Flashing Red Lights FW16/no attempt to boot
Having more issues, just tried to turn my computer on and the display was flickering ever couple of seconds, so naturally i tried to restart it and it wont boot. Im on Windows 11, latest bios/driver package. For a moment it tried to repair my drive, but now all it does when the power button is pressed is blink the status lights red twice. I tried booting without the graphics card to at least get into bios or boot from safe mode but alas no luck. I could have also sworn fro a moment the light blinked orange and green. When I plug it in the light goes white as it should (or blinks red when the input modules and midplate are removed. No clue what to do.
Edits:
Without battery, blinks red/blue, probably cause it’s missing the battery.
Acts sorta normal if the “sw3” switch is held down. But with 0 signs of life.
Sometimes after I press sw3 and hit the power button it blinks red 6 times. I believe this is important because the second flash in the original 2 seems to be cut short.
Attached the midplate cable, red light blinked 15 times (?)
I was submitting a support ticket and it did a POST diagnostic! Sadly, I didn’t catch it in time to write it down, so no clue what it said. I’ve tried replicating it to no avail.
Left for a second and came back to it, no signs of life except when I remove the battery while its plugged in, it does the red/blue. On putting the battery back in, it has returned to the 2 blinks.
I am honestly so sick of this computer.
Contact FW support via their Web site.
It is only other users like you here.
If it helps, trying to boot into the bios of a healthy FW16 with the keyboard and battery removed does not successfully boot. So it makes it difficult to diagnose problems.
