Diffrences between the 16" performance and pro performance
Hello,
Was curious what the differences between the two of them are!
and if the USBC is also standard 4, which acts like a thunderbolt for EGPU
thanks!
The only difference between the 16" Performance and 16" Performance Pro is that the later comes with Windows 11 Pro and the former comes with Windows 11 Home.
Welcome to the forum.
Take a look here (the spec tab, Interfaces section)
It tells you which slots can do what. The back most slot on the left and right are full USB 4. Functionally equivalent to thunderbolt. Just not called thunderbolt because thunderbolt certification is done by intel.
