Caldigit TS3+ not working with FW16 AMD Fedora 41
Just got a Caldigit TS3+ and hooked into my back port via thunderbolt to my FW 16 AMD. The dock doesn’t present ethernet to the laptop, my mouse dongle doesn’t work, and the monitor that’s plugged into it is only at 640p instead of 1440. I’m running Fedora 41. Here’s my dmesg output
[ 7881.285439] usb 1-1: USB disconnect, device number 11
[ 7882.487324] amdgpu 0000:03:00.0: [drm] Cannot find any crtc or sizes
[ 7882.506007] amdgpu 0000:03:00.0: [drm] Cannot find any crtc or sizes
[ 7883.147757] [drm] PCIE GART of 512M enabled (table at 0x00000081FEB00000).
[ 7883.147812] amdgpu 0000:03:00.0: amdgpu: PSP is resuming...
[ 7883.203718] amdgpu 0000:03:00.0: amdgpu: reserve 0x1300000 from 0x81fc000000 for PSP TMR
[ 7883.298936] amdgpu 0000:03:00.0: amdgpu: RAS: optional ras ta ucode is not available
[ 7883.306388] amdgpu 0000:03:00.0: amdgpu: RAP: optional rap ta ucode is not available
[ 7883.306394] amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
[ 7883.306400] amdgpu 0000:03:00.0: amdgpu: SMU is resuming...
[ 7883.306407] amdgpu 0000:03:00.0: amdgpu: smu driver if version = 0x00000035, smu fw if version = 0x00000040, smu fw program = 0, smu fw version = 0x00525c00 (82.92.0)
[ 7883.306413] amdgpu 0000:03:00.0: amdgpu: SMU driver if version not matched
[ 7883.347496] amdgpu 0000:03:00.0: amdgpu: SMU is resumed successfully!
[ 7883.355951] [drm] DMUB hardware initialized: version=0x07002A00
[ 7884.526896] amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[ 7884.526907] amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[ 7884.526911] amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[ 7884.526914] amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
[ 7884.526917] amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
[ 7884.526942] amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
[ 7884.526945] amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
[ 7884.526947] amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
[ 7884.526951] amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
[ 7884.526954] amdgpu 0000:03:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
[ 7884.526956] amdgpu 0000:03:00.0: amdgpu: ring sdma1 uses VM inv eng 13 on hub 0
[ 7884.526959] amdgpu 0000:03:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
[ 7884.526962] amdgpu 0000:03:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
[ 7884.526965] amdgpu 0000:03:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 14 on hub 0
[ 7884.533270] amdgpu 0000:03:00.0: [drm] Cannot find any crtc or sizes
[ 7884.534247] [drm] ring gfx_32789.1.1 was added
[ 7884.534658] [drm] ring compute_32789.2.2 was added
[ 7884.535046] [drm] ring sdma_32789.3.3 was added
[ 7884.535111] [drm] ring gfx_32789.1.1 ib test pass
[ 7884.535168] [drm] ring compute_32789.2.2 ib test pass
[ 7884.535229] [drm] ring sdma_32789.3.3 ib test pass
[ 7884.954178] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-70)
[ 7885.178306] amdgpu 0000:03:00.0: [drm] Cannot find any crtc or sizes
[ 7885.873055] usb 1-1: new low-speed USB device number 13 using xhci_hcd
[ 7886.006818] usb 1-1: No LPM exit latency info found, disabling LPM.
[ 7886.025862] usb 1-1: New USB device found, idVendor=2188, idProduct=0011, bcdDevice= 4.65
[ 7886.025870] usb 1-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 7886.025873] usb 1-1: Product: TS3 Plus
[ 7886.025875] usb 1-1: Manufacturer: CalDigit, Inc.
[ 7886.025877] usb 1-1: SerialNumber: 22539016924208BFA34057FB53EAE4D7
Any help would be appreciated.
The rear port is display ONLY. Change to the back left and back right port on either side of the Framework 16 Laptop. Should be a night and day difference.
I do not have the video card module for my Framework 16 though I could see a benefit for putting in large letters or a symbol that it is display ONLY on that port.
A number of people have made this mistake (commonly laptops from a long time ago always had their ports on the back of the machine)
Let us know how it turns out.
When I said “back port” I meant back port on the side. The usb 4 ports.
Here’s a better dmesg
[17941.097129] ucsi_acpi USBC000:00: unknown error 0
[17941.097145] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-5)
[17941.333179] amdgpu 0000:03:00.0: [drm] Cannot find any crtc or sizes
[17941.773728] thunderbolt 0-0:2.1: new retimer found, vendor=0x7fea device=0x1032
[17941.979792] [drm] PCIE GART of 512M enabled (table at 0x00000081FEB00000).
[17941.979853] amdgpu 0000:03:00.0: amdgpu: PSP is resuming...
[17942.035925] amdgpu 0000:03:00.0: amdgpu: reserve 0x1300000 from 0x81fc000000 for PSP TMR
[17942.130701] amdgpu 0000:03:00.0: amdgpu: RAS: optional ras ta ucode is not available
[17942.138145] amdgpu 0000:03:00.0: amdgpu: RAP: optional rap ta ucode is not available
[17942.138149] amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
[17942.138154] amdgpu 0000:03:00.0: amdgpu: SMU is resuming...
[17942.138160] amdgpu 0000:03:00.0: amdgpu: smu driver if version = 0x00000035, smu fw if version = 0x00000040, smu fw program = 0, smu fw version = 0x00525c00 (82.92.0)
[17942.138165] amdgpu 0000:03:00.0: amdgpu: SMU driver if version not matched
[17942.177944] amdgpu 0000:03:00.0: amdgpu: SMU is resumed successfully!
[17942.186362] [drm] DMUB hardware initialized: version=0x07002A00
[17942.298206] thunderbolt 0-2: new device found, vendor=0x3d device=0x11
[17942.298214] thunderbolt 0-2: CalDigit, Inc. TS3 Plus
[17942.324529] pcieport 0000:00:03.1: pciehp: Slot(0-1): Card present
[17942.324536] pcieport 0000:00:03.1: pciehp: Slot(0-1): Link Up
[17942.412863] [drm] DMUB HPD IRQ callback: link_index=5
[17942.451551] pci 0000:06:00.0: [8086:15d3] type 01 class 0x060400 PCIe Switch Upstream Port
[17942.451603] pci 0000:06:00.0: PCI bridge to [bus 00]
[17942.451620] pci 0000:06:00.0:   bridge window [io  0x0000-0x0fff]
[17942.451627] pci 0000:06:00.0:   bridge window [mem 0x00000000-0x000fffff]
[17942.451649] pci 0000:06:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[17942.451670] pci 0000:06:00.0: enabling Extended Tags
[17942.451832] pci 0000:06:00.0: supports D1 D2
[17942.451835] pci 0000:06:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[17942.451965] pci 0000:06:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0000:00:03.1 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[17942.452267] pci 0000:06:00.0: Adding to iommu group 5
[17942.452347] pcieport 0000:00:03.1: ASPM: current common clock configuration is inconsistent, reconfiguring
[17942.455387] pci 0000:06:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[17942.455527] pci 0000:07:00.0: [8086:15d3] type 01 class 0x060400 PCIe Switch Downstream Port
[17942.455569] pci 0000:07:00.0: PCI bridge to [bus 00]
[17942.455581] pci 0000:07:00.0:   bridge window [io  0x0000-0x0fff]
[17942.455587] pci 0000:07:00.0:   bridge window [mem 0x00000000-0x000fffff]
[17942.455606] pci 0000:07:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[17942.455634] pci 0000:07:00.0: enabling Extended Tags
[17942.455789] pci 0000:07:00.0: supports D1 D2
[17942.455792] pci 0000:07:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[17942.456049] pci 0000:07:00.0: Adding to iommu group 5
[17942.456124] pci 0000:07:01.0: [8086:15d3] type 01 class 0x060400 PCIe Switch Downstream Port
[17942.456162] pci 0000:07:01.0: PCI bridge to [bus 00]
[17942.456172] pci 0000:07:01.0:   bridge window [io  0x0000-0x0fff]
[17942.456177] pci 0000:07:01.0:   bridge window [mem 0x00000000-0x000fffff]
[17942.456194] pci 0000:07:01.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[17942.456216] pci 0000:07:01.0: enabling Extended Tags
[17942.456365] pci 0000:07:01.0: supports D1 D2
[17942.456368] pci 0000:07:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[17942.456650] pci 0000:07:01.0: Adding to iommu group 5
[17942.456727] pci 0000:07:02.0: [8086:15d3] type 01 class 0x060400 PCIe Switch Downstream Port
[17942.456764] pci 0000:07:02.0: PCI bridge to [bus 00]
[17942.456775] pci 0000:07:02.0:   bridge window [io  0x0000-0x0fff]
[17942.456780] pci 0000:07:02.0:   bridge window [mem 0x00000000-0x000fffff]
[17942.456796] pci 0000:07:02.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[17942.456817] pci 0000:07:02.0: enabling Extended Tags
[17942.456958] pci 0000:07:02.0: supports D1 D2
[17942.456960] pci 0000:07:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[17942.457265] pci 0000:07:02.0: Adding to iommu group 5
[17942.457338] pci 0000:07:03.0: [8086:15d3] type 01 class 0x060400 PCIe Switch Downstream Port
[17942.457385] pci 0000:07:03.0: PCI bridge to [bus 00]
[17942.457397] pci 0000:07:03.0:   bridge window [io  0x0000-0x0fff]
[17942.457402] pci 0000:07:03.0:   bridge window [mem 0x00000000-0x000fffff]
[17942.457418] pci 0000:07:03.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[17942.457440] pci 0000:07:03.0: enabling Extended Tags
[17942.457583] pci 0000:07:03.0: supports D1 D2
[17942.457585] pci 0000:07:03.0: PME# supported from D0 D1 D2 D3hot D3cold
[17942.457801] pci 0000:07:03.0: Adding to iommu group 5
[17942.457878] pci 0000:07:04.0: [8086:15d3] type 01 class 0x060400 PCIe Switch Downstream Port
[17942.457916] pci 0000:07:04.0: PCI bridge to [bus 00]
[17942.457926] pci 0000:07:04.0:   bridge window [io  0x0000-0x0fff]
[17942.457931] pci 0000:07:04.0:   bridge window [mem 0x00000000-0x000fffff]
[17942.457947] pci 0000:07:04.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[17942.457968] pci 0000:07:04.0: enabling Extended Tags
[17942.458107] pci 0000:07:04.0: supports D1 D2
[17942.458109] pci 0000:07:04.0: PME# supported from D0 D1 D2 D3hot D3cold
[17942.458387] pci 0000:07:04.0: Adding to iommu group 5
[17942.458473] pci 0000:06:00.0: PCI bridge to [bus 07-64]
[17942.458493] pci 0000:07:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[17942.458505] pci 0000:07:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[17942.458517] pci 0000:07:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[17942.458528] pci 0000:07:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[17942.458540] pci 0000:07:04.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[17942.458729] pci 0000:08:00.0: [1b73:1100] type 00 class 0x0c0330 PCIe Endpoint
[17942.458769] pci 0000:08:00.0: BAR 0 [mem 0x00000000-0x0000ffff 64bit]
[17942.458793] pci 0000:08:00.0: BAR 2 [mem 0x00000000-0x00000fff 64bit]
[17942.458817] pci 0000:08:00.0: BAR 4 [mem 0x00000000-0x00000fff 64bit]
[17942.458955] pci 0000:08:00.0: supports D1
[17942.458957] pci 0000:08:00.0: PME# supported from D0 D1 D3hot D3cold
[17942.459020] pci 0000:08:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0000:00:03.1 (capable of 4.000 Gb/s with 5.0 GT/s PCIe x1 link)
[17942.459339] pci 0000:08:00.0: Adding to iommu group 5
[17942.461392] pci 0000:07:00.0: PCI bridge to [bus 08-64]
[17942.461413] pci_bus 0000:08: busn_res: [bus 08-64] end is updated to 08
[17942.461528] pci 0000:09:00.0: [1b73:1100] type 00 class 0x0c0330 PCIe Endpoint
[17942.461567] pci 0000:09:00.0: BAR 0 [mem 0x00000000-0x0000ffff 64bit]
[17942.461591] pci 0000:09:00.0: BAR 2 [mem 0x00000000-0x00000fff 64bit]
[17942.461618] pci 0000:09:00.0: BAR 4 [mem 0x00000000-0x00000fff 64bit]
[17942.461751] pci 0000:09:00.0: supports D1
[17942.461753] pci 0000:09:00.0: PME# supported from D0 D1 D3hot D3cold
[17942.461816] pci 0000:09:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0000:00:03.1 (capable of 4.000 Gb/s with 5.0 GT/s PCIe x1 link)
[17942.461973] pci 0000:09:00.0: Adding to iommu group 5
[17942.464392] pci 0000:07:01.0: PCI bridge to [bus 09-64]
[17942.464411] pci_bus 0000:09: busn_res: [bus 09-64] end is updated to 09
[17942.464524] pci 0000:0a:00.0: [1b21:1242] type 00 class 0x0c0330 PCIe Endpoint
[17942.464568] pci 0000:0a:00.0: BAR 0 [mem 0x00000000-0x00007fff 64bit]
[17942.464646] pci 0000:0a:00.0: enabling Extended Tags
[17942.464816] pci 0000:0a:00.0: PME# supported from D3hot D3cold
[17942.465035] pci 0000:0a:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0000:00:03.1 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link)
[17942.465307] pci 0000:0a:00.0: Adding to iommu group 5
[17942.467391] pci 0000:07:02.0: PCI bridge to [bus 0a-64]
[17942.467408] pci_bus 0000:0a: busn_res: [bus 0a-64] end is updated to 0a
[17942.467536] pci 0000:0b:00.0: working around ROM BAR overlap defect
[17942.467538] pci 0000:0b:00.0: [8086:1533] type 00 class 0x020000 PCIe Endpoint
[17942.467574] pci 0000:0b:00.0: BAR 0 [mem 0x00000000-0x0007ffff]
[17942.467607] pci 0000:0b:00.0: BAR 2 [io  0x0000-0x001f]
[17942.467625] pci 0000:0b:00.0: BAR 3 [mem 0x00000000-0x00003fff]
[17942.467863] pci 0000:0b:00.0: PME# supported from D0 D3hot D3cold
[17942.468149] pci 0000:0b:00.0: Adding to iommu group 5
[17942.469572] amdgpu 0000:c4:00.0: [drm] *ERROR* No EDID read.
[17942.470393] pci 0000:07:03.0: PCI bridge to [bus 0b-64]
[17942.470415] pci_bus 0000:0b: busn_res: [bus 0b-64] end is updated to 0b
[17942.470521] pci 0000:07:04.0: PCI bridge to [bus 0c-64]
[17942.470541] pci_bus 0000:0c: busn_res: [bus 0c-64] end is updated to 64
[17942.470550] pci_bus 0000:07: busn_res: [bus 07-64] end is updated to 64
[17942.470566] pci 0000:07:04.0: bridge window [mem 0x00100000-0x001fffff 64bit pref] to [bus 0c-64] add_size 100000 add_align 100000
[17942.470572] pci 0000:07:04.0: bridge window [mem 0x00100000-0x001fffff] to [bus 0c-64] add_size 100000 add_align 100000
[17942.470579] pci 0000:06:00.0: bridge window [mem 0x00100000-0x005fffff 64bit pref] to [bus 07-64] add_size 100000 add_align 100000
[17942.470584] pci 0000:06:00.0: bridge window [mem 0x00100000-0x005fffff] to [bus 07-64] add_size 100000 add_align 100000
[17942.470595] pci 0000:06:00.0: bridge window [mem 0x78000000-0x8fffffff]: assigned
[17942.470599] pci 0000:06:00.0: bridge window [mem 0x6c00000000-0x7bffffffff 64bit pref]: assigned
[17942.470603] pci 0000:06:00.0: bridge window [io  0xb000-0xffff]: assigned
[17942.470609] pci 0000:07:00.0: bridge window [mem 0x78000000-0x780fffff]: assigned
[17942.470613] pci 0000:07:00.0: bridge window [mem 0x6c00000000-0x6c000fffff 64bit pref]: assigned
[17942.470617] pci 0000:07:01.0: bridge window [mem 0x78100000-0x781fffff]: assigned
[17942.470620] pci 0000:07:01.0: bridge window [mem 0x6c00100000-0x6c001fffff 64bit pref]: assigned
[17942.470623] pci 0000:07:02.0: bridge window [mem 0x78200000-0x782fffff]: assigned
[17942.470626] pci 0000:07:02.0: bridge window [mem 0x6c00200000-0x6c002fffff 64bit pref]: assigned
[17942.470630] pci 0000:07:03.0: bridge window [mem 0x78300000-0x783fffff]: assigned
[17942.470633] pci 0000:07:03.0: bridge window [mem 0x6c00300000-0x6c003fffff 64bit pref]: assigned
[17942.470636] pci 0000:07:04.0: bridge window [mem 0x78400000-0x8fffffff]: assigned
[17942.470639] pci 0000:07:04.0: bridge window [mem 0x6c00400000-0x7bffffffff 64bit pref]: assigned
[17942.470643] pci 0000:07:00.0: bridge window [io  0xb000-0xbfff]: assigned
[17942.470646] pci 0000:07:01.0: bridge window [io  0xc000-0xcfff]: assigned
[17942.470649] pci 0000:07:02.0: bridge window [io  0xd000-0xdfff]: assigned
[17942.470652] pci 0000:07:03.0: bridge window [io  0xe000-0xefff]: assigned
[17942.470656] pci 0000:07:04.0: bridge window [io  0xf000-0xffff]: assigned
[17942.470660] pci 0000:08:00.0: BAR 0 [mem 0x78000000-0x7800ffff 64bit]: assigned
[17942.470682] pci 0000:08:00.0: BAR 2 [mem 0x78010000-0x78010fff 64bit]: assigned
[17942.470703] pci 0000:08:00.0: BAR 4 [mem 0x78011000-0x78011fff 64bit]: assigned
[17942.470723] pci 0000:07:00.0: PCI bridge to [bus 08]
[17942.470728] pci 0000:07:00.0:   bridge window [io  0xb000-0xbfff]
[17942.470736] pci 0000:07:00.0:   bridge window [mem 0x78000000-0x780fffff]
[17942.470743] pci 0000:07:00.0:   bridge window [mem 0x6c00000000-0x6c000fffff 64bit pref]
[17942.470753] pci 0000:09:00.0: BAR 0 [mem 0x78100000-0x7810ffff 64bit]: assigned
[17942.470774] pci 0000:09:00.0: BAR 2 [mem 0x78110000-0x78110fff 64bit]: assigned
[17942.470794] pci 0000:09:00.0: BAR 4 [mem 0x78111000-0x78111fff 64bit]: assigned
[17942.470814] pci 0000:07:01.0: PCI bridge to [bus 09]
[17942.470819] pci 0000:07:01.0:   bridge window [io  0xc000-0xcfff]
[17942.470826] pci 0000:07:01.0:   bridge window [mem 0x78100000-0x781fffff]
[17942.470832] pci 0000:07:01.0:   bridge window [mem 0x6c00100000-0x6c001fffff 64bit pref]
[17942.470842] pci 0000:0a:00.0: BAR 0 [mem 0x78200000-0x78207fff 64bit]: assigned
[17942.470862] pci 0000:07:02.0: PCI bridge to [bus 0a]
[17942.470867] pci 0000:07:02.0:   bridge window [io  0xd000-0xdfff]
[17942.470875] pci 0000:07:02.0:   bridge window [mem 0x78200000-0x782fffff]
[17942.470881] pci 0000:07:02.0:   bridge window [mem 0x6c00200000-0x6c002fffff 64bit pref]
[17942.470891] pci 0000:0b:00.0: BAR 0 [mem 0x78300000-0x7837ffff]: assigned
[17942.470900] pci 0000:0b:00.0: BAR 3 [mem 0x78380000-0x78383fff]: assigned
[17942.470910] pci 0000:0b:00.0: BAR 2 [io  0xe000-0xe01f]: assigned
[17942.470919] pci 0000:07:03.0: PCI bridge to [bus 0b]
[17942.470924] pci 0000:07:03.0:   bridge window [io  0xe000-0xefff]
[17942.470931] pci 0000:07:03.0:   bridge window [mem 0x78300000-0x783fffff]
[17942.470937] pci 0000:07:03.0:   bridge window [mem 0x6c00300000-0x6c003fffff 64bit pref]
[17942.470947] pci 0000:07:04.0: PCI bridge to [bus 0c-64]
[17942.470951] pci 0000:07:04.0:   bridge window [io  0xf000-0xffff]
[17942.470959] pci 0000:07:04.0:   bridge window [mem 0x78400000-0x8fffffff]
[17942.470965] pci 0000:07:04.0:   bridge window [mem 0x6c00400000-0x7bffffffff 64bit pref]
[17942.470974] pci 0000:06:00.0: PCI bridge to [bus 07-64]
[17942.470978] pci 0000:06:00.0:   bridge window [io  0xb000-0xffff]
[17942.470987] pci 0000:06:00.0:   bridge window [mem 0x78000000-0x8fffffff]
[17942.470992] pci 0000:06:00.0:   bridge window [mem 0x6c00000000-0x7bffffffff 64bit pref]
[17942.471002] pcieport 0000:00:03.1: PCI bridge to [bus 06-64]
[17942.471005] pcieport 0000:00:03.1:   bridge window [io  0xb000-0xffff]
[17942.471011] pcieport 0000:00:03.1:   bridge window [mem 0x78000000-0x8fffffff]
[17942.471016] pcieport 0000:00:03.1:   bridge window [mem 0x6c00000000-0x7bffffffff 64bit pref]
[17942.471454] pcieport 0000:06:00.0: enabling device (0000 -> 0003)
[17942.471691] pcieport 0000:07:00.0: enabling device (0000 -> 0003)
[17942.471920] pcieport 0000:07:01.0: enabling device (0000 -> 0003)
[17942.472182] pcieport 0000:07:02.0: enabling device (0000 -> 0003)
[17942.472458] pcieport 0000:07:03.0: enabling device (0000 -> 0003)
[17942.472912] pcieport 0000:07:04.0: enabling device (0000 -> 0003)
[17942.473175] pcieport 0000:07:04.0: pciehp: Slot #4 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[17942.473499] pci 0000:08:00.0: enabling device (0000 -> 0002)
[17942.473729] xhci_hcd 0000:08:00.0: xHCI Host Controller
[17942.473837] xhci_hcd 0000:08:00.0: new USB bus registered, assigned bus number 9
[17942.475259] xhci_hcd 0000:08:00.0: hcc params 0x200071e9 hci version 0x100 quirks 0x0000000000000010
[17942.475858] xhci_hcd 0000:08:00.0: xHCI Host Controller
[17942.475908] xhci_hcd 0000:08:00.0: new USB bus registered, assigned bus number 10
[17942.475911] xhci_hcd 0000:08:00.0: Host supports USB 3.0 SuperSpeed
[17942.475957] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[17942.475960] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[17942.475962] usb usb9: Product: xHCI Host Controller
[17942.475963] usb usb9: Manufacturer: Linux 6.12.15-200.fc41.x86_64 xhci-hcd
[17942.475965] usb usb9: SerialNumber: 0000:08:00.0
[17942.476148] hub 9-0:1.0: USB hub found
[17942.476168] hub 9-0:1.0: 4 ports detected
[17942.476484] usb usb10: We don't know the algorithms for LPM for this host, disabling LPM.
[17942.476501] usb usb10: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
[17942.476504] usb usb10: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[17942.476505] usb usb10: Product: xHCI Host Controller
[17942.476507] usb usb10: Manufacturer: Linux 6.12.15-200.fc41.x86_64 xhci-hcd
[17942.476508] usb usb10: SerialNumber: 0000:08:00.0
[17942.476626] hub 10-0:1.0: USB hub found
[17942.476644] hub 10-0:1.0: 4 ports detected
[17942.476867] pci 0000:09:00.0: enabling device (0000 -> 0002)
[17942.477097] xhci_hcd 0000:09:00.0: xHCI Host Controller
[17942.477142] xhci_hcd 0000:09:00.0: new USB bus registered, assigned bus number 11
[17942.478528] xhci_hcd 0000:09:00.0: hcc params 0x200071e9 hci version 0x100 quirks 0x0000000000000010
[17942.479272] xhci_hcd 0000:09:00.0: xHCI Host Controller
[17942.479303] xhci_hcd 0000:09:00.0: new USB bus registered, assigned bus number 12
[17942.479305] xhci_hcd 0000:09:00.0: Host supports USB 3.0 SuperSpeed
[17942.479341] usb usb11: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[17942.479343] usb usb11: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[17942.479345] usb usb11: Product: xHCI Host Controller
[17942.479346] usb usb11: Manufacturer: Linux 6.12.15-200.fc41.x86_64 xhci-hcd
[17942.479348] usb usb11: SerialNumber: 0000:09:00.0
[17942.479524] hub 11-0:1.0: USB hub found
[17942.479540] hub 11-0:1.0: 4 ports detected
[17942.480121] usb usb12: We don't know the algorithms for LPM for this host, disabling LPM.
[17942.480138] usb usb12: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
[17942.480141] usb usb12: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[17942.480142] usb usb12: Product: xHCI Host Controller
[17942.480143] usb usb12: Manufacturer: Linux 6.12.15-200.fc41.x86_64 xhci-hcd
[17942.480145] usb usb12: SerialNumber: 0000:09:00.0
[17942.480450] hub 12-0:1.0: USB hub found
[17942.480465] hub 12-0:1.0: 4 ports detected
[17942.480816] pci 0000:0a:00.0: enabling device (0000 -> 0002)
[17942.480994] xhci_hcd 0000:0a:00.0: xHCI Host Controller
[17942.481317] xhci_hcd 0000:0a:00.0: new USB bus registered, assigned bus number 13
[17942.540281] xhci_hcd 0000:0a:00.0: hcc params 0x0200eec0 hci version 0x110 quirks 0x0000000000800010
[17942.540713] xhci_hcd 0000:0a:00.0: xHCI Host Controller
[17942.540776] xhci_hcd 0000:0a:00.0: new USB bus registered, assigned bus number 14
[17942.540779] xhci_hcd 0000:0a:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[17942.540909] usb usb13: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[17942.540911] usb usb13: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[17942.540912] usb usb13: Product: xHCI Host Controller
[17942.540913] usb usb13: Manufacturer: Linux 6.12.15-200.fc41.x86_64 xhci-hcd
[17942.540914] usb usb13: SerialNumber: 0000:0a:00.0
[17942.541143] hub 13-0:1.0: USB hub found
[17942.541157] hub 13-0:1.0: 2 ports detected
[17942.541248] usb usb14: We don't know the algorithms for LPM for this host, disabling LPM.
[17942.541264] usb usb14: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
[17942.541266] usb usb14: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[17942.541267] usb usb14: Product: xHCI Host Controller
[17942.541268] usb usb14: Manufacturer: Linux 6.12.15-200.fc41.x86_64 xhci-hcd
[17942.541269] usb usb14: SerialNumber: 0000:0a:00.0
[17942.541389] hub 14-0:1.0: USB hub found
[17942.541398] hub 14-0:1.0: 2 ports detected
[17942.542143] igb 0000:0b:00.0: enabling device (0000 -> 0002)
[17942.572579] igb 0000:0b:00.0: added PHC on eth0
[17942.572612] igb 0000:0b:00.0: Intel(R) Gigabit Ethernet Network Connection
[17942.572615] igb 0000:0b:00.0: eth0: (PCIe:2.5Gb/s:Width x1) 64:4b:f0:18:f1:bc
[17942.572695] igb 0000:0b:00.0: eth0: PBA No: 000300-000
[17942.572696] igb 0000:0b:00.0: Using MSI-X interrupts. 4 rx queue(s), 4 tx queue(s)
[17942.576760] igb 0000:0b:00.0 enp11s0: renamed from eth0
[17942.804821] usb 12-4: new SuperSpeed USB device number 2 using xhci_hcd
[17942.818606] usb 12-4: New USB device found, idVendor=2188, idProduct=0747, bcdDevice=10.38
[17942.818613] usb 12-4: New USB device strings: Mfr=3, Product=4, SerialNumber=5
[17942.818616] usb 12-4: Product: Card Reader
[17942.818618] usb 12-4: Manufacturer: CalDigit
[17942.818620] usb 12-4: SerialNumber: 000000000010
[17942.820160] usb-storage 12-4:1.0: USB Mass Storage device detected
[17942.820515] scsi host0: usb-storage 12-4:1.0
[17943.371671] amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[17943.371678] amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[17943.371680] amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[17943.371682] amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
[17943.371684] amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
[17943.371686] amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
[17943.371688] amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
[17943.371690] amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
[17943.371692] amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
[17943.371694] amdgpu 0000:03:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
[17943.371696] amdgpu 0000:03:00.0: amdgpu: ring sdma1 uses VM inv eng 13 on hub 0
[17943.371697] amdgpu 0000:03:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
[17943.371699] amdgpu 0000:03:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
[17943.371701] amdgpu 0000:03:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 14 on hub 0
[17943.377377] amdgpu 0000:03:00.0: [drm] Cannot find any crtc or sizes
[17943.378099] [drm] ring gfx_32790.1.1 was added
[17943.378458] [drm] ring compute_32790.2.2 was added
[17943.378799] [drm] ring sdma_32790.3.3 was added
[17943.378846] [drm] ring gfx_32790.1.1 ib test pass
[17943.378885] [drm] ring compute_32790.2.2 ib test pass
[17943.378942] [drm] ring sdma_32790.3.3 ib test pass
[17943.839257] scsi 0:0:0:0: Direct-Access     CalDigit Card Reader      1038 PQ: 0 ANSI: 6
[17943.839828] sd 0:0:0:0: Attached scsi generic sg0 type 0
[17943.840416] sd 0:0:0:0: [sda] Media removed, stopped polling
[17943.841063] sd 0:0:0:0: [sda] Attached SCSI removable disk
[17944.540413] usb 9-2: new full-speed USB device number 2 using xhci_hcd
[17944.674864] usb 9-2: New USB device found, idVendor=2188, idProduct=6533, bcdDevice= 1.01
[17944.674872] usb 9-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[17944.674876] usb 9-2: Product: CalDigit Thunderbolt 3 Audio
[17944.674878] usb 9-2: Manufacturer: CalDigit, Inc.
[17944.710690] input: CalDigit, Inc. CalDigit Thunderbolt 3 Audio as /devices/pci0000:00/0000:00:03.1/0000:06:00.0/0000:07:00.0/0000:08:00.0/usb9/9-2/9-2:1.3/0003:2188:6533.0021/input/input44
[17944.761736] hid-generic 0003:2188:6533.0021: input,hidraw15: USB HID v1.11 Device [CalDigit, Inc. CalDigit Thunderbolt 3 Audio] on usb-0000:08:00.0-2/input3
Just tried the dock with a FW13 running a Fedora 41 live image and am having the same issue. The monitor only presents itself as 640x480
Just tried with a different monitor and it works. I guess I gotta return these monitors. These are what I was trying to work with
https://www.newegg.com/msi-pro-mp275q-27-qhd/p/N82E16824475369
What’s weird is they support DP 1.2a
You should try the patch on this bug in case it also affected caldigit.
Also make sure there is not some settings you are missing, and that the cables being used are correct. Also double check the CalDigit details it may require active cables for the displayport connection. In my experience it is more often the dock that is the problem.
The problem seems to be here:
Sounds like the monitors are failing to communicate. Especially considering a different monitor works no problem. I’ll try that patch though. Could help.
