Hi all,
I bought Framework 16" with CPU AMD Ryzen 7 7840HS with motherboard FRANMZCP07.
I’m looking for “how to be sure fan good work” ?
Thanks a lot !
Hi all,
Thanks a lot !
You can force the fans on with:
sudo ./framework_tool --fansetduty 100
and switch them back to auto with:
sudo ./framework_tool --autofanctrl
How it’s possible to use it on debian trixie ?
That is a github repository.
You download the source code using
git clone https://github.com/FrameworkComputer/framework-system.git
Compile it with:
cargo build
Run it with
./target/debug/framework_tool --fansetduty 100
Or you can download a pre-compiled binary from here:
