Framework 12 Crashing
Hey, I’ve been running discord and tried using Fantasy Grounds on steam using arch. After about 20mins or any large use of a map/minor graphics, the system locks up and doesn’t respond to anything short of a full reboot. I’m running the same setup on a minisforum pc, and it seems to work fine there so I have to assume its a hardware issues. Any suggestions?
Also, apparently I can’t use the Arch tag, which is odd, but this is arch.
Try different distro, or debug more what is actually crashing. Might be bug in a library, or configuration.
(Different distro, might be using different versions, or even different libraries altogether)
Appreciate the comment. I ran a DMESG to see if there were any errors, but didn’t see any. I’m not super interested in running another distro, and I’d rather just not run that software on this device if need be. Part of me wonders if it’s because I only have 16GB of memory.
Alright, well I tried Fedora, and I’ve not done too much with it. I still get random crashes where caps lock flashes and the computer freezes
