Can't use keyboard.frame.work after firware upgrade?
Haven’t messed with the keyboard website in a while, after going to it today, I cant seem to manage my keyboard or numpad?
Errors below:
22:21:31.713
* NotAllowedError: Failed to open the device.
* Device: Framework Laptop 16 Keyboard Module - ANSI
* Vid: 0x32AC
* Pid: 0x0012
22:21:31.740
* Received invalid protocol version from device
* Vid: 0x32AC
* Pid: 0x0012
Any ideas?
I tried messing with the permissions of /dev/hidraw12 and that worked… once
I tried qmk udev rules, I tried the Framework udev rules, neither seems to work..
Downgraded the keyboard firmware - same issue.
Just a bump on this - can someone running Fedora, on the current firmware, confirm if they can access keyboard.frame.work?
I have no problems on Bazzite (very fancy Fedora Silverblue/Kinoite).
Framework Laptop 16"
Bazzite Linux 43 (GNOME) (whatever the latest minor version is, I have it)
UEFI/BIOS 4.0.2
ANSI Keyboard (1st gen) firmware 0.31
Numpad (1st gen) firmware 0.31
I assume you did the udev rules?
Can you give me the output of:
ls -l /dev/hidraw*
And:
ls -l /etc/udev/rules.d/
So I finalyl got this fixed.
I pulled the udev rules provided from the guides here - provided by @Matt_Hartley :
wget https://raw.githubusercontent.com/qmk/qmk_firmware/master/util/udev/50-qmk.rules && sudo cp 50-qmk.rules /etc/udev/rules.d/ && sudo udevadm control --reload-rules && sudo udevadm trigger
And, even after following the guide, it wouldn’t work (I did this guide like 15 times… just saying)
I am not sure whats going on, but I did notice a couple things:
1. VendorID 32ac is not in the above list
2. hidraw for me is all owned by "root:root" and I do not have a goup "plugdev"
So I finally decided to append the following to the udev rules:
SUBSYSTEMS=="usb", ATTRS{idVendor}=="32ac", ATTRS{idProduct}=="0014", TAG+="uaccess"
SUBSYSTEMS=="usb", ATTRS{idVendor}=="32ac", ATTRS{idProduct}=="0012", TAG+="uaccess"
And it worked.. Not sure what changed, and why I had to add that manually now - but might be worth adding this to the official guide if the other one is going to be finicky.
I don’t understand what that means, so I think no.
The only time I touch terminal was to enable Bluetooth LE Audio and LC3 codec (edit: except fwupdmgr related commands). Even then I believe I did not execute commands, only edited config files.
crw-rw-rw-. 1 root root 241,  0 Nov 21 04:53 /dev/hidraw0
crw-rw-rw-+ 1 root root 241,  1 Nov 21 02:30 /dev/hidraw1
crw-rw-rw-+ 1 root root 241, 10 Nov 21 02:30 /dev/hidraw10
crw-rw-rw-+ 1 root root 241, 11 Nov 21 06:29 /dev/hidraw11
crw-rw-rw-+ 1 root root 241,  2 Nov 21 02:30 /dev/hidraw2
crw-rw-rw-+ 1 root root 241,  3 Nov 21 02:30 /dev/hidraw3
crw-rw-rw-+ 1 root root 241,  4 Nov 21 02:30 /dev/hidraw4
crw-rw-rw-+ 1 root root 241,  5 Nov 21 02:30 /dev/hidraw5
crw-rw-rw-+ 1 root root 241,  6 Nov 21 02:30 /dev/hidraw6
crw-rw-rw-+ 1 root root 241,  7 Nov 21 02:30 /dev/hidraw7
crw-rw-rw-+ 1 root root 241,  8 Nov 21 02:30 /dev/hidraw8
crw-rw-rw-+ 1 root root 241,  9 Nov 21 02:30 /dev/hidraw9
total 0
Any chance this is fixed in fwupd 2.0.17? They fiddled with Framework hardware in that version too. Or that is not tied to fwupd in any way?
Sorry, I had a brain fart and mixed forum threads in my head.
No worries!!
If you check above, I figured it out w/my udev rules.
I haven’t mess w/Bazzite much - but I wonder if your setup (Atomic) keeps you from needing the udev rules :person_shrugging:
Either way, a slight change to the udev rules fixed me up :slight_smile:
This worked! Tysm
That covers the USA/ansi keyboard and the numpad.
All of the current FWL16 keyboards:
USB [VendorID]:[ProductID] “[Manufacturer][Product name]”
32ac:0012 “Framework Laptop 16 Keyboard Module - ANSI”
32ac:0013 “Framework Laptop 16 RGB Macropad”
32ac:0014 “Framework Laptop 16 Numpad Module”
32ac:0018 “Framework Laptop 16 Keyboard Module - ISO”
32ac:0019 “Framework Laptop 16 Keyboard Module - JIS”
So, to cover all:
SUBSYSTEMS=="usb", ATTRS{idVendor}=="32ac", ATTRS{idProduct}=="0013", TAG+="uaccess"
SUBSYSTEMS=="usb", ATTRS{idVendor}=="32ac", ATTRS{idProduct}=="0018", TAG+="uaccess"
SUBSYSTEMS=="usb", ATTRS{idVendor}=="32ac", ATTRS{idProduct}=="0019", TAG+="uaccess"
@Destroya I was unable to find this documented anywhere - and the previous method Framework-provided was not sufficient with the new firmware
Can we get a new post thats pinned with these udev rules for linux users?
As more ppl are getting around to upgrading their firmware, this is likely to be asked more
Looks like this may be a systemd bug issue, which has bitten many many people. And the best solution for qmk hasn’t been decided yet
TAG+="uaccess" does sound like the way to go though.
New FW16 AI 300 series on a fresh install of Fedora 43 KDE here - this wasn’t working for me, but adding all the udev rules specified by @MJ1 the way that @knipp30 did fixed it for me. Thank you both!
