So you have everything and context :
AMD Ryzen 9 7940HS w/ Radeon 780M Graphics
AMD Radeon™ RX 7700S
31 GB RAM, Windows 11, BIOS: 04.04
Never had an issue I couldn’t solve with my Framework 16 until now, and it seems the support couldn’t pinpoint my problem either so here I am. I keep replacing my fans every 6 months. It begins with overheating, then the fan start making a rattling sound and copper thread go loose. I often need to remove them as they obstruct the fans- I have other weird issues going with it, like my dedicated GPU acting up at the same time as the fan (even though the temp state it is pretty much fine, never going above 75-80 degree). Then I have so much artifacts on my screen it just seems dead. Restarting or shutting it down has no effect, I need to wait 24 to 72 hours before everything is back to normal (except for the fans-) I can keep changing the fans but it’s getting very expensive in the long run and I really wish to understand why it is that way. I thought about an issue with the processor but I don’t know? It doesn’t really make sense to me. It is to note that the overheating is never caused by dust or thermal paste issues. I make sure to clean everything every one or two months and regularly change the thermal paste. Any idea on why everything is the way it is?
This seems like it might be related… The earliest boards came with liquid metal TIM and later boards have PTM. Liquid metal should be replaced with PTM, but then the PTM should be good for a long time.
Are you sure you didn’t lose part of the heatsink switching from liquid metal to thermal paste? There’s a “honeycomb pad” attached to the original heatsink that is pretty easy to pop off accidentally (I thought it was part of the liquid metal pad originally
) and if you are missing it, then you might be running hot with no effective cooling (paste doesn’t maintain good contact with heatsink or is too thick), which would run the fans all the time and burn them out fast.
Thank you for the lead. I didn’t lose it but it was pretty damaged last time I repasted the cpu. I don’t know if they sell them but I will look it up.
Thank you for your answer, I didn’t think of that at all, I’ll dig into i
Unfortunately, you have to get an entire replacement heatsink to replace that plate.
But there are forum members here that have made their own copper shims to replace it, which might be an option for you.
It’s a huge thread, but there is a ton of information in here: Uneven CPU thermals!
Let me guess…you live on Venus?
Changed the ptm and the damaged pad. I still have a lot to learn but this issue is resolved thanks to you. Have a great day!
