Saw this “45W sustained” wording on a slide from Andrew Marc David’s review:
Can anyone confirm if they’re able to run the FL13 Pro at 45W sustained?
Link to the video: https://youtu.be/TUsrbVveDaI?t=1341
On my FW13 Pro, the maximum sustained package power is only programmable up to 35W
To be fair it also took a while for us to figure oput how to get more than 35W sustained out of the amd platforms when those came out so life may still find a way XD
I believe 35W is the current industry power limit for single fan systems. Most laptops featuring X7 358H have dual fans design that’s why they can boost up to 80W and have sustained 45W or even 60W mode.
Framework is trying to compete with Apple and they also use dual fans for M Pro and Max series.
Regular M5 has single fan cooling and uses ~28W in sustained mode.
TLDR; if you want more performant chip get more efficient rather than use more power. Apple and Qualcomm show it’s possible
