That is the only area. I noticed that in the RAM area also have connection?
Sorry, I don’t really understand. You want to check the RAM too?
I don’t think that RAM is a problem, because the LED blink code would have been different then.
Ok, I did unplugging the Display connection and reconnect it again. It still nothingness. Nothing to showing to me in the Display.
Ok, well done. At least now you are pretty sure that there is an issue with the display!
Now the official Framework Support will tell you what to do.
The only thing that I notice the Framework Laptop is noisy fan.
Yes but when there is a hardware issue like that, with LED error codes etc, it’s common that the fans make a really loud noise.
Maybe when you get a functional display the fan noise will disappear naturally.
I have first hand experience of this phenomenon.
It can be a different problem, for sure, but first thing would be to try solving the display issue.
Maybe Support will have you try an external display, using the HDMI port.
You should power down the machine by the way, I don’t think there is a need to keep it powered up.
The same. Had a faulty ram that prevented the laptop to boot, it had the exact same behaviour.
I am the person who travel many places, So, i do not carry more stuff.
You mean you don’t have a HDMI adapter?
I do not have one of those HDMI adapter.
Ok, right, sorry.
Maybe Support will know what to do then.
If you have not yet installed an operating system, the fan will be running at full speed as there is nothing to properly control it. Once you get help with your display and get an operating system installed your fan should quiet down.
@Omega21 I’m aware, I just wanted to calm your fears about the fan being too loud since you’ve brought it up a few times in the thread.
I did message to FrameWork Team and send 3 videos as proof of the laptop defectiveness. And not much help at all.
I too had this problem. My problem was the connector cable on the display end was slightly loose (not totally seated). I seated the connector and all was well. Check both ends of the cable.
I better get my refund money to me. I know this Framework Laptop is the first product of the company. I really have bad experience. I better get the version as Ready-to-use Framework Laptop. I feel as lost hope with Framework Laptop. I asked the Framework Team for repair, they said that I need pay extra fee for repair. It is only the RAM and M.2 SSD are the 2 component plus, 4 expansion cards.
