Feature Request Megathread - Expansion Card
So many people really want a dual port expansion card for usb-c, or usb-a. While those might be possible, something I was thinking of was like a usb hub but for expansion cards. I’m not much of an electrical engineer, but I don’t think this would be too hard, especially if we can have a bit more space in the expansion hub right?
Wasn’t letting me edit, gave me error 500, so I did this as a reply
Edit: to explain the idea further, I was think that one expansion card slot on the computer could be used for two expansion cards
Not actually plugged directly into the laptop, but I have seen somewhere in one of the expansion card threads that someone was musing about building an external enclosure to plug multiple expansion cards into, almost like a USB dock.
Yeah that is what I was thinking
Would be possible, maybe I could attempt to make a hub station.
Are the Expansion Slots Set to be Hot swappable by default for the storage Expansion Card, like a USB, or are the set by default to be more like internal storage?
@Skyline1029 They are essentially a flash drive.
Good to know. I figured but wanted to double-check because they did talk about using it as a boot for Chrome OS.
Correct me if I’m wrong, but it honestly sounds like your talking about this pre-existing discussion:
I don’t know much about hardware design so I could be off base, but I feel like a 4-8 port usb-c hub could be made that could have expansion slots to hold cards and make a configurable USB hub.
It’d also be a convenient holder for extra cards.
I couldn’t find any posts talking about such an idea, but I could just be bad at searching so let me know if it’s been done already
Here’s another thread discussing this:
Here’s another:
Also in this thread:
http://community.frame.work/t/usb-c-thunderbolt-dock-megathread/1460/70
for gpus, storage, networking, etc.
Just no.
------20 chars-----
Its definitely possible, just much more impractical than the ADT Link eGPU setup some are using
I would think you’d still be bottlenecked by the USB-C adapter on the laptop. Maybe x4 would be a better fit, which would essentially be an NVMe to USB-C adapter.
Define possible. I’m siding with Josh Cook.
I was actually just doing research on eGPUs. Probably right on the bottleneck. What would be cool is if you could hook up a GPU to a framework laptop.
You can. Plenty of threads about it. Besides, where would these 16 lanes come from? It’s not like the laptop has lanes to spare, every lane available from the CPU has been allocated already. 4 lanes to each of the TB4 ports and 4 lanes to the m.2 makes 20 lanes, which is every lane available.
