Framework 16 Won't Wake from Sleep
I’ve been using this laptop for over a year and a half now, but no matter the distro including windows I cannot get the laptop to sleep properly, it will sleep but I cannot get it to wake up, at times if I wait and wait and wait 5-10minutes I can get it to wake up, but in being in the middle of something it’s a death sentence and I just have to hold the power button until it shuts off so I can get back up and running.
  • Which Linux distro are you using? Bazzite-Deck
  • Which release version?: Not sure; it’s the most recent
  • Which kernel are you using?: 6.17.7-ba25.fc43.x86_64
  • Which BIOS version are you using?: 4.03
  • Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series): AMD Ryzen 9 7940HS (16) @ 4.00 GHz
  • bazzite-deck-gnome:stable 
  • Linux 6.17.7-ba25.fc43.x86_64
  • Laptop 16 (AMD Ryzen 7040 Series))
  • AMD Ryzen 9 7940HS (16) @ 4.00 GHz
  • AMD Radeon 780M Graphics [Integra]
  • GNOME 49.1
  • Mutter (Wayland)
  • bash 5.3.0
  • Ptyxis 49.2
  • 2737 (rpm), 91 (flatpak)
Please assist if you can here’s the s2idle report:
Linux s2idle Power Report
s2idle report created 2026-01-31 17:33:51.197022 using amd-s2idle 0.0.1
:laptop: AMD Ryzen 9 7940HS w/ Radeon 780M Graphics (family 19 model 74)
:laptop: Framework Laptop 16 (AMD Ryzen 7040 Series) (16in Laptop)
:penguin: Bazzite
:penguin: Kernel 6.17.7-ba25.fc43.x86_64
:battery: Battery BAT1 (NVT FRANDBA) is operating at 85.65% of design
:white_check_mark: ASPM policy set to ‘default’
:white_check_mark: GPIO driver `pinctrl_amd` available
:white_check_mark: PMC driver `amd_pmc` loaded (Program 0 Firmware 76.96.0)
:white_check_mark: USB3 driver `xhci_hcd` bound to 0000:c2:00.3, 0000:c2:00.4, 0000:c4:00.3, 0000:c4:00.4
:white_check_mark: USB4 driver `thunderbolt` bound to 0000:c4:00.5, 0000:c4:00.6
:white_check_mark: System is configured for s2idle
:white_check_mark: GPU driver `amdgpu` bound to 0000:c2:00.0
:white_check_mark: PC6 and CC6 enabled
:white_check_mark: SMT enabled
:white_check_mark: ACPI FADT supports Low-power S0 idle
:white_check_mark: Logs are provided via systemd
:white_check_mark: LPS0 _DSM enabled
:white_check_mark: WLAN driver `mt7921e` bound to 0000:02:00.0
Prerequisites
Summary
Cycle 0Cycle 0
Start Time Duration Hardware Sleep Battery Start Battery Delta Battery Ave Rate Wake Pin Wake Interrupt
0 2026-01-31 17:31:01 0:02:50 4.99% 47.03% -1.28% -0.98W 8 ACPI SCI, GPIO Controller
Disabled Cycle 0
:zzz: Hardware sleep cycle count: 1
:zzz: Notify devices [‘UBTC’] found during suspend
Disabled Cycle 0
System had low hardware sleep residency The system was asleep for 0:02:50, but only spent 4.99% of this time in a hardware sleep state. In sleep cycles that are at least 60 seconds long it’s expected you spend above 90 percent of the cycle in hardware sleep.
Debugging :mosquito:
Disabled Cycle 0
BAT1 energy level is 2212000 µAh ACPI Lid (/proc/acpi/button/lid/LID0/state): open /proc/cmdline: vconsole.keymap=us amdgpu.abmlevel=0 video=DP-2:1024x768@85
Wakeup Source Linux Device Status
ACPI Battery PNP0C0A:00 enabled
ACPI Lid Switch PNP0C0D:00 enabled
ACPI Power Button PNP0C0C:00 enabled
Advanced Micro Devices, Inc. [AMD] ISA bridge 0000:00:14.3 enabled
Advanced Micro Devices, Inc. [AMD] Multimedia controller 0000:c2:00.5 enabled
Advanced Micro Devices, Inc. [AMD] PCI bridge 0000:00:01.2 enabled
Advanced Micro Devices, Inc. [AMD] PCI bridge 0000:00:02.2 enabled
Advanced Micro Devices, Inc. [AMD] PCI bridge 0000:00:02.4 enabled
Advanced Micro Devices, Inc. [AMD] PCI bridge 0000:00:03.1 enabled
Advanced Micro Devices, Inc. [AMD] PCI bridge 0000:00:04.1 enabled
Advanced Micro Devices, Inc. [AMD] USB controller 0000:c2:00.3 enabled
Advanced Micro Devices, Inc. [AMD] USB controller 0000:c2:00.4 enabled
Advanced Micro Devices, Inc. [AMD] USB controller 0000:c4:00.3 enabled
Advanced Micro Devices, Inc. [AMD] USB controller 0000:c4:00.4 enabled
Advanced Micro Devices, Inc. [AMD] USB controller 0000:c4:00.5 enabled
Advanced Micro Devices, Inc. [AMD] USB controller 0000:c4:00.6 enabled
PIXA3854:00 093A:0274 Mouse i2c-PIXA3854:00 enabled
Plug-n-play Real Time Clock 00:01 enabled
Real Time Clock alarm timer rtc0 enabled
Thunderbolt domain domain0 enabled
Thunderbolt domain domain1 enabled
USB4 host controller 0-0 enabled
USB4 host controller 1-0 enabled
/sys/devices/platform/USBC000:00/power_supply/ucsi-source-psy-USBC000:001/wakeup57 enabled
/sys/devices/platform/USBC000:00/power_supply/ucsi-source-psy-USBC000:002/wakeup59 enabled
/sys/devices/platform/USBC000:00/power_supply/ucsi-source-psy-USBC000:003/wakeup60 enabled
/sys/devices/platform/USBC000:00/power_supply/ucsi-source-psy-USBC000:004/wakeup61 enabled
AMDI0009:00 disabled
gnome-shell compositor is running
Thermal zones
├─ LNXTHERM:00
│ temp: 35.8°C
│ critical trip: 170.0°C
│ hot trip: 160.0°C
├─ LNXTHERM:01
│ temp: 34.8°C
│ hot trip: 160.0°C
├─ LNXTHERM:02
│ temp: 35.8°C
│ hot trip: 160.0°C
└─LNXTHERM:03
temp: 34.8°C
hot trip: 160.0°C
Suspend timer programmed for 0:00:10
PM: suspend entry (s2idle)
ACPI: \_SB_.PEP_: Successfully transitioned to state display off
ACPI: \_SB_.PEP_: Successfully transitioned to state sleep entry
Filesystems sync: 0.045 seconds
Freezing user space processes
Freezing user space processes completed (elapsed 0.003 seconds)
OOM killer disabled.
Freezing remaining freezable tasks
Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
printk: Suspending console(s) (use no_console_suspend to debug)
wlan0: deauthenticating from 96:18:65:d4:9d:19 by local choice (Reason: 3=DEAUTH_LEAVING)
PM: suspend of devices complete after 243.940 msecs
PM: start suspend of devices complete after 250.422 msecs
PM: suspend devices took 0.250 seconds
pcieport 0000:00:08.3: quirk: disabling D3cold for suspend
Clearing debounce for GPIO #0 during suspend.
Disabling GPIO #8 interrupt for suspend.
Disabling GPIO #84 interrupt for suspend.
PM: late suspend of devices complete after 2.549 msecs
ACPI: EC: interrupt blocked
PM: noirq suspend of devices complete after 237.997 msecs
ACPI: \_SB_.PCI0.GPP3: LPI: Device not power manageable
ACPI: \_SB_.PCI0.GPP4: LPI: Device not power manageable
ACPI: \_SB_.PCI0.GPP0: LPI: Device not power manageable
ACPI: \_SB_.PCI0.GPP2: LPI: Device not power manageable
ACPI: \_SB_.PCI0.GPP5: LPI: Device not power manageable
ACPI: \_SB_.PCI0.GPP7: LPI: Device not power manageable
ACPI: \_SB_.PCI0.GP11.SWUS: LPI: Constraint not met; min power state:D3hot current power state:D0
ACPI: \_SB_.PCI0.GP12.SWUS: LPI: Constraint not met; min power state:D3hot current power state:D0
ACPI: \_SB_.PCI0.GPP2.WWAN: LPI: Device not power manageable
ACPI: \_SB_.PCI0.GPP5.RTL8: LPI: Device not power manageable
ACPI: \_SB_.PCI0.GPP5.RUSB: LPI: Device not power manageable
ACPI: \_SB_.PCI0.GPP6.WLAN: LPI: Device not power manageable
ACPI: \_SB_.PCI0.GP18.NPU_: LPI: Device not power manageable
ACPI: \_SB_.PCI0.GP19.XHC2: LPI: Constraint not met; min power state:D3hot current power state:D0
ACPI: \_SB_.PLTF.C000: LPI: Device not power manageable
ACPI: \_SB_.PLTF.C001: LPI: Device not power manageable
ACPI: \_SB_.PLTF.C002: LPI: Device not power manageable
ACPI: \_SB_.PLTF.C003: LPI: Device not power manageable
ACPI: \_SB_.PLTF.C004: LPI: Device not power manageable
ACPI: \_SB_.PLTF.C005: LPI: Device not power manageable
ACPI: \_SB_.PLTF.C006: LPI: Device not power manageable
ACPI: \_SB_.PLTF.C007: LPI: Device not power manageable
ACPI: \_SB_.PLTF.C008: LPI: Device not power manageable
ACPI: \_SB_.PLTF.C009: LPI: Device not power manageable
ACPI: \_SB_.PLTF.C00A: LPI: Device not power manageable
ACPI: \_SB_.PLTF.C00B: LPI: Device not power manageable
ACPI: \_SB_.PLTF.C00C: LPI: Device not power manageable
ACPI: \_SB_.PLTF.C00D: LPI: Device not power manageable
ACPI: \_SB_.PLTF.C00E: LPI: Device not power manageable
ACPI: \_SB_.PLTF.C00F: LPI: Device not power manageable
ACPI: \_SB_.PEP_: Successfully transitioned to state lps0 entry
PM: suspend-to-idle
amd_pmc: SMU idlemask s0i3: 0x3ffbbeb5
Timekeeping suspended for 8.906 seconds
PM: Triggering wakeup from IRQ 9
ACPI: PM: ACPI fixed event wakeup
PM: resume from suspend-to-idle
ACPI: \_SB_.PEP_: Successfully transitioned to state lps0 exit
ACPI: EC: interrupt unblocked
rcu: INFO: rcu_preempt self-detected stall on CPU
rcu: 6-…!: (1 ticks this GP) idle=f6a4/1/0x4000000000000000 softirq=29086/29086 fqs=0
rcu: (t=77937 jiffies g=49493 q=50 ncpus=16)
rcu: rcu_preempt kthread timer wakeup didn’t happen for 77934 jiffies! g49493 f0x0 RCU_GP_WAIT_FQS(5) ->state=0x402
rcu: Possible timer handling issue on cpu=14 timer-softirq=3650
rcu: rcu_preempt kthread starved for 77937 jiffies! g49493 f0x0 RCU_GP_WAIT_FQS(5) ->state=0x402 ->cpu=14
rcu: Unless rcu_preempt kthread gets sufficient CPU time, OOM is now expected behavior.
rcu: RCU grace-period kthread stack dump:
task:rcu_preempt state:I stack:0 pid:16 tgid:16 ppid:2 task_flags:0x208040 flags:0x00004000
Call Trace:
clocksource: Long readout interval, skipping watchdog check: cs_nsec: 78063596541 wd_nsec: 78062846456
__schedule+0x2f9/0x7b0
? __pfx_rcu_gp_kthread+0x10/0x10
schedule+0x27/0x80
schedule_timeout+0x83/0x100
? __pfx_process_timeout+0x10/0x10
rcu_gp_fqs_loop+0x10a/0x6c0
rcu_gp_kthread+0x1ca/0x270
kthread+0xf9/0x240
? __pfx_kthread+0x10/0x10
ret_from_fork+0xf1/0x110
ret_from_fork_asm+0x1a/0x30
Sending NMI from CPU 6 to CPUs 0:
NMI backtrace for cpu 0 skipped: idling at io_idle+0x3/0x40
Sending NMI from CPU 6 to CPUs 1:
NMI backtrace for cpu 1
CPU: 1 UID: 0 PID: 0 Comm: swapper/1 Tainted: G W 6.17.7-ba25.fc43.x86_64 #1 PREEMPT(lazy)
Tainted: [W]=WARN
Hardware name: Framework Laptop 16 (AMD Ryzen 7040 Series)/FRANMZCP09, BIOS 04.03 12/22/2025
RIP: 0010:psi_group_change+0x29c/0x440
Code: 01 00 00 48 c7 c3 c0 c3 be a7 49 81 fa 00 20 00 00 0f 83 8f 01 00 00 4a 8b 04 d5 40 e0 38 a6 8b 3c 24 48 8b 94 03 10 0c 00 00 <89> f8 83 c8 08 f6 82 49 0a 00 00 04 0f 44 c7 89 04 24 e9 c5 fe ff
RSP: 0018:ffffcddd801d7da8 EFLAGS: 00000083
RAX: ffff8d0c766c6000 RBX: ffffffffa7bec3c0 RCX: 0000000000000100
RDX: ffff8d04c28ab040 RSI: 0000000000000001 RDI: 0000000000000180
RBP: 0000000000000001 R08: 000000368b4d456b R09: 0000000000000001
R10: 0000000000000001 R11: 0000000000000000 R12: 0000000000000000
R13: ffffffffa6c86b60 R14: ffffffffa6c86b60 R15: ffff8d0c1e29ce40
FS: 0000000000000000(0000) GS:ffff8d0c766c6000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
CR2: 0000000058681506 CR3: 000000028d62c000 CR4: 0000000000f50ef0
PKRU: 55555554
Call Trace:
? srso_alias_return_thunk+0x5/0xfbef5
? set_next_task_fair+0xd2/0x110
psi_task_switch+0x2b4/0x390
__schedule+0x4ab/0x7b0
schedule_idle+0x22/0x40
do_idle+0xa3/0xd0
cpu_startup_entry+0x29/0x30
start_secondary+0x126/0x170
common_startup_64+0x13e/0x141
Sending NMI from CPU 6 to CPUs 2:
NMI backtrace for cpu 2
CPU: 2 UID: 0 PID: 0 Comm: swapper/2 Tainted: G W 6.17.7-ba25.fc43.x86_64 #1 PREEMPT(lazy)
Tainted: [W]=WARN
RIP: 0010:llist_reverse_order+0x16/0x30
Code: 00 00 00 00 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 f3 0f 1e fa 48 89 f8 48 85 ff 74 15 31 c9 eb 03 48 89 d0 48 8b 10 <48> 89 08 48 89 c1 48 85 d2 75 ef e9 35 08 4d ff 66 2e 0f 1f 84 00
RSP: 0018:ffffcddd801dfeb0 EFLAGS: 00200086
RAX: ffff8d0c1e332400 RBX: 0000000000200282 RCX: ffff8d04d93e8038
RDX: 0000000000000000 RSI: 000000000001654c RDI: ffff8d04d93e8038
RBP: 0000000000000001 R08: ffff8d04c0bc3040 R09: 0000000000000000
R10: 0000000000000002 R11: fffffffffffeabda R12: 0000000000000000
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff8d0c76746000(0000) knlGS:0000000000000000
CR2: 00007f61e72ecff8 CR3: 000000028d62c000 CR4: 0000000000f50ef0
PKRU: 55555554
Call Trace:
__flush_smp_call_function_queue+0x3d/0x410
flush_smp_call_function_queue+0x37/0x70
do_idle+0x9e/0xd0
Sending NMI from CPU 6 to CPUs 4:
NMI backtrace for cpu 4
CPU: 4 UID: 0 PID: 119 Comm: kworker/u64:2 Tainted: G W 6.17.7-ba25.fc43.x86_64 #1 PREEMPT(lazy)
Tainted: [W]=WARN
Workqueue: writeback wb_workfn (flush-btrfs-1)
RIP: 0010:xas_start+0xae/0x100
Code: e2 03 48 83 fa 02 75 c6 48 3d fd 00 00 00 77 be 48 c1 e8 02 89 c2 83 f8 40 77 32 48 83 c2 04 49 8b 44 d1 08 eb a8 0f b6 48 fe <80> f9 3f 77 41 48 d3 ee 48 83 fe 3f 76 8e 49 c7 40 18 01 00 00 00
RSP: 0018:ffffcddd8059b458 EFLAGS: 00000282
RAX: ffff8d04d801db62 RBX: ffffcddd8059b4b8 RCX: 0000000000000006
RDX: 0000000000000002 RSI: 00000000000000b6 RDI: ffffcddd8059b4b8
RBP: ffffcddd8059b578 R08: ffffcddd8059b4b8 R09: 0000000000000003
R10: ffffffffffffffff R11: 00000000000b6000 R12: 00000000000000b6
R13: ffffcddd8059b570 R14: ffff8d0547eada38 R15: 00000000000b6000
FS: 0000000000000000(0000) GS:ffff8d0c76846000(0000) knlGS:0000000000000000
CR2: 000055b3a1bd3d10 CR3: 000000028d62c000 CR4: 0000000000f50ef0
PKRU: 55555554
Call Trace:
? __map_bio+0x169/0x190
? alloc_io+0x26/0x100
xas_load+0x11/0x100
filemap_get_folios_contig+0x78/0x3c0
? __process_folios_contig+0x1b9/0x1e0
lock_delalloc_folios+0xa2/0x240
find_lock_delalloc_range+0x117/0x250
writepage_delalloc+0x1da/0x5a0
? mod_memcg_lruvec_state+0xe7/0x2e0
? folio_mkclean+0xb3/0xc0
extent_writepage+0x10b/0x300
extent_write_cache_pages+0x14d/0x490
btrfs_writepages+0x74/0x130
? __pfx_end_bbio_data_write+0x10/0x10
do_writepages+0xd0/0x170
__writeback_single_inode+0x41/0x280
writeback_sb_inodes+0x214/0x4c0
? update_entity_lag+0x18/0x80
__writeback_inodes_wb+0x4c/0xf0
wb_writeback+0x2b3/0x340
wb_workfn+0x35c/0x460
process_one_work+0x18f/0x350
worker_thread+0x25a/0x3a0
? __pfx_worker_thread+0x10/0x10
kthread+0xf9/0x240
CPU: 6 UID: 0 PID: 7668 Comm: kworker/u64:24 Tainted: G W 6.17.7-ba25.fc43.x86_64 #1 PREEMPT(lazy)
Tainted: [W]=WARN
Workqueue: async async_run_entry_fn
RIP: 0010:acpi_os_write_port+0x13/0x70
Code: 83 57 7a 00 0f 1f 00 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 f3 0f 1e fa 0f 1f 44 00 00 83 fa 08 77 0c 89 f0 89 fa ee <31> c0 e9 41 34 34 ff 83 fa 10 77 0d 89 f0 89 fa 66 ef 31 c0 e9 2f
RSP: 0018:ffffcddda4b1f8b0 EFLAGS: 00000246
RAX: 00000000000000e3 RBX: 0000000000000001 RCX: 0000000000000002
RDX: 00000000000000b0 RSI: 00000000000000e3 RDI: 00000000000000b0
RBP: 0000000000000008 R08: 0000000000000000 R09: 0000000000000000
R10: 00000000000000b0 R11: 0000000000000001 R12: 00000000000000b0
R13: ffffcddda4b1f9f8 R14: 0000000000000000 R15: ffff8d04de2bd360
FS: 0000000000000000(0000) GS:ffff8d0c76946000(0000) knlGS:0000000000000000
CR2: 000055b3a2781800 CR3: 000000028d62c000 CR4: 0000000000f50ef0
PKRU: 55555554
Call Trace:
acpi_ex_system_io_space_handler+0x78/0x120
acpi_ev_address_space_dispatch+0x17d/0x4a0
acpi_ex_access_region+0x170/0x280
? __schedule+0x301/0x7b0
acpi_ex_field_datum_io+0xa1/0x4f0
acpi_ex_write_with_update_rule+0x106/0x270
acpi_ex_insert_into_field+0x312/0x370
acpi_ex_write_data_to_field+0xe6/0x3d0
? acpi_ex_resolve_object+0x10f/0x150
acpi_ex_store_object_to_node+0x1b6/0x3a0
acpi_ex_store+0x204/0x290
acpi_ex_opcode_1A_1T_1R+0x107/0x6a0
? acpi_ex_resolve_operands+0x5ea/0xac0
acpi_ds_exec_end_op+0x20e/0x8e0
acpi_ps_parse_loop+0x122/0x740
acpi_ps_parse_aml+0xbd/0x5d0
acpi_ps_execute_method+0x171/0x3e0
acpi_ns_evaluate+0x196/0x5c0
acpi_evaluate_object+0x1f0/0x470
acpi_device_set_power+0x200/0x4a0
acpi_pci_set_power_state+0x7f/0x150
pci_power_up+0x2d/0x180
pci_pm_power_up_and_verify_state+0x23/0xb0
pci_pm_resume_noirq+0xac/0x150
? __pfx_pci_pm_resume_noirq+0x10/0x10
dpm_run_callback+0x47/0x140
device_resume_noirq+0x16d/0x2c0
async_resume_noirq+0x21/0x30
async_run_entry_fn+0x31/0x130
kthread+0xf9/0x240
Sending NMI from CPU 6 to CPUs 9:
NMI backtrace for cpu 9 skipped: idling at io_idle+0x3/0x40
Sending NMI from CPU 6 to CPUs 10:
NMI backtrace for cpu 10 skipped: idling at io_idle+0x3/0x40
Sending NMI from CPU 6 to CPUs 11:
NMI backtrace for cpu 11 skipped: idling at io_idle+0x3/0x40
Sending NMI from CPU 6 to CPUs 12:
NMI backtrace for cpu 12 skipped: idling at io_idle+0x3/0x40
PM: Triggering wakeup from IRQ 7
rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
rcu: 4-…!: (4 ticks this GP) idle=5860/0/0x0 softirq=21999/21999 fqs=1 (false positive?)
rcu: 8-…!: (4 ticks this GP) idle=cb94/1/0x4000000000000002 softirq=16370/16370 fqs=1
rcu: 12-…!: (3 ticks this GP) idle=47a4/1/0x4000000000000002 softirq=19011/19011 fqs=1
rcu: 15-…!: (3 ticks this GP) idle=d558/0/0x0 softirq=12285/12285 fqs=1 (false positive?)
rcu: (detected by 10, t=77154 jiffies, g=49497, q=91 ncpus=16)
Sending NMI from CPU 10 to CPUs 4:
NMI backtrace for cpu 4 skipped: idling at io_idle+0x3/0x40
PM: noirq resume of devices complete after 155767.472 msecs
nvme 0000:01:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000f address=0x58e5c000 flags=0x0000]
nvme 0000:03:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0011 address=0x58e47000 flags=0x0000]
PM: early resume of devices complete after 2.548 msecs
[drm] PCIE GART of 512M enabled (table at 0x000000801FD00000).
amdgpu 0000:c2:00.0: amdgpu: SMU is resuming…
nvme nvme1: 16/0/0 default/read/poll queues
nvme nvme1: resetting controller due to persistent internal error
amdgpu 0000:c2:00.0: amdgpu: SMU is resumed successfully!
nvme nvme1: Identify namespace failed (-4)
nvme nvme0: 16/0/0 default/read/poll queues
nvme nvme0: resetting controller due to persistent internal error
nvme nvme0: Identify namespace failed (-4)
amdgpu 0000:c2:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
amdgpu 0000:c2:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
amdgpu 0000:c2:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
amdgpu 0000:c2:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
amdgpu 0000:c2:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
amdgpu 0000:c2:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
amdgpu 0000:c2:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
amdgpu 0000:c2:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
amdgpu 0000:c2:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
amdgpu 0000:c2:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
amdgpu 0000:c2:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
amdgpu 0000:c2:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
amdgpu 0000:c2:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 13 on hub 0
GPIO 8 is active: 0x18341b00
usb 1-4.3: reset full-speed USB device number 7 using xhci_hcd
usb 1-4.3: unable to get BOS descriptor set
PM: resume of devices complete after 1050.701 msecs
PM: resume devices took 1.055 seconds
OOM killer enabled.
Restarting tasks: Starting
Restarting tasks: Done
random: crng reseeded on system resumption
ACPI: \_SB_.PEP_: Successfully transitioned to state sleep exit
ACPI: \_SB_.PEP_: Successfully transitioned to state display on
PM: suspend exit
Dispatching Notify on [UBTC] (Device) Value 0x80 (Status Change)
wlan0: authenticate with 94:18:65:d4:9d:1f (local address=fc:b0:de:18:05:f7)
wlan0: send auth to 94:18:65:d4:9d:1f (try 1/3)
wlan0: authenticated
wlan0: associate with 94:18:65:d4:9d:1f (try 1/3)
wlan0: RX AssocResp from 94:18:65:d4:9d:1f (capab=0x1511 status=0 aid=7)
wlan0: associated
wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by 94:18:65:d4:9d:1f
Used AMD uPEP GUID in LPS0 _DSM
Woke up from IRQ 9 (IR-IO-APIC 9-fasteoi acpi)
gpe0B increased from 153 to 165
BAT1 energy level is 2152000 µAh
Thermal zones
├─ LNXTHERM:00
│ 35.8°C → 34.8°C
├─ LNXTHERM:01
│ 34.8°C → 33.8°C
├─ LNXTHERM:02
│ 35.8°C → 38.8°C
└─LNXTHERM:03
34.8°C → 45.8°C
Here’s a second report, I can pull any of these individual runs as well. I understand it says tainted kernel, but it’s acting like it always does, if there’s a distro I should test on I’m all ears, but this seems to happen on Arch, Mint, Fedora, Silverblue, Bazzite, CachyOS, etc.
s2idle report created 2026-01-31 18:09:56.287673 using amd-s2idle 0.0.1
:penguin: Bazzite
:vertical_traffic_light: Kernel is tainted: 64
Prerequisites
Summary
Battery
Low power state residency
Filter minimum session length
All>10 min>1 min
0 2026-01-31 17:53:38 0:03:02 32.07% 53.05% 2.51% 1.80W 8 ACPI SCI, GPIO Controller
1 2026-01-31 17:56:45 0:03:43 26.39% 55.62% 2.96% 1.73W 8 ACPI SCI, GPIO Controller
2 2026-01-31 18:00:33 0:02:52 33.69% 58.66% 2.49% 1.89W 8 ACPI SCI, GPIO Controller
3 2026-01-31 18:03:30 0:03:12 30.25% 61.24% 2.47% 1.68W 8 ACPI SCI, GPIO Controller
4 2026-01-31 18:06:47 0:03:04 31.94% 63.77% 2.45% 1.74W ACPI SCI, GPIO Controller
Which nvme ssd make / model / firmware version do you have? It appears that it is causing the suspend problems.
I’ve also completely defaulted the BIOS
WD_BLACK SN850X 2000GB (Firmware version 620361WD)
That should be ok. I have a sn850x 1tb, and suspend works ok here.
I guess I could try the WD SN740 and see if it sleeps any better; typically I dualboot, windows has always been on the other and I was never impressed by any difference seen, but maybe windows was being windows, I’ll attempt that shortly and put the same OS on the other SSD
Are you by chance using the Audio Expansion Card? Is it possible that the suspend problems are related to it? I had that problem when the card crashed during suspend because any process using it would be stalled and the screen would not turn on because something was waiting for the audio card.
You can of course easily try this by removing the expansion card.
I thought it was the nvme ssds because of this error:
So, you have 2 nvme devices installed. Try removing the non sn850x one, and see if suspend works.
I will attempt both of these recommendations and report as to whether I see any change
SN850X ONLY
s2idle report created 2026-02-02 07:33:06.337130 using amd-s2idle 0.0.1
:penguin: Bazzite
:battery: Battery BAT1 (NVT FRANDBA) is operating at 84.37% of design
:white_check_mark: USB3 driver `xhci_hcd` bound to 0000:c1:00.3, 0000:c1:00.4, 0000:c3:00.3, 0000:c3:00.4
:white_check_mark: USB4 driver `thunderbolt` bound to 0000:c3:00.5, 0000:c3:00.6
:white_check_mark: GPU driver `amdgpu` bound to 0000:c1:00.0
:white_check_mark: WLAN driver `mt7921e` bound to 0000:01:00.0
Prerequisites
Summary
Cycle 0Cycle 0
0 2026-02-02 07:32:14 0:00:52 15.44% 82.99% -0.41% -1.01W 8, 84 ACPI SCI
Disabled Cycle 0
Disabled Cycle 0
BAT1 energy level is 3845000 µAh ACPI Lid (/proc/acpi/button/lid/LID0/state): open /proc/cmdline: vconsole.keymap=us amdgpu.abmlevel=0
Advanced Micro Devices, Inc. [AMD] Multimedia controller 0000:c1:00.5 enabled
Advanced Micro Devices, Inc. [AMD] USB controller 0000:c1:00.3 enabled
Advanced Micro Devices, Inc. [AMD] USB controller 0000:c1:00.4 enabled
Advanced Micro Devices, Inc. [AMD] USB controller 0000:c3:00.3 enabled
Advanced Micro Devices, Inc. [AMD] USB controller 0000:c3:00.4 enabled
Advanced Micro Devices, Inc. [AMD] USB controller 0000:c3:00.5 enabled
Advanced Micro Devices, Inc. [AMD] USB controller 0000:c3:00.6 enabled
/sys/devices/platform/USBC000:00/power_supply/ucsi-source-psy-USBC000:001/wakeup54 enabled
/sys/devices/platform/USBC000:00/power_supply/ucsi-source-psy-USBC000:002/wakeup56 enabled
/sys/devices/platform/USBC000:00/power_supply/ucsi-source-psy-USBC000:003/wakeup57 enabled
/sys/devices/platform/USBC000:00/power_supply/ucsi-source-psy-USBC000:004/wakeup58 enabled
Thermal zones
├─ LNXTHERM:00
│ temp: 34.8°C
│ hot trip: 160.0°C
├─ LNXTHERM:01
│ temp: 32.8°C
│ hot trip: 160.0°C
├─ LNXTHERM:02
│ temp: 38.8°C
│ hot trip: 160.0°C
└─LNXTHERM:03
temp: 47.8°C
hot trip: 160.0°C
Filesystems sync: 0.041 seconds
Freezing user space processes completed (elapsed 0.002 seconds)
wlan0: deauthenticating from 94:18:65:d4:9d:1f by local choice (Reason: 3=DEAUTH_LEAVING)
PM: suspend of devices complete after 245.696 msecs
PM: start suspend of devices complete after 249.023 msecs
PM: suspend devices took 0.249 seconds
PM: late suspend of devices complete after 2.145 msecs
PM: noirq suspend of devices complete after 123.482 msecs
ACPI: \_SB_.PCI0.GPP1: LPI: Device not power manageable
PM: suspend-to-idle
Timekeeping suspended for 8.383 seconds
PM: noirq resume of devices complete after 39159.590 msecs
nvme 0000:02:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000f address=0x58e5c000 flags=0x0000]
PM: early resume of devices complete after 2.363 msecs
amdgpu 0000:c1:00.0: amdgpu: SMU is resuming…
amdgpu 0000:c1:00.0: amdgpu: SMU is resumed successfully!
GPIO 84 is active: 0x10141b00
amdgpu 0000:c1:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
amdgpu 0000:c1:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
amdgpu 0000:c1:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
amdgpu 0000:c1:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
amdgpu 0000:c1:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
amdgpu 0000:c1:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
amdgpu 0000:c1:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
amdgpu 0000:c1:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
amdgpu 0000:c1:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
amdgpu 0000:c1:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
amdgpu 0000:c1:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
amdgpu 0000:c1:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
amdgpu 0000:c1:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 13 on hub 0
PM: resume of devices complete after 1047.072 msecs
PM: resume devices took 1.051 seconds
OOM killer enabled.
PM: suspend exit
wlan0: RX AssocResp from 94:18:65:d4:9d:1f (capab=0x1511 status=0 aid=2)
wlan0: associated
gpe0B increased from 153 to 163
BAT1 energy level is 3826000 µAh
Thermal zones
├─ LNXTHERM:00
│ 34.8°C → 33.8°C
├─ LNXTHERM:01
│ 32.8°C → 32.8°C
├─ LNXTHERM:02
│ 38.8°C → 39.8°C
└─LNXTHERM:03
47.8°C → 52.8°C
SN740 ONLY
s2idle report created 2026-02-02 07:22:19.346988 using amd-s2idle 0.0.1
:penguin: Bazzite
Prerequisites
Summary
Cycle 0Cycle 0
0 2026-02-02 07:22:06 0:00:13 63.66% 85.58% 0.00% 0.00W ACPI SCI
Disabled Cycle 0
Disabled Cycle 0
BAT1 energy level is 3965000 µAh ACPI Lid (/proc/acpi/button/lid/LID0/state): open /proc/cmdline: vconsole.keymap=us
Thermal zones
├─ LNXTHERM:00
│ temp: 33.8°C
│ hot trip: 160.0°C
├─ LNXTHERM:01
│ temp: 31.8°C
│ hot trip: 160.0°C
├─ LNXTHERM:02
│ temp: 34.8°C
│ hot trip: 160.0°C
└─LNXTHERM:03
temp: 41.8°C
hot trip: 160.0°C
Filesystems sync: 0.058 seconds
PM: suspend of devices complete after 241.768 msecs
PM: start suspend of devices complete after 246.831 msecs
PM: suspend devices took 0.247 seconds
PM: late suspend of devices complete after 2.256 msecs
PM: noirq suspend of devices complete after 181.312 msecs
ACPI: \_SB_.PCI0.GPP8: LPI: Device not power manageable
PM: suspend-to-idle
Timekeeping suspended for 8.620 seconds
PM: noirq resume of devices complete after 646.352 msecs
PM: early resume of devices complete after 2.936 msecs
PM: resume of devices complete after 475.088 msecs
PM: resume devices took 0.481 seconds
OOM killer enabled.
PM: suspend exit
wlan0: associated
gpe0B increased from 151 to 159
Thermal zones
├─ LNXTHERM:00
│ 33.8°C → 33.8°C
├─ LNXTHERM:01
│ 31.8°C → 32.8°C
├─ LNXTHERM:02
│ 34.8°C → 33.8°C
└─LNXTHERM:03
41.8°C → 28.8°C
Audio Expandsion card didn’t seem to affect any of the results
