Framework 16 under Fedora crashes when resuming from suspend with display attached to dGPU
Hey all! I’m having a problem with Fedora 42 where I resume from suspend (or boot from off) with a monitor plugged into the back dGPU port and the machine with either crash (resume from suspend) or not boot (booting from off). When I unplug the monitor from the dGPU port, the machine boots without issue.
Does anyone know why this could be happening? This did not happen prior to Fedora 42.
Fedora
Which release version?
Fedora 42
Which kernel are you using?
Linux 6.14.3-300.fc42.x86_64
03.05
Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series)
AMD Ryzen 9 7940HS w/ Radeon 780M Graphics
AMD Radeon RX 7700S [Discrete]
Probably related to Graphics card not available
I don’t think there’s a workaround unfortunately but a kernel fix is coming I believe
