Framework 13 Intel Core Ultra Ubuntu 24.04 Drag&drop system makes softwares crash
Which Linux distro ?
Ubuntu
Which release version?
Ubuntu 24.04
Which kernel are you using?
Linux 6.11.0-21-generic x86_64
03.04
Framework Laptop 13 Intel Core Ultra Series 1
Hello everyone !
There is an issue with my Framework 13 Ultra Series 1. The drag & drop system is pretty much broken. It makes the Firefox or softwares like Zotero crashes. With the thunderbird software, it simply doesn’t work (I mean that nothing happens after dragging and then dropping).
Is this a recognized issue ? Does anyone have an idea of how to fix it or what is causing it ?
Thanks in advance for the help !
