lto_priv.0 (libglib-2.0.so.0 + 0x5cfa9)
#5 0x00007f52eef2ec98 g_main_context_iterate_unlocked.isra.0 (libglib-2.0.so.0 + 0xbec98)
#6 0x00007f52eeece383 g_main_context_iteration (libglib-2.0.so.0 + 0x5e383)
#7 0x00007f52ef0ff0fd g_application_run (libgio-2.0.so.0 + 0xe20fd)
#8 0x00005634e8b335af main (bijiben-shell-search-provider + 0x105af)
#9 0x00007f52e8e39088 __libc_start_call_main (libc.so.6 + 0x2a088)
#10 0x00007f52e8e3914b __libc_start_main@@GLIBC_2.34 (libc.so.6 + 0x2a14b)
#11 0x00005634e8b335f5 _start (bijiben-shell-search-provider + 0x105f5)
Stack trace of thread 12638:
#0 0x00007f52e8f1c87d __poll (libc.so.6 + 0x10d87d)
#1 0x00007f52eef2ec34 g_main_context_iterate_unlocked.isra.0 (libglib-2.0.so.0 + 0xbec34)
#2 0x00007f52eeece383 g_main_context_iteration (libglib-2.0.so.0 + 0x5e383)
#3 0x00007f52e343e705 dconf_gdbus_worker_thread (libdconfsettings.so + 0x7705)
#4 0x00007f52eeefd813 g_thread_proxy (libglib-2.0.so.0 + 0x8d813)
#5 0x00007f52e8ea66d7 start_thread (libc.so.6 + 0x976d7)
#6 0x00007f52e8f2a60c __clone3 (libc.so.6 + 0x11b60c)
Stack trace of thread 12677:
#2 0x00007f52eeed2f37 g_main_loop_run (libglib-2.0.so.0 + 0x62f37)
#3 0x00007f52ee3137d8 cal_client_dbus_thread (libecal-2.0.so.3 + 0x227d8)
Stack trace of thread 12684:
#0 0x00007f52e8f283dd syscall (libc.so.6 + 0x1193dd)
#1 0x00007f52eef2beb0 g_cond_wait_until (libglib-2.0.so.0 + 0xbbeb0)
#2 0x00007f52eee975e3 g_async_queue_pop_intern_unlocked (libglib-2.0.so.0 + 0x275e3)
#3 0x00007f52eeeff59a g_thread_pool_thread_proxy.lto_priv.0 (libglib-2.0.so.0 + 0x8f59a)
Stack trace of thread 12675:
Stack trace of thread 12631:
#3 0x00007f52eeece3e1 glib_worker_main (libglib-2.0.so.0 + 0x5e3e1)
Stack trace of thread 12630:
#1 0x00007f52eef2bccd g_cond_wait (libglib-2.0.so.0 + 0xbbccd)
#2 0x00007f52eee9761b g_async_queue_pop_intern_unlocked (libglib-2.0.so.0 + 0x2761b)
#3 0x00007f52eeefea03 g_thread_pool_spawn_thread (libglib-2.0.so.0 + 0x8ea03)
Stack trace of thread 12632:
#3 0x00007f52eeeff43d g_thread_pool_thread_proxy.lto_priv.0 (libglib-2.0.so.0 + 0x8f43d)
Stack trace of thread 12634:
#3 0x00007f52ef132682 gdbus_shared_thread_func.lto_priv.0 (libgio-2.0.so.0 + 0x115682)
Stack trace of thread 12668:
ELF object binary architecture: AMD x86-64
15:51:30 gdm: Gdm: on_display_removed: assertion ‘GDM_IS_REMOTE_DISPLAY (display)’ failed
15:51:20 systemd: Failed to start app-gnome-snap\x2duserd\x2dautostart-3435.scope - Application launched by gnome-session-binary.
15:51:20 systemd: Failed to start app-gnome-xapp\x2dsn\x2dwatcher-3325.scope - Application launched by gnome-session-binary.
15:51:14 systemd: Timed out waiting for device dev-disk-by\x2did-wwn\x2d0x500a0751e4f925ef\x2dpart2.device - /dev/disk/by-id/wwn-0x500a0751e4f925ef-part2.
15:51:12 dbus-broker-lau: Ignoring duplicate name ‘org.freedesktop.FileManager1’ in service file ‘/usr/share//dbus-1/services/org.freedesktop.FileManager1.service’
15:51:12 gdm: Gdm: on_display_added: assertion ‘GDM_IS_REMOTE_DISPLAY (display)’ failed
15:51:10 gdm-session-wor: gkr-pam: unable to locate daemon control file
15:51:04 systemd: Failed to start fw-fanctrl.service - FrameWork Fan Controller.
15:51:03 abrt-server: Not saving repeating crash in ‘/usr/local/bin/fanctrl.py’
15:51:02 abrt-server: Not saving repeating crash in ‘/usr/local/bin/fanctrl.py’
15:51:01 abrt-server: Not saving repeating crash in ‘/usr/local/bin/fanctrl.py’
15:50:58 chronyd: Could not add source fd00::1eed:6fff:febb:a2b9 : Already in use
15:50:48 dbus-broker-lau: Ignoring duplicate name ‘org.freedesktop.FileManager1’ in service file ‘/usr/share//dbus-1/services/org.freedesktop.FileManager1.service’
15:50:46 chronyd: Could not add source 192.168.178.1 : Already in use
15:50:42 abrtd: ‘/var/spool/abrt/Python3-2024-05-18-21:11:13-11898.new’ is not a problem directory
15:50:41 abrtd: ‘/var/spool/abrt/Python3-2024-05-12-22:51:00-6527.new’ is not a problem directory
15:50:41 abrtd: ‘/var/spool/abrt/Python3-2024-05-09-22:16:10-10515.new’ is not a problem directory
15:50:40 abrtd: ‘/var/spool/abrt/Python3-2024-04-30-17:38:38-5529.new’ is not a problem directory
15:50:40 abrtd: ‘/var/spool/abrt/Python3-2024-04-23-22:17:28-14500.new’ is not a problem directory
15:50:39 abrtd: ‘/var/spool/abrt/Python3-2024-04-22-22:54:34-16720.new’ is not a problem directory
15:50:39 abrtd: ‘/var/spool/abrt/Python3-2024-04-21-11:11:42-4217.new’ is not a problem directory
15:50:39 kernel: iwlwifi 0000:a6:00.0: WRT: Invalid buffer destination
15:50:38 kernel: iwlwifi 0000:a6:00.0: WRT: Invalid buffer destination
15:50:38 abrtd: ‘/var/spool/abrt/Python3-2024-04-14-21:51:52-10640.new’ is not a problem directory
15:50:38 abrtd: ‘/var/spool/abrt/Python3-2024-04-02-09:03:56-5299.new’ is not a problem directory
15:50:37 abrtd: ‘/var/spool/abrt/Python3-2024-03-23-22:21:18-9437.new’ is not a problem directory
15:50:37 thermald: Unsupported conditions are present
15:50:37 thermald: Unsupported condition 58 (UKNKNOWN)
15:50:36 kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
15:50:35 kernel: iwlwifi 0000:a6:00.0: WRT: Invalid buffer destination
15:50:34 kernel: cros-usbpd-charger cros-usbpd-charger.3.auto: probe with driver cros-usbpd-charger failed with error -71
15:50:34 kernel: cros-usbpd-charger cros-usbpd-charger.3.auto: Unexpected number of charge port count
15:50:31 kernel: Module hid_sensor_hub is blacklisted
15:50:20 kernel: Module hid_sensor_hub is blacklisted
There is a lot of weird stuff going on in there but this is the most worrying. What device is that disk id pointing to? Is it your NVME drive? I was thinking maybe file system corruption before I saw that.
Edit: At minimum something in gnome is crashing. You may try to reinstall packages associated with the errors.
I would also be looking through your system logs for anything that mentions fsck or disk.
Thanks for looking. I have no idea what that device is actually. I’m trying to work it out. It’s not my NVME drive.
What do you have listed ls -lah /dev/disk/by-id?
Does reinstalling bijiben make those crashes go away?
@parawizard
bash-5.2$ ls -lah /dev/disk/by-id?
ls: cannot access ‘/dev/disk/by-id?’: No such file or directory
Sadly not.
I have also discovered that Pika Backup can no longer make backups or restore files from backup. Also Steam isn’t working.
I suspect I might have to nuke it and reinstall Fedora from scratch. It’s so odd.
I did remember last night that these issues started occurring after I had a hard freeze while opening Geary so I had to shut down and restart. I doubt that is the cause, more likely a symptom.
I would check for disk or fsck evidence. You can also force a fsck. I think there should be something in dmesg or journalctl -k.
I’ve had libc become corrupted once and caused all kinds of weird issues.
You might want to check smart status on your nvme as well.
Looks like you can get rpm to verify installed packages Using RPM to Verify Installed Packages
Interesting developments.
I reinstalled Fedora 40 last night. Everything seemed OK running from the live CD so I went ahead and did it. I backed up my Home data first of course.
After installation Fedora was behaving fine. No grey boot screen, reasonably responsive.
BUT after I applied all the Software updates and restarted, the nasty grey boot screen came back!
So my working assumption is that there is something in the latest Fedora updates which is messing things up.
I re reinstalled after that to check I wasn’t going mad and yes it’s all fine again now, but I don’t think I can update software now.
So basically I’m a bit stuck. There’s something bad in the latest operating system update.
Grey scrern and performance might be separate? Are you following the fedora 40 guide?
Maybe, but grey screen and slow jerky performance coincide.
Then again maybe it’s a hardware problem. I just don’t know,
Yes I followed the Framework guide for installing Fedora 40.
I dont see anything in Fedora 40 on the Framework Laptop 13 - #47 by kholdstare
You would think that others would have the same issues.
Yes true, that’s why I’m starting to think it could be a hardware issue.
I am slowly rebuilding the system. I went ahead and updated all the software again and the grey boot screen with three dots is back. The computer is usable, and reinstalling everything has been good in that a lot of the scary looking log notes aren’t there anymore.
However, I am still seeing a general sluggishness to the system, and I frequently get wait or force quit alerts when doing basic things like saving a small spreadsheet. So it’s definitely not great. I hope that updates to Fedora components will eventually weed out whatever has gone wrong.
Is there a (ideally GUI based, but I can do some basic Terminal things at a push) way to check the health of the components of my Framework? Especially the internal drive, but maybe also the CPU/mainboard?
Have you tried falling back to the previous kernel?
Have you tried that RPM verify yet?
Did you try falling back to X11?
I assume opening a text based tty has no performance issues?
Did you add anything to the kernel command line? I thi k the three dot screen is plymouth fallback mode.
Look for the stacks and errors associated with the force quits. Ideally we identify the bad package. Post a bunch of stacks or large logs to look at.
Edit: What are your kernel command line parameters?
Edit2: can you fallback to X Configuring Xorg as the default GNOME session :: Fedora Docs
Update, possibly final (I hope). I removed and reinserted the four expansion cards and all the performance issues I have experienced are no longer happening. So, a very simple solution apparently. Not quite ‘have you tried turning it off and on again’, but close!
I have no idea why this worked, or why the problem started in the first place. But I’m very happy to have a properly functioning computer again.
freaky
