This is something that has happened to me at least twice now, and both times the issue could be fixed with a restart, but it is an interesting occurrence.
After using my Framework Laptop 16 for a few days without restarting, I have noticed it becoming sluggish and after running Cinebench my concerns were confirmed. Somehow, the CPU wouldn’t go beyond 1.5 Ghz when stress testing.
In task manager, when the CPU usage was low, the clock speed would sometimes peak at 4 Ghz, usually staying at 3, however the moment I started Cinebench, the clock speeds would drop to 1.54. The CPU usage was also always reporting a max of around 50%.
Temperatures were also well within the normal range at 54C. and never peaking, so it doesn’t make sense why the CPU was refusing to boost. Energy saver was turned off and max performance was enabled.
Has anyone else experienced this kind of issue before?
Here is a screenshot of the test. It ended up scoring a 3815, lower than the Core i7 4850HQ.
