Hello everyone, I’m working on a project to create emembership cards for our nonprofit organization using Linux. While developing the software, I’m facing some technical challenges:
Integration issues: Connecting the membership database with the card generation system is giving unexpected results.
QR code generation problems: Generating and embedding QR codes into the digital membership card reliably is proving difficult, especially for distribution via email or mobile wallets.
I’m looking for advice or recommendations on:
Linux-compatible tools or libraries for digital card generation
Reliable QR code generation and embedding approaches
Examples of successful implementations for nonprofits
Any insights, sample workflows, or tips would be greatly appreciated!
Hey @lyriq , this sounds like a great project and you’re on the right track. From my experience, it’s usually better to keep your system modular instead of tightly coupling the database with the card generation process. You can create a simple backend API (using something like Python Flask or Node.js) that handles member data, and then a separate service that generates the digital cards using HTML templates rendered into PDF or image format. This approach helps avoid the integration issues you’re facing and makes debugging much easier. For QR code generation on Linux, tools like qrencode or libraries such as Python’s qrcode or Node’s qrcode package are quite reliable. One important tip is to encode a secure verification URL (like a unique token linked to your database) instead of embedding raw user data inside the QR. This improves both security and flexibility. You can generate the QR as a PNG or SVG and then embed it into your card design using HTML/CSS, and convert it using tools like wkhtmltopdf or Puppeteer for consistent output.
When it comes to distribution, try to keep the cards mobile-friendly and ensure the QR code is high resolution with proper contrast so it scans easily across devices. A common workflow is: generate a unique token for each member, create the QR code, render the card, and then send it via email or provide it through a user dashboard. Also, consider adding validation logic like expiry or scan tracking for better security and analytics. This kind of setup is already widely used in digital membership systems, and once structured properly, it becomes quite scalable and reliable.
I don’t think it is too difficult to create QR codes.
For example, I typed “example rust program to create qr codes” into gemini and it creates a nice simple .png file. gemini write it in any programming language you wish.
QR codes are generally easier to decode than bar codes, so changing from a bar code to a QR code is a good idea.
Here is an example output .png file, but it can output in any format you wish.
In general uncompressed formats such as .png are better than compressed formats like .jpg.
