Hello,
I would like to get a Framework Laptop to use at work and privately.
To do this, I would like to use two storage expansion cards, each of them with an own operating system. The laptop itself would not contain any hard disk. During work only the extension A would be plugged, when used privately only the extension B
This way I would like to prevent a malware that infects system A to infiltrate system B and vice versa.
Is this setup possible or is it strictly necessary to have a hard disk? As far as I know the speed of the expansion cards is quite well, so I don’t bother there too much. Does this setup make sence anyway?
Thanks in advance
