Tealk
March 17, 2025, 5:43pm
1
Arch Gnome Wayland
Which release version?
Which kernel are you using?
Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series)
AMD Ryzen™ 7 7840HS w/ Radeon™ 780M Graphics × 16
Advanced Micro Devices, Inc. [AMD®/ATI] Navi 33 [Radeon RX 7600/7600 XT/7600M XT/7600S/7700S / PRO W7600]
Hello everyone, recently my graphics card has no longer been recognized correctly by the system, e.g. it can no longer be found in Mission Center, and I also notice that when I start an app, the CPU load goes extremely high even though I have actually selected Discrep Graphic Card.
I found this in the System logs:
18:52:30 kernel: amdgpu 0000:03:00.0: amdgpu: Failed to set workload mask 0x00000001
18:52:30 kernel: [drm:vcn_v4_0_stop [amdgpu]] *ERROR* Dpm disable uvd failed, ret = -121.
18:52:30 kernel: amdgpu 0000:03:00.0: amdgpu: Failed to power gate VCN!
18:52:30 kernel: [drm:amdgpu_device_ip_set_powergating_state [amdgpu]] *ERROR* set_powergating_state of IP block <jpeg_v4_0> failed -110
18:52:30 kernel: amdgpu 0000:03:00.0: [drm:jpeg_v4_0_set_powergating_state [amdgpu]] *ERROR* amdgpu: JPEG enable power gating failed
18:52:29 kernel: ucsi_acpi USBC000:00: GET_CABLE_PROPERTY failed (-5)
18:52:29 kernel: snd_hda_intel 0000:03:00.1: no codecs initialized
18:52:29 kernel: hdaudio hdaudioC1D3: no AFG or MFG node found
18:52:29 kernel: snd_hda_intel 0000:03:00.1: CORB reset timeout#2, CORBRP = 65535
18:52:28 kernel: amdgpu 0000:03:00.0: amdgpu: amdgpu_device_ip_resume failed (-22).
18:52:28 kernel: ucsi_acpi USBC000:00: GET_CABLE_PROPERTY failed (-5)
18:52:27 kernel: cros-usbpd-charger cros-usbpd-charger.6.auto: probe with driver cros-usbpd-charger failed with error -71
18:52:27 kernel: leds framework_laptop::kbd_backlight: Setting an LED's brightness failed (-5)
Zoe
March 17, 2025, 8:51pm
2
did the symptom appear when you updated the system?
would you mind listing the actual release for future reference?
/Zoe
Tealk
March 17, 2025, 8:54pm
3
i can no longer say exactly, i had the problem once after the computer came out of standby and after a restart it worked again. unfortunately i have not needed the graphics card for the last 4 days so i would not have noticed it if it had been missing during that time. i also can’t think of how i could determine this.
Which versions do you think would be relevant?
Zoe
March 17, 2025, 9:24pm
4
pleas make sure to uninstall any graphics driver you aren’t using, also make sure you are running the new kernel.
/Zoe
Tealk
March 17, 2025, 9:36pm
5
I update the system several times a day and have only installed packages that I need. Kernel is already up to date, as written in the initial post.
These are the updates from the last few days:
[2025-03-11T19:47:31+0100] [ALPM] upgraded babl (0.1.110-1 -> 0.1.112-1)
[2025-03-11T19:47:32+0100] [ALPM] upgraded chromium (134.0.6998.35-2 -> 134.0.6998.88-1)
[2025-03-11T19:47:32+0100] [ALPM] upgraded gtest (1.15.2-1 -> 1.16.0-1)
[2025-03-11T19:47:32+0100] [ALPM] upgraded libical (3.0.19-2 -> 3.0.20-1)
[2025-03-11T19:47:32+0100] [ALPM] upgraded yamllint (1.35.1-2 -> 1.36.0-1)
[2025-03-11T19:47:33+0100] [ALPM] transaction completed
[2025-03-11T19:48:02+0100] [ALPM] upgraded brave-bin (1:1.76.73-1 -> 1:1.76.74-1)
[2025-03-11T19:48:02+0100] [ALPM] transaction completed
[2025-03-12T17:14:10+0100] [ALPM] upgraded abseil-cpp (20250127.0-1 -> 20250127.0-2)
[2025-03-12T17:14:10+0100] [ALPM] upgraded amd-ucode (20250210.5bc5868b-1 -> 20250311.b69d4b74-2)
[2025-03-12T17:14:10+0100] [ALPM] upgraded bash (5.2.037-1 -> 5.2.037-2)
[2025-03-12T17:14:10+0100] [ALPM] upgraded element-web (1.11.92-2 -> 1.11.95-1)
[2025-03-12T17:14:10+0100] [ALPM] upgraded pango (1:1.56.1-1 -> 1:1.56.2-1)
[2025-03-12T17:14:10+0100] [ALPM] upgraded libcap (2.71-1 -> 2.75-1)
[2025-03-12T17:14:10+0100] [ALPM] upgraded element-desktop (1.11.92-2 -> 1.11.95-1)
[2025-03-12T17:14:10+0100] [ALPM] upgraded faac (1.30-5 -> 1.31.1-1)
[2025-03-12T17:14:10+0100] [ALPM] upgraded ldb (2:4.21.4-1 -> 2:4.22.0-1)
[2025-03-12T17:14:10+0100] [ALPM] upgraded lib32-libcap (2.71-1 -> 2.75-1)
[2025-03-12T17:14:10+0100] [ALPM] upgraded lib32-pango (1:1.56.1-1 -> 1:1.56.2-1)
[2025-03-12T17:14:10+0100] [ALPM] upgraded libarchive (3.7.7-1 -> 3.7.7-2)
[2025-03-12T17:14:10+0100] [ALPM] upgraded libwbclient (2:4.21.4-1 -> 2:4.22.0-1)
[2025-03-12T17:14:10+0100] [ALPM] upgraded libxmlb (0.3.21-1 -> 0.3.22-1)
[2025-03-12T17:14:10+0100] [ALPM] upgraded linux-firmware-whence (20250210.5bc5868b-1 -> 20250311.b69d4b74-2)
[2025-03-12T17:14:11+0100] [ALPM] upgraded linux-firmware (20250210.5bc5868b-1 -> 20250311.b69d4b74-2)
[2025-03-12T17:14:11+0100] [ALPM] upgraded ollama (0.5.13-1 -> 0.6.0-1)
[2025-03-12T17:14:11+0100] [ALPM] upgraded ollama-rocm (0.5.13-1 -> 0.6.0-1)
[2025-03-12T17:14:11+0100] [ALPM] warning: /etc/pacman.d/mirrorlist installed as /etc/pacman.d/mirrorlist.pacnew
[2025-03-12T17:14:11+0100] [ALPM] upgraded pacman-mirrorlist (20250101-1 -> 20250311-1)
[2025-03-12T17:14:11+0100] [ALPM] upgraded smbclient (2:4.21.4-1 -> 2:4.22.0-1)
[2025-03-12T17:14:11+0100] [ALPM] transaction completed
[2025-03-12T17:19:24+0100] [ALPM] upgraded vscodium-bin (1.98.0.25067-1 -> 1.98.1.25070-1)
[2025-03-12T17:19:24+0100] [ALPM] installed vscodium-bin-debug (1.98.1.25070-1)
[2025-03-12T17:19:24+0100] [ALPM] transaction completed
[2025-03-12T22:34:36+0100] [ALPM] upgraded mangohud (0.8.0-3 -> 0.8.1-1)
[2025-03-12T22:34:36+0100] [ALPM] transaction completed
[2025-03-13T17:21:31+0100] [ALPM] upgraded dkms (3.1.5-1 -> 3.1.6-1)
[2025-03-13T17:21:31+0100] [ALPM] upgraded ghostscript (10.04.0-1 -> 10.05.0-1)
[2025-03-13T17:21:31+0100] [ALPM] upgraded qpdf (11.10.1-1 -> 12.0.0-1)
[2025-03-13T17:21:31+0100] [ALPM] upgraded libcupsfilters (2.1.1-1 -> 2.1.1-2)
[2025-03-13T17:21:31+0100] [ALPM] upgraded xorg-xinit (1.4.3-1 -> 1.4.4-1)
[2025-03-13T17:21:31+0100] [ALPM] transaction completed
[2025-03-13T17:21:55+0100] [ALPM] upgraded librewolf-bin (1:136.0.0_2-1 -> 1:136.0.1_1-1)
[2025-03-14T18:32:54+0100] [ALPM] upgraded alsa-card-profiles (1:1.4.0-2 -> 1:1.4.1-1)
[2025-03-14T18:32:54+0100] [ALPM] upgraded android-udev (20241109-1 -> 20250314-1)
[2025-03-14T18:32:54+0100] [ALPM] upgraded fontconfig (2:2.16.0-2 -> 2:2.16.1-1)
[2025-03-14T18:32:56+0100] [ALPM] upgraded cairo (1.18.2-2 -> 1.18.4-1)
[2025-03-14T18:32:56+0100] [ALPM] upgraded libpipewire (1:1.4.0-2 -> 1:1.4.1-1)
[2025-03-14T18:32:56+0100] [ALPM] upgraded pipewire (1:1.4.0-2 -> 1:1.4.1-1)
[2025-03-14T18:32:56+0100] [ALPM] upgraded gtest (1.16.0-1 -> 1.16.0-2)
[2025-03-14T18:32:56+0100] [ALPM] upgraded pipewire-audio (1:1.4.0-2 -> 1:1.4.1-1)
[2025-03-14T18:32:56+0100] [ALPM] upgraded pipewire-jack (1:1.4.0-2 -> 1:1.4.1-1)
[2025-03-14T18:32:56+0100] [ALPM] upgraded svt-av1 (3.0.0-1 -> 3.0.1-1)
[2025-03-14T18:32:56+0100] [ALPM] upgraded spirv-tools (1:1.4.304.1-2 -> 1:1.4.309.0-1)
[2025-03-14T18:32:56+0100] [ALPM] upgraded mesa (1:24.3.4-1 -> 1:25.0.1-2)
[2025-03-14T18:32:56+0100] [ALPM] upgraded shaderc (2024.4-1 -> 2025.1-1)
[2025-03-14T18:32:56+0100] [ALPM] upgraded chromaprint (1.5.1-9 -> 1.5.1-10)
[2025-03-14T18:32:56+0100] [ALPM] upgraded dotnet-host (9.0.2.sdk103-1 -> 9.0.3.sdk104-1)
[2025-03-14T18:32:56+0100] [ALPM] upgraded dotnet-runtime (9.0.2.sdk103-1 -> 9.0.3.sdk104-1)
[2025-03-14T18:32:56+0100] [ALPM] upgraded netstandard-targeting-pack (9.0.2.sdk103-1 -> 9.0.3.sdk104-1)
[2025-03-14T18:32:56+0100] [ALPM] upgraded dotnet-targeting-pack (9.0.2.sdk103-1 -> 9.0.3.sdk104-1)
[2025-03-14T18:32:57+0100] [ALPM] upgraded dotnet-sdk (9.0.2.sdk103-1 -> 9.0.3.sdk104-1)
[2025-03-14T18:32:57+0100] [ALPM] upgraded libxkbcommon (1.8.0-1 -> 1.8.1-1)
[2025-03-14T18:32:57+0100] [ALPM] upgraded libxkbcommon-x11 (1.8.0-1 -> 1.8.1-1)
[2025-03-14T18:32:57+0100] [ALPM] upgraded libxslt (1.1.42-2 -> 1.1.43-1)
[2025-03-14T18:32:57+0100] [ALPM] upgraded epiphany (47.3.1-1 -> 47.4-1)
[2025-03-14T18:32:57+0100] [ALPM] upgraded gamescope (3.16.1-1 -> 3.16.2-1)
[2025-03-14T18:32:57+0100] [ALPM] upgraded gnome-software (47.4-1 -> 47.5-1)
[2025-03-14T18:32:57+0100] [ALPM] upgraded gst-plugin-pipewire (1:1.4.0-2 -> 1:1.4.1-1)
[2025-03-14T18:32:57+0100] [ALPM] upgraded lib32-fontconfig (2:2.16.0-2 -> 2:2.16.1-1)
[2025-03-14T18:32:59+0100] [ALPM] upgraded lib32-cairo (1.18.2-2 -> 1.18.4-1)
[2025-03-14T18:32:59+0100] [ALPM] upgraded lib32-libxkbcommon (1.8.0-1 -> 1.8.1-1)
[2025-03-14T18:32:59+0100] [ALPM] upgraded lib32-spirv-tools (1:1.4.304.1-2 -> 1:1.4.309.0-1)
[2025-03-14T18:33:00+0100] [ALPM] upgraded lib32-mesa (1:24.3.4-1 -> 1:25.0.1-2)
[2025-03-14T18:33:00+0100] [ALPM] upgraded vulkan-mesa-layers (1:24.3.4-1 -> 1:25.0.1-2)
[2025-03-14T18:33:00+0100] [ALPM] upgraded lib32-vulkan-mesa-layers (1:24.3.4-1 -> 1:25.0.1-2)
[2025-03-14T18:33:00+0100] [ALPM] upgraded libsynctex (2025.0-1 -> 2025.1-1)
[2025-03-14T18:33:00+0100] [ALPM] upgraded pipewire-alsa (1:1.4.0-2 -> 1:1.4.1-1)
[2025-03-14T18:33:00+0100] [ALPM] upgraded pipewire-pulse (1:1.4.0-2 -> 1:1.4.1-1)
[2025-03-14T18:33:00+0100] [ALPM] upgraded vulkan-radeon (1:24.3.4-1 -> 1:25.0.1-2)
[2025-03-14T18:33:00+0100] [ALPM] upgraded zed (0.176.3-1 -> 0.177.8-1)
[2025-03-14T18:33:00+0100] [ALPM] upgraded zvbi (0.2.43-1 -> 0.2.44-1)
[2025-03-14T18:33:00+0100] [ALPM] transaction completed
[2025-03-14T18:35:33+0100] [ALPM] upgraded expat (2.6.4-1 -> 2.7.0-1)
[2025-03-14T18:35:33+0100] [ALPM] upgraded lib32-expat (2.6.4-1 -> 2.7.0-1)
[2025-03-14T18:35:33+0100] [ALPM] transaction completed
[2025-03-14T18:36:07+0100] [ALPM] upgraded vscodium-bin (1.98.1.25070-1 -> 1.98.2.25072-1)
[2025-03-14T18:36:07+0100] [ALPM] installed vscodium-bin-debug (1.98.2.25072-1)
[2025-03-14T18:36:07+0100] [ALPM] upgraded arch-update (3.7.5-1 -> 3.7.6-1)
[2025-03-14T18:36:07+0100] [ALPM] transaction completed
[2025-03-14T21:39:36+0100] [ALPM] upgraded libseccomp (2.5.5-4 -> 2.5.6-1)
[2025-03-14T21:39:36+0100] [ALPM] transaction completed
[2025-03-15T11:55:28+0100] [ALPM] upgraded freerdp (2:3.13.0-1 -> 2:3.14.0-1)
[2025-03-15T11:55:28+0100] [ALPM] upgraded libadwaita (1:1.6.4-1 -> 1:1.6.5-1)
[2025-03-15T11:55:28+0100] [ALPM] upgraded libarchive (3.7.7-2 -> 3.7.7-3)
[2025-03-15T11:55:28+0100] [ALPM] upgraded libmanette (0.2.9-2 -> 0.2.11-1)
[2025-03-15T11:55:28+0100] [ALPM] upgraded linux (6.13.6.arch1-1 -> 6.13.7.arch1-1)
[2025-03-15T11:55:30+0100] [ALPM] upgraded linux-headers (6.13.6.arch1-1 -> 6.13.7.arch1-1)
[2025-03-15T11:55:30+0100] [ALPM] upgraded rygel (1:0.44.1-1 -> 1:0.44.2-1)
[2025-03-15T11:55:30+0100] [ALPM] upgraded zed (0.177.8-1 -> 0.177.9-1)
[2025-03-15T11:55:30+0100] [ALPM] transaction completed
[2025-03-15T13:48:54+0100] [ALPM] upgraded git (2.48.1-2 -> 2.49.0-1)
[2025-03-15T13:48:54+0100] [ALPM] upgraded gnome-maps (47.4-1 -> 47.5-1)
[2025-03-15T13:48:54+0100] [ALPM] upgraded lib32-amdvlk (2025.Q1.2-1 -> 2025.Q1.3-1)
[2025-03-15T13:48:54+0100] [ALPM] transaction completed
[2025-03-15T20:06:08+0100] [ALPM] upgraded docker-compose (2.33.1-1 -> 2.34.0-1)
[2025-03-15T20:06:08+0100] [ALPM] upgraded karchive (6.11.0-1 -> 6.12.0-1)
[2025-03-15T20:06:08+0100] [ALPM] upgraded kguiaddons (6.11.0-1 -> 6.12.0-1)
[2025-03-15T20:06:08+0100] [ALPM] transaction completed
[2025-03-15T23:40:08+0100] [ALPM] upgraded yamllint (1.36.0-1 -> 1.36.1-1)
[2025-03-15T23:40:08+0100] [ALPM] transaction completed
[2025-03-16T09:20:46+0100] [ALPM] upgraded gnome-console (47.1-1 -> 47.2-1)
[2025-03-16T09:20:46+0100] [ALPM] upgraded libgoa (3.52.3.1-1 -> 3.52.4-1)
[2025-03-16T09:20:46+0100] [ALPM] upgraded gnome-online-accounts (3.52.3.1-1 -> 3.52.4-1)
[2025-03-16T09:20:47+0100] [ALPM] upgraded gnome-user-docs (47.2-1 -> 47.5-1)
[2025-03-16T09:20:47+0100] [ALPM] upgraded libpeas-2 (2.0.5-2 -> 2.0.7-1)
[2025-03-16T09:20:47+0100] [ALPM] upgraded libspelling (0.4.6-2 -> 0.4.7-1)
[2025-03-16T09:20:47+0100] [ALPM] transaction completed
[2025-03-16T17:01:23+0100] [ALPM] upgraded protobuf (29.3-1 -> 30.0-3)
[2025-03-16T17:01:23+0100] [ALPM] upgraded android-tools (35.0.2-11 -> 35.0.2-12)
[2025-03-16T17:01:23+0100] [ALPM] upgraded libgoa (3.52.4-1 -> 3.52.5-1)
[2025-03-16T17:01:23+0100] [ALPM] upgraded libphonenumber (1:9.0.0-1 -> 1:9.0.0-2)
[2025-03-16T17:01:23+0100] [ALPM] upgraded evolution-data-server (3.54.3-4 -> 3.54.3-5)
[2025-03-16T17:01:23+0100] [ALPM] upgraded gnome-online-accounts (3.52.4-1 -> 3.52.5-1)
[2025-03-16T17:01:23+0100] [ALPM] upgraded lib32-gtk3 (1:3.24.48-1 -> 1:3.24.49-1)
[2025-03-16T17:01:23+0100] [ALPM] upgraded libedataserverui4 (3.54.3-4 -> 3.54.3-5)
[2025-03-16T17:01:23+0100] [ALPM] upgraded poppler (25.02.0-2 -> 25.03.0-1)
[2025-03-16T17:01:24+0100] [ALPM] upgraded libreoffice-fresh (25.2.1-2 -> 25.2.1-3)
[2025-03-16T17:01:24+0100] [ALPM] upgraded libvlc (3.0.21-14 -> 3.0.21-15)
[2025-03-16T17:01:25+0100] [ALPM] upgraded mumble (1.5.735-4 -> 1.5.735-5)
[2025-03-16T17:01:25+0100] [ALPM] upgraded poppler-glib (25.02.0-2 -> 25.03.0-1)
[2025-03-16T17:01:25+0100] [ALPM] upgraded protobuf-c (1.5.0-11 -> 1.5.1-1)
[2025-03-16T17:01:25+0100] [ALPM] upgraded vlc (3.0.21-14 -> 3.0.21-15)
[2025-03-16T17:01:25+0100] [ALPM] transaction completed
[2025-03-16T19:52:01+0100] [ALPM] upgraded gcr-4 (4.3.0-1 -> 4.3.1-1)
[2025-03-16T19:52:01+0100] [ALPM] transaction completed
[2025-03-16T22:11:42+0100] [ALPM] upgraded ollama (0.6.0-1 -> 0.6.1-1)
[2025-03-16T22:11:43+0100] [ALPM] upgraded ollama-rocm (0.6.0-1 -> 0.6.1-1)
[2025-03-16T22:11:43+0100] [ALPM] transaction completed
[2025-03-17T08:18:13+0100] [ALPM] upgraded at-spi2-core (2.54.1-1 -> 2.56.0-1)
[2025-03-17T08:18:13+0100] [ALPM] upgraded libgirepository (1.82.0-3 -> 1.84.0-1)
[2025-03-17T08:18:13+0100] [ALPM] upgraded gobject-introspection-runtime (1.82.0-3 -> 1.84.0-1)
[2025-03-17T08:18:13+0100] [ALPM] upgraded gobject-introspection (1.82.0-3 -> 1.84.0-1)
[2025-03-17T08:18:13+0100] [ALPM] upgraded gstreamer (1.24.12-4 -> 1.26.0-1)
[2025-03-17T08:18:13+0100] [ALPM] upgraded gst-plugins-base-libs (1.24.12-4 -> 1.26.0-1)
[2025-03-17T08:18:13+0100] [ALPM] upgraded gst-devtools-libs (1.24.12-4 -> 1.26.0-1)
[2025-03-17T08:18:13+0100] [ALPM] upgraded gst-python (1.24.12-4 -> 1.26.0-1)
[2025-03-17T08:18:13+0100] [ALPM] upgraded gst-editing-services (1.24.12-4 -> 1.26.0-1)
[2025-03-17T08:18:13+0100] [ALPM] upgraded pango (1:1.56.2-1 -> 1:1.56.3-1)
[2025-03-17T08:18:13+0100] [ALPM] upgraded gst-libav (1.24.12-4 -> 1.26.0-1)
[2025-03-17T08:18:13+0100] [ALPM] upgraded gst-plugins-bad-libs (1.24.12-4 -> 1.26.0-1)
[2025-03-17T08:18:13+0100] [ALPM] upgraded gst-plugin-gtk (1.24.12-4 -> 1.26.0-1)
[2025-03-17T08:18:13+0100] [ALPM] upgraded gst-plugin-gtk4 (0.13.4-1 -> 0.13.5-1)
[2025-03-17T08:18:13+0100] [ALPM] upgraded gst-plugins-bad (1.24.12-4 -> 1.26.0-1)
[2025-03-17T08:18:13+0100] [ALPM] upgraded gst-plugins-base (1.24.12-4 -> 1.26.0-1)
[2025-03-17T08:18:13+0100] [ALPM] upgraded gst-plugins-good (1.24.12-4 -> 1.26.0-1)
[2025-03-17T08:18:13+0100] [ALPM] upgraded haskell-onetuple (0.4.1.1-21 -> 0.4.1.1-23)
[2025-03-17T08:18:13+0100] [ALPM] upgraded haskell-foldable1-classes-compat (0.1-117 -> 0.1-119)
[2025-03-17T08:18:13+0100] [ALPM] upgraded haskell-indexed-traversable (0.1.4-30 -> 0.1.4-32)
[2025-03-17T08:18:13+0100] [ALPM] upgraded haskell-unordered-containers (0.2.20-32 -> 0.2.20-33)
[2025-03-17T08:18:13+0100] [ALPM] upgraded haskell-indexed-traversable-instances (0.1.2-15 -> 0.1.2-16)
[2025-03-17T08:18:13+0100] [ALPM] upgraded haskell-comonad (5.0.8-301 -> 5.0.8-303)
[2025-03-17T08:18:13+0100] [ALPM] upgraded haskell-bifunctors (5.6-117 -> 5.6-119)
[2025-03-17T08:18:13+0100] [ALPM] upgraded haskell-semigroupoids (6.0.0.1-1 -> 6.0.0.1-2)
[2025-03-17T08:18:13+0100] [ALPM] upgraded haskell-assoc (1.1-2 -> 1.1-4)
[2025-03-17T08:18:13+0100] [ALPM] upgraded haskell-these (1.2-2 -> 1.2-4)
[2025-03-17T08:18:13+0100] [ALPM] upgraded haskell-semialign (1.3-2 -> 1.3-3)
[2025-03-17T08:18:13+0100] [ALPM] upgraded haskell-strict (0.5-2 -> 0.5-4)
[2025-03-17T08:18:13+0100] [ALPM] upgraded haskell-witherable (0.4.2-122 -> 0.4.2-123)
[2025-03-17T08:18:13+0100] [ALPM] upgraded haskell-aeson (2.1.2.1-69 -> 2.1.2.1-70)
[2025-03-17T08:18:13+0100] [ALPM] upgraded haskell-regex-tdfa (1.3.2.2-58 -> 1.3.2.2-59)
[2025-03-17T08:18:13+0100] [ALPM] upgraded lib32-at-spi2-core (2.54.1-1 -> 2.56.0-1)
[2025-03-17T08:18:13+0100] [ALPM] upgraded lib32-gstreamer (1.24.12-3 -> 1.26.0-1)
[2025-03-17T08:18:13+0100] [ALPM] upgraded lib32-gst-plugins-base-libs (1.24.12-3 -> 1.26.0-1)
[2025-03-17T08:18:13+0100] [ALPM] upgraded lib32-pango (1:1.56.2-1 -> 1:1.56.3-1)
[2025-03-17T08:18:13+0100] [ALPM] upgraded libmanette (0.2.11-1 -> 0.2.11-2)
[2025-03-17T08:18:14+0100] [ALPM] upgraded python-numpy (2.2.3-1 -> 2.2.4-1)
[2025-03-17T08:18:14+0100] [ALPM] upgraded shellcheck (0.10.0-29 -> 0.10.0-30)
[2025-03-17T08:18:14+0100] [ALPM] transaction completed
[2025-03-17T16:48:47+0100] [ALPM] upgraded libavif (1.2.0-2 -> 1.2.1-1)
[2025-03-17T16:48:47+0100] [ALPM] upgraded python-filelock (3.17.0-1 -> 3.18.0-1)
[2025-03-17T16:48:47+0100] [ALPM] upgraded qemu-common (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:47+0100] [ALPM] upgraded qemu-audio-alsa (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:47+0100] [ALPM] upgraded qemu-audio-dbus (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:47+0100] [ALPM] upgraded qemu-audio-jack (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:47+0100] [ALPM] upgraded qemu-audio-oss (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:47+0100] [ALPM] upgraded qemu-audio-pa (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:47+0100] [ALPM] upgraded qemu-audio-pipewire (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:47+0100] [ALPM] upgraded qemu-audio-sdl (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:47+0100] [ALPM] upgraded qemu-ui-opengl (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:47+0100] [ALPM] upgraded qemu-ui-spice-core (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:47+0100] [ALPM] upgraded qemu-audio-spice (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:47+0100] [ALPM] upgraded qemu-img (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:47+0100] [ALPM] upgraded qemu-system-x86-firmware (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-system-x86 (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-base (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-block-curl (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-block-dmg (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-block-nfs (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-block-ssh (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-chardev-spice (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-hw-display-qxl (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-hw-display-virtio-gpu (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-hw-display-virtio-gpu-gl (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-hw-display-virtio-gpu-pci (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-hw-display-virtio-gpu-pci-gl (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-hw-display-virtio-vga (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-hw-display-virtio-vga-gl (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-hw-usb-host (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-hw-usb-redirect (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-hw-usb-smartcard (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-ui-curses (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-ui-dbus (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-ui-egl-headless (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-ui-gtk (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-ui-sdl (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-ui-spice-app (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-vhost-user-gpu (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded qemu-desktop (9.2.0-2 -> 9.2.2-1)
[2025-03-17T16:48:48+0100] [ALPM] upgraded yamllint (1.36.1-1 -> 1.36.2-1)
[2025-03-17T16:48:48+0100] [ALPM] transaction completed
[2025-03-17T21:35:49+0100] [ALPM] upgraded containerd (2.0.3-1 -> 2.0.4-1)
[2025-03-17T21:35:49+0100] [ALPM] upgraded gegl (0.4.54-1 -> 0.4.56-1)
[2025-03-17T21:35:49+0100] [ALPM] installed appstream-glib (0.8.3-2)
[2025-03-17T21:35:50+0100] [ALPM] upgraded gimp (2.10.38-5 -> 3.0.0-1)
[2025-03-17T21:35:51+0100] [ALPM] upgraded zed (0.177.9-1 -> 0.177.10-1)
[2025-03-17T21:35:51+0100] [ALPM] transaction completed
I would now generally suspect mesa:
[2025-03-14T18:32:56+0100] [ALPM] upgraded mesa (1:24.3.4-1 → 1:25.0.1-2)
Ok mesa is probably not it, the downgrade did not help.
Zoe
March 17, 2025, 9:49pm
6
The problem appears to be in the kernel driver, or the firmware.
check the linux-firmware package as well as the kernel.
consider installing stable drivers before asking for support, It might be useful to start a testing topic for people that enjoy broken systems.
/Zoe
this seems to be a regression in the kernel and/or mesa.
i’ve had the same issue crop up with my framework16 recently and it seems to cause the dedicated GPU to fail to exit sleep mode once it enters it.
i have seen reports of issues with AMD graphics corruption with mesa 1.25 so this may be another symptom of that.
I’ve been unable to figure out a workaround to resolve the issue yet, but i remain interested in figuring one out.
Tealk
March 17, 2025, 10:10pm
8
How exactly should I do this, I assume that the packages offered in the repos have a certain stability, if not I will have a hard time finding out where this is not the case
Unfortunately, the problem also seems to exist with mesa 24.3.4
Zoe
March 17, 2025, 10:23pm
9
I am not familiar with arch, as far as I can tell 6.12 or 6.6 seems to be the latest stable kernels.
the problem seems to be that the kernel driver can’t configure the hardware properly, this indicate that it’s a regression.
/Zoe
Tealk
March 17, 2025, 10:24pm
10
i don’t know why, but i just booted fedora from a stick to see if the hardware has a defect, now i’m back in arch and the graphics card is running, with all the updates mentioned above… i feel screwed.
yeah…
but at least that proves it isnt’ a hardware issue.
Reaching out to a more arch specific support channel might be a good idea, there should be tools to track down the issue and apply the apropriate fix.
Either that or wait a week or two and no doubt the bug will be fixed and a pacman -Syu will fix the issue.
Tealk
March 17, 2025, 10:35pm
12
yes that’s very reassuring that the hardware is doing well. if it comes up again i’ll post in the arch forum.
But I’m thinking about trying Fedora again.
Zoe
March 17, 2025, 10:38pm
13
It sounds like you booted into the old kernel, when you update it is important to verify that you run the right kernel after the update. This shouldn’t be a problem, but both I and an other community member have had this problem on different distros when using grub.
/Zoe
Tealk
March 17, 2025, 10:42pm
14
i don’t use grub, i use systemd-boot with uki and i only have one kernel installed at a time, so i can’t boot into an old kernel.
As you can see in the initial post, the very latest kernel is also loaded.
Tealk
March 18, 2025, 5:54pm
15
Ok today the GPU is gone again, very strange.
Does the problem stop when you install an LTS kernel?
Having an LTS kernel is a good idea on Arch, just because it makes narrowing things down a lot easier. If it still occurs on the LTS kernel, then the regression was introduced by a fix and it would be very easy to figure out what is causing these issues.
Tealk
March 18, 2025, 9:44pm
17
So it seems to be working with the LTS, I’ll keep an eye on it.
After that, that might be the culprit
Tealk
March 21, 2025, 9:17am
18
I have just installed a Fedora 41 and have the same problem, here are some system info and logs:
OS: Fedora Linux 41 (Silverblue)
Kernel: Linux 6.13.7-200.fc41.x86_64
DE: GNOME 47.4
WM: Mutter (Wayland)
10:10:32 kernel: amdgpu 0000:03:00.0: amdgpu: amdgpu_device_ip_resume failed (-62).
09:53:31 kernel: [drm:amdgpu_device_ip_suspend_phase2 [amdgpu]] *ERROR* SMC failed to set mp1 state 2, -121
09:53:31 kernel: amdgpu 0000:03:00.0: amdgpu: [PrepareMp1] Failed!
09:53:31 kernel: [drm:gfx_v11_0_hw_fini [amdgpu]] *ERROR* failed to halt cp gfx
09:53:30 kernel: amdgpu 0000:03:00.0: amdgpu: MES ring buffer is full.
09:53:25 kernel: [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
09:53:25 kernel: amdgpu 0000:03:00.0: amdgpu: MES failed to respond to msg=REMOVE_QUEUE
09:53:19 kernel: [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
09:53:19 kernel: amdgpu 0000:03:00.0: amdgpu: MES failed to respond to msg=REMOVE_QUEUE
09:53:16 kernel: [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
09:53:16 kernel: amdgpu 0000:03:00.0: amdgpu: MES failed to respond to msg=REMOVE_QUEUE
09:53:13 kernel: [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
09:53:13 kernel: amdgpu 0000:03:00.0: amdgpu: MES failed to respond to msg=REMOVE_QUEUE
09:53:11 kernel: [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
09:53:11 kernel: amdgpu 0000:03:00.0: amdgpu: MES failed to respond to msg=REMOVE_QUEUE
09:53:08 kernel: [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
09:53:08 kernel: amdgpu 0000:03:00.0: amdgpu: MES failed to respond to msg=REMOVE_QUEUE
09:52:58 kernel: snd_hda_intel 0000:03:00.1: CORB reset timeout#2, CORBRP = 65535
09:52:58 kernel: amdgpu 0000:03:00.0: PM: failed to resume async: error -62
09:52:58 kernel: ucsi_acpi USBC000:00: GET_CABLE_PROPERTY failed (-5)
09:52:58 kernel: amdgpu 0000:03:00.0: amdgpu: suspend of IP block <psp> failed -22
09:52:58 kernel: [drm:gfx_v11_0_hw_fini [amdgpu]] *ERROR* failed to halt cp gfx
09:52:58 kernel: [drm:amdgpu_mes_unmap_legacy_queue [amdgpu]] *ERROR* failed to unmap legacy queue
09:52:58 kernel: amdgpu 0000:03:00.0: amdgpu: MES failed to respond to msg=REMOVE_QUEUE
09:00:32 conmon: 2025-03-21 8:00:32 0 [Note] mariadbd: Shutdown complete
08:27:41 systemd: Failed to start app-gnome-org.gnome.Shell.Extensions.GSConnect.Preferences-6286.scope - Application launched by gnome-shell.
08:25:44 polkitd: Error converting subject to JS object: Process 1961 terminated
08:25:44 systemd-logind: Failed to open '/boot//loader/entries': Remote address changed
08:25:42 kernel: amdgpu 0000:03:00.0: amdgpu: Failed to set workload mask 0x00000001
08:25:42 kernel: [drm:vcn_v4_0_stop [amdgpu]] *ERROR* Dpm disable uvd failed, ret = -121.
08:25:42 kernel: amdgpu 0000:03:00.0: amdgpu: Failed to power gate VCN!
08:25:42 kernel: [drm:amdgpu_device_ip_set_powergating_state [amdgpu]] *ERROR* set_powergating_state of IP block <jpeg_v4_0> failed -110
08:25:42 kernel: amdgpu 0000:03:00.0: [drm:jpeg_v4_0_set_powergating_state [amdgpu]] *ERROR* amdgpu: JPEG enable power gating failed
08:25:42 systemd-logind: Failed to open '/boot//loader/entries': Remote address changed
08:25:40 kernel: amdgpu 0000:03:00.0: amdgpu: amdgpu_device_ip_resume failed (-22).
08:25:39 systemd: Failed to start app-gnome-gnome\x2dkeyring\x2dssh-2876.scope - Application launched by gnome-session-binary.
08:23:20 systemd-tmpfile: "/root" already exists and is not a directory.
08:23:20 kernel: cros-usbpd-charger cros-usbpd-charger.6.auto: probe with driver cros-usbpd-charger failed with error -71
08:20:49 kernel: ucsi_acpi USBC000:00: GET_CABLE_PROPERTY failed (-5)
Tealk
March 21, 2025, 4:48pm
19
Ok, it’s getting wilder and wilder: Currently, the graphics card can simply be displayed in the middle of operation in Mission Control and also simply disappear again.
I can see the graphics card in Resources, but it doesn’t do anything and not in the Mission Center. I just got a new kernel today, unfortunately without any improvement: Linux 6.13.8-200.fc41.x86_64
I’m seeing this issue/a similar issue on a fresh install of Fedora 41, but I’m not seeing this issue on my Arch install. I’m using the Zen kernel, perhaps you can give that a shot and see if it works around the issue.
