Consistent freezing just before suspend when using dGPU
Which Linux distro are you using? Fedora
Which release version? 42
Which kernel are you using? 6.14.9
Which BIOS version are you using? 3.05
I have noticed that whenever I have the dGPU installed, it seems that the system freezes just before the suspend happens as the last frame is still kept for a few seconds. I could not replicate this behavior when running with just the integrated GPU. While it may sound like nothing but a slight annoyance, I feel like there is a bigger issue hiding here as this is clearly not how suspend should behave. Has anyone else also experienced this exact problem?
I think the issue was resolved when I removed some kernel parameters that were disabling Panel Self Refresh (PSR) because of the corruption issues mentioned here, which are now fixed.
