If you want to install it on an otherwise incompatible distribution, you can download their binary release. If you cannot use the binary release (due to e.g. using a different libc) you can build it from source, and all you need is Rust. It should work fine on Trixie as it worked fine on Bookworm.
The list you’ve linked only indicates which distributions come with prebuilts, packages or package definitions for framework-tool. You can always build it yourself.
