Framework 13 - NixOS doesn´t suspend
NixOS 25.05 + Gnome/Wayland
Which release version?
25.05.20250629.b43c397
Which kernel are you using?
6.12.35
Vendor: INSYDE Corp.
Version: 03.03
Release Date: 03/10/2025
ROM Size: 32 MB
AMD Ryzen AI 300 Series
AMD Ryzen™ AI 9 HX 370
As title says, new laptop with fresh 25.05 installation. When send to sleep, screen goes blank and then comes up again after a few seconds.
Reproduce using
With new HW, sometimes a newer kernel will work: Add this to your configuration.nix
boot.kernelPackages = pkgs.linuxPackages_latest;
This worked. 6.15.4 has no suspend issues.
Glad to hear it!
6.12 was released nov 2024, long before AMD Ryzen AI 300 Series, so naturally it has issues.
We recommend at least 6.14.
We published a compatibility matrix here: Framework Component Linux Support Matrix
I can safely say that I tried everything for my Ryzen 300 Series Framework 16, and the only solution was `boot.kernelPackages = pkgs.linuxPackages_latest;`
Thanks so much!
