Windows 11
BIOS 3.0.2
Have gpu
180w charger
Only usb a and one usb c cards
Frequently cannot charge the framework.
Sometimes i can charge after removing AC power from the charger and plugging it back in. Other times not. All my other usb c PD cables either don’t work, or charge for 5 seconds, then stop, then charge for 5 more seconds, then stop.
Factory cable charges for awhile, but then stops and my battery dies.
If i use the back left port, i get some success, but if i use the back right slot, Windows reports that usb port doesn’t support charging, even though it worked a week ago.
Ive tried reseating the usb c card, moving it around, and using a different card. Rebooting has no effect other than sometimes making it stop charging if was already working.
Sorry to hear about your charging not working on your FW16 machine. Do you have another USBC charger to try? I was impressed that the little 30W USBC PD charger that came with my Pixel 7 charges both the FW13 and FW16.
Definitely contact support to help them work with you. You might need to reset the Mainboard if something is going on with the Embedded Controller that is shutting down the charging and which ports it is allowing.
Let us know how it turns out. If the other charger works like a charm then the 180W might just be out of spec/not talking correctly and the laptop is shutting it down to protect itself.
I see a bunch of such issue all over the places. Here, reddit and other forum. I can’t always answer everywhere and help everyone unfortunately.
Is this being investigated at Framework ?
This seem to be really related to an EC bug. It would be nice to have some official feedback or recognition about this. I couldnt find anything in the FAQ or any official KB.
I still need to do this trick at least 1 time every one/two month or so while using different charger (official one at home, various 65w/100w docking stations at work)
cc @Destroya@Matt_Hartley
Just in case, here are some info that might help:
FW16 batch1 here on Fedora40 fully updated, kernel 6.10.x and also testing the 6.11.0-RCx line.
I was going to create a new post, but I saw this one, and it is almost the exact same issue I am experiencing, so I’m going to bump this thread and piggyback on it.
I have a 13 (Windows 11, 13th gen Intel) and it began to intermittently charge, then stopped altogether. I have two chargers, and two USB-C cards. Right side won’t recognize any USB devices, left side will read media but not charge. Updated BIOS, drivers, and reset the mainboard with no change. Can charge by bypassing the EC. Rebooting by long pressing the power button will restore charging functionality, but only for a few minutes.
Someone just had a similar issue with I think a FW13 13th gen machine. His was data only on the right side but no charging.
If you have time and the parts try this:
Try powering the mainboard by itself outside of the laptop. Ideally you would have a HDMI/Display port plugged into one of the other expansion slots and a USB keyboard.
In his case, there was something strange with the battery connector that was causing his issue, he got it to boot stand-alone and when it was all put back together it all started working again correctly. Worth a shot! (Be sure to ground yourself and rest the board on something nonconductive like a piece of paper or cardboard)
Just for future users: I had the same issue, both my USB ports were not charging. Long press on power button to reset fixed the problem, at least for now (only did it 10 minutes ago, and definitely charging up).
I hope Framework find the root cause and prevent it in the future.
I have a brand new FW16 and am having this same issue. The included 180W power supply will not power the laptop during use, but I recently bought an Anker 140W supply and it charges it fine, reporting a draw of 54W on the digital display.
