Which Linux distro are you using? Linux Mint 22.3 Cinnamon (based on Ubuntu 24.04 Noble)
Which kernel are you using? 6.14.0-37-generic (downgraded from HWE 6.17, see details below)
Which BIOS version are you using? 773 (current, verified via fwupd)
Which Framework Laptop 13 model are you using? AMD Ryzen™ AI 300 Series (Ryzen AI 9 HX 370, Radeon 890M, device ID 0x150E)
Problem description
I am running two external monitors via a Thunderbolt 4 dock (OBERDO TB4, one monitor via DisplayPort, one via HDMI). The DisplayPort monitor flickers repeatedly – it goes black for a few seconds, then comes back. Less frequently, the HDMI monitor does the same. In severe episodes, both monitors are almost permanently black, and keyboard input (connected via the dock) is also interrupted simultaneously.
The laptop display itself is unaffected in the current state, but under kernel 6.17 it was also flickering badly.
Kernel logs show a clear DMUB HPD RX IRQ storm:
amdgpu 0000:c1:00.0: amdgpu: [drm] DMUB HPD RX IRQ callback: link_index=7
(dozens of entries within seconds)
What I have tried
- Replaced DisplayPort cable – no effect
- Downgraded from kernel 6.17 (HWE) to 6.14 – reduced severity, but storm persists
linux-firmwareis up to date (20240318.git3b128b60-0ubuntu2.27)- All firmware up to date via fwupd (BIOS 773, Thunderbolt controller current)
- Kernel parameter
amdgpu.dsc=0– no effect - Kernel parameter
drm_kms_helper.poll=0x4– has no effect (parameter is ignored, module is built-in)
Question
Has anyone found a working workaround for this specific HPD storm issue with a TB4 dock? Is this a known bug with a fix in progress for the amdgpu/DMUB firmware?
Thanks in advance for your help!
