Dedicated GPU Module not working with external Displays using Display Port alt mode
Fedora 43 beta
Which release version?
Ran dnf update today
Which kernel are you using?
Linux 6.17.0-0.rc7.56.fc43.x86_64
Newest (?)
Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series)
I have a AMD Ryzen™ 9 7940HS with the AMD Radeon™ RX 7700S GPU Module
When I try to use the usb c port on the GPU module with DP alt mode and MST to connect two monitors, I don’t get any output on my Monitors, even though the Settings App shows the two monitors as available, but doesn’t let me enable them, stating that it might be “due to hardware limitations”
When I open an app and tell it to specifically use the dGPU using DRI_PRIME=1 to wake it up completely they show up as enabled in the settings but still don’t show anything.
When I run journalctl --follow and try to enable one of the monitors (without an app started using DRI_PRIME=1) I find this message: gnome-control-center[5316]: Config not applicable: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: No available primary plane found for CRTC 84 (/dev/dri/card1)
I also asked about this over on the Discord Server (might wanna read that if I forgot abt anything I did): Discord
Are you able to get 1 monitor to work with the DP expansion card?
