Which Linux distro are you using? Ubuntu
Which release version? 22.04 LTS
Which kernel are you using? 6.8.0-48-generic #48~22.04.1-Ubuntu
Which BIOS version are you using? 3.03
Which Framework Laptop 16 model are you using? AMD Ryzen™ 7040 Series
I have finally upgraded my network to Wifi7. Every other device in my house that supports 6e or 7 connects to my new TP-Link EAP773’s with no issue on the dedicated 6GHz SSID I created. However, my FW 16 refuses to connect.
I first thought that it was something with WPA3, but even switching to Enhanced Open security resulted in the same failure.
NetworkManager[1245]: <warn> [1733178606.6143] device (wlp1s0): Activation: (wifi) association took too long, failing activation
When I look in Network Manager, it shows this as a 2.4/5GHz network, when it is actually a pure 6GHz network (I separate my SSIDs by frequency):
I tried creating a joined 5/6GHz SSID and the FW16 only connects to the 5GHz band and never shows 6GHz as even a supported frequency in NM.
Anybody have any ideas on this? My searches have led mostly to solutions that either don’t apply to Network Manager or didn’t have any effect. The only other posts I found in this community apply to the Intel Wifi, not the MediaTek that ships with the AMD units.
