Cursor randomly stuck in lower right corner until reboot
I have come across an issue that I am unsure how to troubleshoot. On occasion, my cursor will be stuck in the lower right corner. This seems to happen upon entering the desktop environment. The only fix is to use an external mouse only or reboot. When it is in this state, the external mouse will move the cursor as normal but when I touch the trackpad, the cursor immediately returns to the lower right…so really the only workaround I have is to reboot.
Setup:
Operating System: Arch Linux
KDE Plasma Version: 6.5.5
KDE Frameworks Version: 6.23.0
Qt Version: 6.10.2
Kernel Version: 6.18.9-arch1-2 (64-bit)
Graphics Platform: Wayland
Processors: 12 × 13th Gen Intel® Core™ i5-1334U
Memory: 32 GiB of RAM (31.1 GiB usable)
Graphics Processor: Intel® Graphics
Manufacturer: Framework
Product Name: Laptop 12 (13th Gen Intel Core)
System Version: A5
I know enough to be dangerous in Linux, but not enough to know where to start troubleshooting so any help would be appreciated.
This also happens on my FW12; sometimes opening up the machine and re-seating the input module helps, but usually i have to use a mouse or reboot to use the machine :confused:
I also have this issue on Arch with KDE, and only on my FW12, not my desktop which has a very similar software setup.
FWIW I only see it happen immediately after logging in, never later on during a session. It resolves itself without a reboot if I logout using the keyboard, touch the trackpad on the login screen and log back in. Still annoying regardless. Not sure if it’s a software or hardware issue, but seems more likely the former if relogging fixes it.
